Thanks for your reply DBCstm. I was just able to get $2 worth of gasoline and I think I’m set for many many emitters.
Nice beamshots comfychair, it’s good to see them again. One thing I just wanted to point out was that since the C8 reflector is bigger than that of a P60, they can’t be used for comparing beam angles, right?
You can monitor to see if the dome falls off or is loosened, maybe 2-10 hours, or you can pull it out in 2-4 hours and poke it gently to see if it will easily be pushed/flipped up and off. Lately I've been doing the shorter time (2 hrs), and carefully flipping it off, starting from the side opposite the wires. Overnight takes the guess work out of it. Most of the time now I see a bubble forming under the dome, indicating the dome' seal has been compromised. At that point it comes off pretty easy.
There's no such thing as 'too long', just leave it in until the dome floats off on its own. If you lightly score the dome with a razor just enough to break the outer skin it can happen in as little as 30 minutes.
I did my first de-dome last night on a Crelant V21A XM-L. I don't have the know-how to remove the whole LED so I just unscrewed the reflector so the emitter was sticking out the end of the light and submerged the top 5mm or so into a shot glass with a little gasoline at the bottom. The dome slid RIGHT off this morning EASY as pie and darn near perfectly.
My only question is how do I get the gasoline smell off?
I ran the head very gently under water to rinse off some of the gasoline and let it sit out all day to fully dry but it still wreaks of gasoline since the metal was submerged somewhat. Obviously I can't really use any chemicals or anything get the smell off...what about just leaving it out in the sunlight? Would that be bad on the bare emitter?
Please use isopropryl alcohol - rinse it - works well with a squeeze bottle. The alcohol is relatively cheap at drug stores (maybe supermarkets too). I use it every time, works well. Actually I use it a ton on cleanups, solder flux, etc...
Should help with the smell, yes I'm think'n, but I can't smell as well as I used to... hhmm, that sounds weird... Well, dunno if it's the same, maybe look it up on wikipedia?
LOL, the flashlight doesn't exist anymore, I put the led in a c8 pill with a 2amp driver as a drop-in for my Uniquefire UF-t20. The test-thrower host is now empty, waiting for a next experiment :-)
