You said not with any custom engineering, but how about a clip for 1-2 $ more on that TK-567. Together with 4 modes and an extension... perfect. Maybe with a neutral white emitter, I would even pay 28-30 $.
I love ur idea to order with the hi-quality as Tank007…I prefer Tk-567 ( if can put Osram bin would be better) and Tk-737 (could be extensional for 2*18650)…again price is very important…around $16-20 would be good…
I'd pay a little more for the E07 if we can get it with an Xp-G or XM-L. (Hard driven XP-G would probably be best given the size makes it inherently floody. Could we get a 1.5amp driver with an R4 or R5 for it?). The special modes by themselves are not enough to make me want to spend extra over the basic model. Otherwise that 567 looks pretty good. Without the extension would be best, again with a 1.5amp driver.
I'm not really a fan of the fat body required of the zoom lights/3xaaa form factor. I'd only be interested if I knew for certain the output really smoked.
You can count me in on a 567 if it will be less than 30 bucks even better yet at the target 24 bucks! I would take the E07 too if it was at the 20 dollar mark. It would be nice with modes! I would take both of them lol. Put in a quality LED and a good driver and I'm happy (but please leave out the SOS)!
I like a variety of torches and mode selection as long as the UI isn't stupid so i'm up for anything you guys decide on. I have some torches that start in low, some that start in high and some with or without memory or strobe and they each serve a different purpose for me.
Hi Joel, I would also like a clip. I don't think this can be cheaply integrated into the design. But maybe some sort of snap-on clip would be possible.
2,8 amps on P60-style host can be used for a duration of an 18650 without serious heat problem. It will get hottish, but not too hot to hande (just don't mess with the head). Zoomability might be a problem though.
And there is of course the notorious Ultrafire UF-980, pulling 4,5+ amps. Don't know if they can be put to reputable category... But you are right about reputable manufacturers usually being sissy what comes to driving their emitters,
BLF branding would be great. I mean there is for example the ITP A3 Eos Upgrade, why couldn't there be Tank007 E07 BLF edition?
If it doesn't get too hot too handle with 10+ watts in a P60 you're cooking the emitter (and you'll still cooking the emitter if it's too hot to handle). And it will be even worse in that zoom light.
UF-980 doesn't pull 4.5+ amps with protected cells or? In any case the body is much larger than a normal P60 light.
I think you can forget custom printing too, even their own UV light series have "CREE XR-E" printed on the body even though it doesn't have any CREE what so ever inside. It seems they only make one print for one model.
I have'nt really had a problem using the MF UF 3mode dropin which is a p60 on a solarforce L2 and a smaller uf 501a(16340). if it got too hot i would just switch to the lower modes. Theres a lot of other people who have the UF 3mode and other XML lights driven over 3 amps. i figured if youre gonna go XML at least have the option to drive it to the optimum current.I usually switch to mid or low if it got too hot or use high momentarily. I tried the xml on a sipik sk68 and the original driver which only drove it to i think 1.4amps. I was pretty happy with it but had to put the LED back on the trustfire F15. So getting a zoomie driven to 3amps is what id like.
The e07 and the 567 look beautiful to me . Zoomies tend to sit on my shelf but either way, I’d buy an xm-l tank007 zoomie if it was a blf edition:) I would just prefer the other two options:)
