X6 Mod: Replacing a SST-90 with an XM-L
23 posts / 0 new
ryansoh3
ryansoh3's picture
Last seen: 5 months 4 weeks ago
Hey everyone, today I’ll be sharing a small mod I did.
I had a TrustFire X6 originally with a SST-90. It was severely underdriven at 6.5A. Sad
So I manned up and replaced the SST-90 with an XM-L.
The star of the show (pardon the pun) was a Noctigon MCPCB:
The LED was a XM-L U2 cool white tint from FastTech.
First, I tried to dedome it, but it wasn’t too neat and somehow I blew it inside the light.
It worked for a few seconds, and when I turned it on again… well it didn’t. :~
So I decided to leave the dedoming until later until I could safely get my hands on some gasoline.
Thankfully, I was able to use the screw down mounts with this star as well:
I used some Arctic MX-4 (overkill) between the star and the heatsink.
Soldiering the leads to the PCB was pretty difficult as the copper + heatsink absorbed the heat pretty quickly.
More pics:
Without the plastic insulator:
With:
Beam profile was not too shabby, but it did have a green ring around the corona:
I’ll add some beamshots tonight. Thanks for looking!
BLF ≠ B-grade Flashlight Forum
MRsDNF
MRsDNF's picture
Nice mod. Did you use the standard driver? You may be able to get rid off the ring by adjusting the height of the led in the reflector.
ryansoh3
ryansoh3's picture
Yup, I used the standard driver. It’s not too bad, as it has a decent mode memory (actually works!) although the PWM frequency is distractingly low.
I’m pretty sure the LED is too low, so I need to add a copper piece under the PCB… I’m cutting a copper chunk out of an old CPU, I’ll let you know how that goes. Thanks!
DARCANGEL
DARCANGEL's picture
Excellent mod,I know a member here used a reamer to open up the reflector's bottom(x7 I think)with good results.That would clean the beam up some and allow adjustment in the reflector.Great job and love to see the beamshots from this beast!
ImA4Wheelr
Last seen: 1 year 2 weeks ago
Nice mod. Looking forward to watching it’s progression and results. If you don’t want to cut up the old cpu, you could pound out a pre-1984 US penny and then lap it flat. Don’t know if you have any of those.
ryansoh3
ryansoh3's picture
Thanks for the kind words, I just finished up cutting the CPU (and cleaned up some copper dust out of my eye).
I’m not sure if I have those pre-1984 copper pennies, let a penny! Silly
Unfortunately Korea doesn’t use any copper coins anymore.
A 10 Won coin, equivalent to a penny, costs more to manufacture than it is worth. It’s now a copper color coin:
The middle is silver colored and is pretty darn light, almost weightless. Not quite sure of its actual composition though.
ryansoh3
ryansoh3's picture
Now the XM-L has died too. Epic fail. Sad
I guess I’ll be looking for a new driver. Party
I think there are current spikes when the driver if first turned on…
panthervision23
Last seen: 8 years 8 months ago
It’s well-placed. Good job. Wink
ryansoh3
ryansoh3's picture
Thanks, the centering was tricky, as the reflector would shift to different places whenever I screwed the head in.
bibihang
bibihang's picture
Last seen: 20 hours 31 min ago
Replace it with XM-L2, I think they can handle the high current better.
ryansoh3
ryansoh3's picture
Got it, I just ordered some XM-L2’s, so I’ll post my results in a week or two. Smile
Slewflash
Slewflash's picture
Nice! Let us know if you dedome that bad boy.
Slewflash
ryansoh3
ryansoh3's picture
Will do.
Does anyone know how to get a safe amount of gasoline from a gas station?
I only need something like 200mL. Big Smile
MRsDNF
MRsDNF's picture
Do you know anyone with a petrol lawn mower or boat? Even two stroke fuel will do the same thing.
ryansoh3
ryansoh3's picture
No one around 20Km of here has lawns or boats unfortunately. Silly
Buildings after buildings… Big Smile
Thanks for the suggestion though!
Ledsmoke
Ledsmoke's picture
Last seen: 2 years 3 months ago
What about someone with a moped/scooter/car? Ask someone to take a little in a jar or something for you. It´s no biggie for people who has to fill their tank every week. Thats what I´d do anyway. BTW: Diesel will also work.
~ Ledsmoke ~
Dutch humor:
[quote=djozz]
 I do not think that the BLF-community ben
ryansoh3
ryansoh3's picture
Thanks. Would they have to pump gasoline directly into the jar? Or siphon it out of their tanks?
MRsDNF
MRsDNF's picture
With a bike, if you can access the outlet tube on the on off tap you could drain it from there.
ryansoh3
ryansoh3's picture
Interesting, I’ll try that out. I don’t think any of my friends own motorcycles though.
I’ll try asking a neighbor. Smile
18sixfifty
18sixfifty's picture
Last seen: 2 years 11 months ago
It should handle the current no problem as long as you have a very good thermal pathway and your emitter is correctly soldered onto the star. Make sure your pill is as flat as you can get it. There is a thread on here about lapping and that should help a lot. Also remember that less thermal compound the better, too much and it actually works as an insulator. You will get a much tighter hotspot if you drill out the hole in the reflector. I use a round file and do it by hand. You can drill out the base of the reflector completely if you want to. When you have it de-domed and the reflector drilled out and focused properly you are going to be flat out blown away by the results. Mine actually puts a large perfectly round hotspot on trees 500meters away. A full kilometer is what it can reach out to.
Good luck and I can't wait to hear about your results.
I’m a junky, I mod lights so I can sell lights so I can buy more light to mod so I can sell lights to buy more lights to mod.
ryansoh3
ryansoh3's picture
Great mod, thanks for sharing.
I had some trouble insulating the + and the – soldering points, what are you using as an insulator?
18sixfifty
Thanks and you’re welcome.
It’s a round plastic piece that came with the one I bought, this is a Ultrafire T90 but I also did an X7 SST-50 a while back, same size reflector basically.
One of the tricks I use all the time is to just cut small pieces of electrical tape if I don’t have anything else available. I cut a small strip and then cut the corner off so it fits around it. Four of them usually works the best. They hold each other in place that way.
ryansoh3
ryansoh3's picture
Oh that’s right, mine did also come with a white plastic retaining ring but I seem to have lost it.
I’ll try the electrical tape method. Smile
