Nice. Is this a goer then?
It looks like it… I need to test the other patterns. So far I have only done XMLs.
Ok, XRE’s and (probably) MTGs are real easy… you can do them blindfolded. The XRE stars that I used were DX non-Sinkpad style stars. All the others were Noctigons. I don’t have any MTGs to play with (frankly I don’t see much good in those things).
XPG’s are a bit of a pain. The apertures are quite a bit smaller. It took me 5 tries to get a clean print. Should improve with practice, but I only had one Nichia 219 to test with. The first try left one pad dry. I could have used the second through fourth prints if I took a resistor lead and cleaned up the slight bleed I was getting between one of the pads and the thermal pad, but I wanted to see what it took to do it with just the stencil. I should have cut a smaller width piece of Kinko-card for use with XPGs. The piece that I was using was too wide.
Also, I think that just holding the stencil in place with one hand works as well as trying to tape it down. The double-sided tape holding down the star works very well.
A little bleed through won't hurt anything.. The solder will snap back onto the pads as soon as it reflows - especially if its tin-lead.
One trick that really helps with mylar/kapton stencils is to set a few of the same-thickness stars around the one you're pasting. It prevents the stencil from wanting to flop over the edges of the tiny star while you're squeegeeing the paste.
PPtk
I know that the bleed doesn’t usually matter, but I was testing the star/led before I reflowed it (if it tests good you know there are no opens/shorts). If both pads had bled to the thermal pad, I couldn’t test it that way.
Supporting the stencil with other stars should work really well. With the stencil flopping over the edge, it wants to bow the stencil upwards and you get more bleed/misalignment.
Also, I was using some pretty “low tack” masking tape to hold the stencil in place. If your tape is too aggressive you might damage the stencil when removing the tape.
aka “drafting” tape.
For sure - Kapton is tough, but if you manage to get a rip started, it will peel down like a banana..
Blue painter's tape is about perfect.
I was thinking that blue low-stick painter’s tape would be about right. Blank FR4 PCBs are about the same thickness (~1.65mm) as the star. I will take a spare one, trace around the star onto it and cut out a same-diameter hole. Tape the board down, set the star in the hole, and lay the stencil over it; no sagging, and the star will stay put.
Relic :) You Closet Zilog user :)
Just for fun, I pasted 6 XRE’s in under a minute. Took a couple more minutes to torch them… all worked fine.
What gave me away?
The Zilog Motion Sensor PCB Under your Noctigon :)
For sure - Kapton is tough, but if you manage to get a rip started, it will peel down like a banana…
How many uses do Kapton stencils usually last? With these kind of pads I mean.
The long thin strips between pads seem like they would fragile.
Be gentle and they'll last for dozens or hundreds of prints. Like I said, kapton is tough, just don't get a tear started..
BTW, wipe the paste in the direction of the length of the slots, not across them. That will greatly minimize the chance of tearing out the material.
I’ve got an XP-G2 waiting for a star swap for Ezarc. I think I’ll wait until this is ready. The few XML’s I’ve done were nerve racking enough. It looks so horrible when you put the solder paste on that you think there is no way that will work but somehow they all have.
I wonder how applying like grout(scrape diagonally across pads) would work. It seems similar but on a much smaller scale.
OK, I have 18 stencils available from the first run. Cost is $3 each shipped in the US. International add $1 to the total amount for postage.
They will be shipped in a standard letter envelope, no tracking… you pays your money, you takes your chances. If you need tracking, cost goes up to stupid levels… I think that the cheapest postage rate with international tracking is over $10, plus it draws the attention of nosey, sticky fingered customs agents…
First come, first served… I’d like to get some feedback on these before doing another run.
PM me for my paypal address… say how many you want so I can track the quantities and include your address.
Are you sure you’ll be doing another run?
