I just got my new XM-L2 U2 SRK from CNQG a few days ago and the parasitic drain is only 1.42mA. Tailcap current on HIGH is only 1.52A, and only 160mA on low. This is the brightest light I have ever had, with Low mode being just a tad dimmer than my previous “bright” LED light. The driver board appears to be glued down so I may order another one when it comes time to put one of your drivers in it; I like this one too much to risk ruining it. I was going to resistor mod this one but not going to chance snapping the board. I was expecting a much higher tail current, not sure what is up.
1.42mA parasitic current is actually pretty darn high. That will essentially discharge a 2900mAh 18650 in 85 days. In just a month, you'll be down to 60% of the runtime you'd expect.
1.52A seems to be really low, I was getting 5A on high with fully charged cells.
I grabbed my 1ohm 100W precision resistor and scoped the tail current and found my earlier readings of 1.5A and 150mA to be wrong; I knew the 150mA was a RMS averaged PWM, but expected the 1.5A to be accurate. There was so much play in conductivity of the positive connection of the contact board where the cell buttons rub that it was hard to get an accurate reading. Without attempting to solder to the contact board to make connection for a test I’m not sure if I can get an accurate reading. Some spots I could only get 500mA, others up to 1.2A. The only difference from last time was I opened and closed the host twice.
I’m tempted to put a layer of solder on the board to prevent the gold plating from being completely worn away as it is already pretty scuffed and I’ve only opened the thing about four times now.
As for the parasitic drain problem; I lock out the light by unscrewing the battery bay 1/4 turn. Though with the high wear on the contact board this does worry me.
1 Ohm is Wayyyy too high of a value for a current shunt. If you push 3A through a 1 Ohm shunt, you'll burn off 3 Volts of the input. A current shunt for the types of currents we're measuring should be more like .01 to .05 Ohms.
Yeah I know. It’s all I’ve got outside of the DMM though. I normally work with HV stuff so I haven’t had reason to get a precision milliohm sense resistor. Normally I’m measuring tens of amps at hundreds of volts, so burning a couple volts here and there isn’t of consequence.
Retesting with the DMM and not using the 4x 18650 battery compartment I’ve measured 2.8A on high with a single high drain cell. Unfortunately my bench supply is out for repairs and I don’t have anything to make battery connectors with so this is the extent of my testing on this. The 1.5mA parasitic measurement does appear to be consistent so far though.
Tens of amps (Say 30) burns even more voltage.. 30 Amps over 1 ohm drops 30 Volts! And makes 900 WATTS of heat... A typical shunt for 30A would be about 3.3 MILLIOHMS, giving a drop of 100mV
Yep, and a 30V drop on a 600V line only 5, but a 3V drop on a 4.2V line is a 70 loss. I normally use the resistor to scope the DC bus current and primary current of my solid state tesla coils, there the worst side effect is the slight de-Qing of the resonant circuit.
I rigged up a PD to check the PWM of low mode and it appears to be a 500uS pulse every 4.5mS, or roughly 10% duty at 222Hz.
Don’t forget there are four cells in there, so it would take approx. 4 months to reach 60% on parasitic drain alone.
IMO that is acceptable, especially for a light with tailcap lockout. Could be better, but acceptable.
Ah yeah, forgot about the multi-cell thing.. Still awfully high though..
I joined up specifically because of this thread. I have been “collecting” lights for a while and have a SRK that I was going to program my own driver for. This beats what I was going to do hands down. I would just like to say congratulations to texaspyro for the work so far and to also say I will purchase 3 boards when they are ready. I have no problems with SMD soldering, electronics in general or microprocessor programming so if texaspyro is after a guinea pig for any beta testing I happily put my hand up, just ask.
Once again thanks texaspyro
I bow and salute you Sir TexasPyro,
Your effort and dedication to the cause has not gone unnoticed, I will be glad to put some extra moolah your way when ready,
tabs
Any updates TexasPyro? I got a kung I want to try this driver in. This driver would be alot easier than wiring up 4 2800ma amc7135 drivers in there.
I made some tweaks to the board layout to make it easier to add a slave driver. Waiting on the prototype boards to come in…
I’m definitely in for one!
I managed to toast one of the REGs when I disassembled (wire came loose, shorted the REG…).
I love what you are doing with this driver! The parasitic is awesome and the modes are as well.
However: is it possible to program this ourselves?
I ’d really like a simple high/med/low/off or High/low/moon/off for regular use and then a Moon/strobe/SOS/ramp/etc etc for a second group.
You can program the modes that you want to use (in the order that you want to use them) along with several other options. Think of the default mode list as a menu of available modes (there’s a LOT of them). You enter programming mode by holding the button down while applying power to the light. Click to the first mode that you want to use and hold down the button for one second and that mode is stored. Lather, rinse, repeat…
The firmware does not support mode groups, though.
OK, so I can program it on the UI! That’s sweet!
I was thinking of hooking it up to a computer to reprogram, but this is even better!
With this it’s possible to change the programming on the fly!
Awesome!
PS: now I’m in for TWO driver boards!
I’m really hoping its up for release soon. I don’t really want to wire up 4 amc7135’s drivers in there. If I did I would want to wire them individually to each led. I was hoping you would save me from all that wiring. :bigsmile:
Do we need to get on a list? Pay in advance? Learn a secret handshake?
If I receive my two M6’s I’ll need pair of these.
Looking forward to moding my first flashlight.
TexasPyro, you should sell the lights with driver installed as a unit too: I know a few who would buy already.
