Yup, I used the standard driver. It’s not too bad, as it has a decent mode memory (actually works!) although the PWM frequency is distractingly low.
I’m pretty sure the LED is too low, so I need to add a copper piece under the PCB… I’m cutting a copper chunk out of an old CPU, I’ll let you know how that goes. Thanks!
Excellent mod,I know a member here used a reamer to open up the reflector's bottom(x7 I think)with good results.That would clean the beam up some and allow adjustment in the reflector.Great job and love to see the beamshots from this beast!
Nice mod. Looking forward to watching it’s progression and results. If you don’t want to cut up the old cpu, you could pound out a pre-1984 US penny and then lap it flat. Don’t know if you have any of those.
What about someone with a moped/scooter/car? Ask someone to take a little in a jar or something for you. It´s no biggie for people who has to fill their tank every week. Thats what I´d do anyway. BTW: Diesel will also work.
It should handle the current no problem as long as you have a very good thermal pathway and your emitter is correctly soldered onto the star. Make sure your pill is as flat as you can get it. There is a thread on here about lapping and that should help a lot. Also remember that less thermal compound the better, too much and it actually works as an insulator. You will get a much tighter hotspot if you drill out the hole in the reflector. I use a round file and do it by hand. You can drill out the base of the reflector completely if you want to. When you have it de-domed and the reflector drilled out and focused properly you are going to be flat out blown away by the results. Mine actually puts a large perfectly round hotspot on trees 500meters away. A full kilometer is what it can reach out to.
Good luck and I can't wait to hear about your results.
It’s a round plastic piece that came with the one I bought, this is a Ultrafire T90 but I also did an X7 SST-50 a while back, same size reflector basically.
One of the tricks I use all the time is to just cut small pieces of electrical tape if I don’t have anything else available. I cut a small strip and then cut the corner off so it fits around it. Four of them usually works the best. They hold each other in place that way.
