How to do a review ? Help guide: share your Tips and Tricks.
I am not sure 'official guidelines' (or even unofficial ones) would be a good idea here on BLF. I like it that the treshold for doing a review here is low and that there is not much reluctancy for people to start posting their own reviews, however basic, so we have all kinds of reviews to read.
That said, my own important rule for a review is that, however short or incomplete the review is, before I start I think about if what I am writing up is at least something that people want to know. And it is of course nice if the reading is at least enjoyable. Oh, and I love good pictures
You need to measure with the battery in the light and the light on, when you turn the light off the battery voltage will increase.
I uses a external power supply to do it, where I step the voltage each second (Everything is computer controlled).
This way I can make charts like this:
I have been using Excel, but now i am using my own software (Together with JFreeChart java library). This way I can better secure the same size and colors every time and it is also easier to automate.
A lux meter is a cheap way to measure the brightness but some people is using the exposure meter in a camera.
Measuring the total light output is much more difficult, because the real equipment for that is very expensive. There are lot of substitutes, mostly they do a decent job of estimating comparing outputs between lights.
That depends on the style of review, some people does technical reviews, other focus more on actual usage.
I.e. a chapter describing how a light worked on a hike can be just as useful as a couple of runtime charts, this depends on the technical level of the reader and the planned usage of the light.
I like to see different types of reviews.
Generally, I prefer reviews that are not too long. I often find myself skipping all text, just browsing through the pictures and jump to the conclusion if its a long review.
Good pictures make a review much more enjoyable.
I also like a review that looks a bit on a light as a mod-host. What can be improved. I think several modders gives more fair ratings to lights. They use the whole scale more. Not only giving a light a 4-5 star rating despite that the light are outdated or mediocre in several obvious ways.
I often find a short review just as likable as a various longer ones. Example of small review done quite nicely by djozz. I would rather read 2-3 good small reviews than 1 large review. When that is said, I have seen a few short reviews that are quite useless.
I really like the reviews Relic38 does!
Foy have his own style. Not always that technical, but lots of nice pictures combined with good and fun writing. I always enjoy his review style. It shows that if you have the writing skills combined with some good photograpy, you don’t need a bunch of graphs and various stuff.
I think people need to find their own style, and put in the effort they feel are reasonable. All reviews cant be the same style, that would be boring…
@ Djozz.. thanks for the second part of your post.. first part is not really helpful for this thread.
second part says: pictures.. so pictures are a must? what kind of pictures are useful?
Are pictures of O-rings/lens thickness/tailcap/led/threads/beamshots/white wall important?
@HKJ... as always very helpful insight.. also answering my questions...
thanks for pointing out, that I should keep the DMM connected at all times, and not turning the light off to measure the voltage.
@RaceR86... thanks for pointing out that you don`t prefer too long reviews.
And again, you mentioned pictures.. What kind of pictures?
And on the other side, what pictures don`t you like? (out of focus?, 10 pics that look actually the same?
What kind of short reviews do you think are useless? what was wrong with them?
I agree that everybody has his/her own style, but again, it would still be nice (for beginners) to see what people actually "want" to see/read in a review.
Keep the thoughts coming. Especially some hints and tips, for example taking pictures.. (links to ideas on the net are also welcome).
Photography:
What do you need?
1. camera
2. tripod
3. pieces of white (colored) background
4. light
If I have time, I use my DSLR for taking pics. But my compact camera is usually closer at hand, and I can start shooting much faste, because with my DSLR I have to get it out of the shelves, change lens, check battery, get my strobe from another bag, check batteries again, get my Flash Remote triggers, and check batteries and working again... anyhow.
I like to have a white background for my pics. Originally I got myself 3 white plastic boards and put 1 down on a stable horizontal surface.
I try to put this in the corner of a room, so I can use the other 2 boards for standing against the wall.
but it depends on the time of day.. if its still bright outside, you can probably use daylight, especially bouncing of a large white surface (cloth/plastic board etc)
For my DSLR; I usually use my flash for bouncing of the ceiling, so it has a widely spread, and pretty diffuse style of lighting.
For my compact camera; I take the tripod and set it about 30-50 cm from the object. I then change the shutter speed so that it takes a long exposure, and not changing the Aperture, so a lot of light comes into the lens, which would give enough light to over expose the white background, so there are no visible imperfections, and it doesnt turn gray, like it would with a Auto exposure.
For taking pictures, light is the most important factor.
For some pictures where I didnt want to use my DSLR because too time consuming, and I my room lights werent bright enough, I used my SRK and put it tailstanding, not too far away from the flashlight I wanted to photograph.
The camera should be on a tripod, or something stable.
I then use one of the white boards, and bounce the light onto the flashlight. This way it takes away harsh black shadows, and still enough light to take a good picture.
any other thoughts?
The purpose of the light can vary, so having strict rules about the content of a review may be counter productive. For example if I'm reading about a thrower I want to know how well it throws, so kcd measurements and beam shots are very important. If a light is being reviewed as a potential mod host then good photos of the light's internal construction are very important, but kcd measurements and beam shots may be irrelevant or impractical.
Judging a photo is very subjective. I like photos that illustrate a point that the reviewer is making about a light. But I also enjoy artistic photos that show the bling factor. How to make these photos is a huge topic, but maybe some of BLF's more accomplished photographers can comment on that...
I like all kinds of different reviews. Basically though I am just looking for a conclusion. Was the light a good buy is one thing I would like to see. Pictures are nice but if the site already has good pics then I don’t see a lot of need for them. Beam shots are nice if they can be done well and with comparisons to other common lights. I just keep mine simple because I’m a simple guy. The good, the bad and the average with a conclusion. I doubt I will ever get really technical it’s not me and not my style. If I do get to where I can take beamshots I will start including them. For now I’m going to keep it as simple as possible.
for me… the good review is always end up with pictures of beamshot of the light with comparison to other popular lights.
so it can help you decide if you want to pull the trigger or not to buy that light.
any review with no pics of beamshot is just like believing a used car salesman’s word :Sp
Thanks.
So it seems that a comparison between a few lights is appreciated.
And oh, I didn't say that there has to b a set of rules to make a review,but I think it's just good to know what the average BLF use is interested to see.
Which makes it easier for reviewers to decide what and how to do a review.
Me, for example have no woods or fields around my house, so I can't take beamshots in nature. I could only possibly do indoor beam shots.
So it seems that a conclusion at the end is also something what people want.
Keep them coming.
What I said, link are welcome.
A question was: why pictures? For me there are two reasons. First: a picture shows more than you can ever describe in words, it can make a review more clear and compact, second: it makes the reading more pleasant. But I agree that numerous pictures of almost the same makes a review boring (I even sometimes find the great reviews of master-reviewer Foy a bit too picture-crowded to my liking).
How do I make pictures for BLF? I do not claim to make great pictures, but I do try to pay some attention to them. There are many better ways to make pictures but this is how I do it:
I have a good quality compact camera, but for pictures that I post on BLF I always use my phone camera (at the monent that is a Sony Xperia Z, it has a nice camera). The reason is that the lens (and sensor) is much smaller, so that you can get close to your object to make easy macro-pictures with good depth of focus. If I want to zoom in more I use this small self-made loupe (I retrieved the lens from somewhere inside a disused spectrofotometer, the 17mm driver is for size reference, the loupe is really small). I clamp it with an elastic band in front of the camera lens like this:
For that really zoomed in enlarged picture I have a stereo microscope (one of my former hobbies has been collecting microscopes), this is the (famous) Olympus zoom. I make the pictures through one of the eye-pieces (that is easy with a phone camera and more difficult with larger-lens camera's):
The best pictures I make with daylight, the diffuse light from the sky makes the clearest pictures. Because work and familylife take up most of my daylight time my hobby is confined to late at night when everone else is sleeping, so mostly no daylight for me . Instead, I light my objects from two sides, one side is the desktop lamp (with a modern 2700K Philips led bulb in it ), the other side is a floody flashlight with a Nichia 219. It produces a typical kind of photo that I quite like, but it may not be the clearest way.
I always touch up the pictures a bit (with the simple photo editor in the Mac Preview application) and resize them, and I make make the picture as small as possible without loosing the essence of the picture. I then upload them to -in my case- flickr.com.
Very helpful Djozz, thanks!
Especially your ideas concerning close up shots using your phone and a loupe.
Hope this will be helpful for others as well, that can start experimenting with taking pictures.
Your tips about using 2 lights, one at each side, is also really helpful, because that would eliminate the strong shadows on each side..
Still what I would suggest, is bouncing these side lights of a white board...keep forgetting the name of that stuff, that is used in boxes for shipping. It's very lightweight. What do you call that?
Do you mean styrofoam board? Yes, that would be a better way of lighting than with the two point-sources I use. I am usually too lazy to set-up a good lighting equipment, and I can't have a permanent set-up because when the family wakes up the hobby should be back in that one small corner of the computer desk (well, it keeps me tidy, that's a good thing).
I don’t know I prefer having textured backgrounds. Something that adds to the picture. I don’t find white backgrounds that interesting, but that’s just my opinion.
I feel sometimes I’m too verbose with my reviews. I often skip to the end of some reviews and read the pictures. Sometimes the graphs are hard for me top interpret. I like nice easy pictures.
I often wish I had better equipment. Like a nice DSLR, and something to measure lumens… but I don’t buy near as many lights as most of the people here so I don’t know how often I’d use an integrating sphere.
Djozz brings up a good point, resizing the photo to a small enough size that still shows good detail. I do this with 95% of my photos in my PhotoBucket account. I find that simply opening the original camera download photo and then clicking Save (to overwrite) is often enough to drop the file size 50%. A good free photo editor is Irfanview and it supports batch processing of multiple files. I dislike reviews that take forever to load the photos (though that could be the host too).
-Garry
Yep, Gary. I post a smaller version. Flickr gives you many many size options. I used to post much larger pictures but I find that, that was probably irritating.
@ Djozz, yes, thats what I meant... Styrofoam... the good thing is that its not shiny, and therefore diffuses the light.
Resize your pictures in only 2 clicks!
Install Photoresize and set it up with your desired settings.
Once you`ve installed it, you can go to any pic and click Right mouse button, and choose Resize picture...
that`s it..
This saves upload time, and eventually saving time to through different options in Flickr etc before you get your desired size.
Not going into details of how this program works, please read the website.
Any computer will be able to use it.
Once you set it up, you can resize any pic in 2 clicks.
I'm working at this too. I have two reviews in progress, and I'm trying to create a sort of template to follow with additional reviews.
The picture thing is still messing me up. I don't have enough windows to take good pictures inside. I tried going outside a few times, but it's so breezy that it's blowing my lightbox around. So I'm trying to get the lighting and exposure right for indoor photography. Photo editing is another big thing, especially since I rarely get anywhere near perfect shots straight out of the camera. I need to use RAW more so there's more color information to allow me to shift white balance and such in the editing software and still have a good picture. When I use a white background, I want the background to disappear. This is proving difficult. It'll probably be easier to use textured backgrounds.
Measurements will be something I'll be working on for a very long time. I need to acquire both the skills and the tools. I'll probably go back and update reviews over time.
As others said, the type of review you do depends on how you use your flashlight. I use mine primarily for hiking.
I can start off with the first impression type of review that flashlights always get, and then I can come back and add extra measurements and a long term review.
+1 8)
XnView is awesome for batch conversions too. That's what I use for batch editing when I prepare scanned books for OCR. I prefer Gimp when I can focus on one file at a time. Both are free.
