At what distance Ohaya? I would like to post you’re measurement in the OP. Each one will contribute to understanding this hard to throw emitter.
ohaya, I’m doing direct drive with a piece of wire from 2xPANA18650PD high drains, resistance mods for all springs. I get ~7A, which the MT-G2 sees comfortable with on copper.
I’m quite confident you can get rid of the resistors safely. J)
I measure the lux at 39 feet, then calculate back to 1 meter, so the number that I posted was at 1 meter (calculated).
Jim
P.S. Thanks for doing this!
Yes, I understand. I was being safe when I added the MT-G2, but I just haven’t had time to remove the resistor yet.
Thanks,
Jim
sorry, forgot to mention - dedomed and original lens.
Thanks Ohaya. Please update us if you change anything. I think your dedomed emitter is probably the best one out there right now.
Bummer. I was hoping for a lot more from the lum 5-90…. havent even played with mine…
Don’t get bummed. Keep in mind that I was using a wounded emitter. I think the numbers will be better when I try it with a health domed emitter. It’s definitely not a dedicated thrower, but that IM reflector and a domed MTG2 is a thing of beauty. Better flood and far better throw than a SRK. I don’t recall if you are looking for a good thrower for biking. I can’t think of a better setup for biking. I’m working on building a flashlight host for it now. It’s going to be redneck at first, but I can tell you that it will be my go to light for most outdoor situations. It just lights up a big area in front of you with smooth, wonderful light. You don’t realize it immediately, but then you start noticing that you see all kinds of stuff you don’t see with other lights.
EDIT: I will still need my SRK’s though. More compact and longer run times. Gotta love them. Like everyone else, I’m anxiously awaiting texaspyro’s driver.
I dedomed another MTG2 last night with heat while reflowing my Defiant spotlight. Well, I should say partial dedome. I removed all the silicone except for a small layer that is right over the diode array. I was afraid I would remove some of the phosphor with it. Partially dedoming with heat seems pretty safe. I didn’t have any phosphor lift off with the silicon. The remnants of silicon over the diode array will cause some artifacts, but at least the light will be emitted from a much smaller surface area.
Next time I will use the heat of the led and be more bold. Maybe the heat will create an air bubble in that area before I even start. Working in baby steps here.
Hopefully, I get the spotlight to a point that I can measure lux tonight. I am concerned a little about the emitter. It had a colder tint than expected in the previous light I was using it in. Before removing it from it’s base, I notice it had at least a partial gap to the base’s thermal pad. When I unsoldered it, there was not much solder on the pad. Hopefully, the emitter was not hurt by that. Here it is. You can see there are is some silicone over the diode array. There is also a fairly wide phosphor layer surrounding the diode array. I really want to get the last remaining silicone off. I hope to attempt that soon.
Defiant XML Spotlight w/Dedomed MTG2 - 250kcd at 5.6amps
Used newly dedomed emitter discussed in Post 21 and 2 Panasonic CGR18650CH’s direct drive. Amperage was measuring 5.6 amps before taking lux reading. 10 feet with glass lens:
Peak reading 26,900 lux (250kcd).
The beam below is on a beige wall. Also, my camera settings always create a very yellow tone. You don’t see the yellow ring in real life. Actually, in real life it is difficult to look at the hot spot at all.
EDIT: I forgot to mention that the emitter is off center for now. The pedestal pill I built has a lot of mass and takes time to cool down. I apparently did not set it level when I put it aside to cool which would have allowed the emitter to slide. Also, I did not that reflector has been handled a lot and has some scratches and other damage. Here is build thread. There have been some changes since and the build is still in progress.
I took the light out for bit last night. The emitter needs to be focused because the hot spot diverges too much. I had adjusted the pill to raise the height of the emitter, but it appears to be too far into the reflector now. Maybe it is the out of center condition. I’ll get it worked out eventually and report back.
Not sure how much the above would effect throw.
Nice! I’ve been looking at the Defiant Spotlight for a while, and was tossing around a dedomed XM-L or an MT-G2. Dedoming the MT-G2 scares me, that looks very yellow in the pic, is it like that for real?
Defiant XML Spotlight w/Dedomed MG-T2 - 250kcd at 5.6amps
OH MY……I do believe this is a record for the MTG-2!?
I may be on spotlight richer very soon……
And no, I regret to inform you that it was not I who was looking for a bike light. That would be the perfect situation, I on the other hand wanted some throw from this.
For some reason, it is much more yellow in the picture. The tint does warm up. Color rendition seems to be better with dedome. I like the dedoomed tint better.
The Defiant Spotlight is nice, but it has an all plastic body. I think the Wideshine’s (search Aliexpress) would be a better host because they have an aluminum body. It could be used to help shed the heat. They also have a bigger reflector and look even more focused. Also, the Wideshine (AKA Digital Projector) reflector is aluminum. I think they can be had for about $40. I should be receiving mine in a day or two. Here is a thread on it:
[image] Produces 110K Lux @ 10 meters thanks to a huge 95mm reflector Hey folks, I’m not exactly sure if this type of light is very popular around here, but I thought I’d post about my new addition to my light collection. Perhaps someone may be interested in this. In addition to the more traditional flashlights I like to purchase, I also like hand-held spotlights, so I’m always looking around for something new and interesting, and most importantly, affordable. For me, this new Digital Proje…
I think the emitter might not be in focus. Here is a picture of the whole beam:
Updates on my short DST (dedomed MT-G2, direct drive).
First, I removed the 0.5 ohm resistor I had, and got:
Tailcap current: 3.46 amps
Lux at 1 meter: 60477 (60.47 Klux, measured at 39 feet and calculated to 1 meter)
Batteries: 2xSibeile IMR 18350, fully-charged
I thought that I’d read that the Sibeile IMRs were NOT behaving as IMRs somewhere, so I then switched to 2xEfest IMR 18350, fully charged, and got:
Tailcap current: 4.81 amps
Lux at 1 meter: 71216 (71.2 Klux, measured at 39 feet and calculated to 1 meter)
Batteries: 2xEfest IMR 18350, fully-charged
The light is stock, other than re-wiring the pill for direct-drive, using the original driver as a contact board and the original driver-to-emitter wires. I have not done any braids on the spring yet.
Per request on another thread, here’s a pic of the dedomed MT-G2 inside the DST reflector:
Some pics of the emitter+Noctigon outside the light are here:
Accidental MTG2 dedoming. I accidently de-domed the MTG2 led inside the light Old Lumens made in this thread: https://budgetlightforum.com/t/-/17969 The light was shorting out, with the reflector making contact with the leads to the led board. The driver worked well, and just prevented it from turning on. To address this, small amount of non conductive paste was applied to the bottom of the reflector, and a bit of loctite added back to the threads, to prevent the head turning again by…
Jim
relic,
At least for myself, and for one other person, when the MT-G2 was dedomed, the tint went cooler instead of warmer. Here’s a whitewall I just took with my DST with dedomed MT-G2 (about 1.5 meters, I guess):
I have notes about dedoming the MT-G2 in gasoline on the “Accidental dedome” thread:
All I did was use the point on a tweezer, and carefully poke a couple of holes in the dome, then soak the emitter+PCB in gasoline. That worked for me, but maybe I just got lucky (only did it once).
Jim
EDIT: I just noticed the title for this thread was misspelled, which is probably why I a hard time finding it.
MG-T2 should be* MT-G2*
Thanks Ohaya. I’m in awe of the close up pictured of your dedome. Those pictureds and the dedome are amazing. They also show a lot of the anatomy of the emitter. My dedomes are not clean like yours. Mine are really partial dedomes. I think you have the only successful, fully dedomed MTG2.
That must have been a challenge assembling the head without a dome to help center the emitter. That DST reflector likes to wobble around when while the bezel is screwed down. So it looks like your reflector is basically resting on the emitters pcb. Same as my domed DST. So we both have about the same height placement. I get the feeling we are not focused yet. I think the emitter needs to be a little lower, but that will be a challenge to accomplish. I don’t think I will get around to playing with that any time soon.
I’ll update the OP first and then I better crash.
EDIT: Thanks for catching the header typo. Fixing.
EDIT2: Ohaya, did you see that CNG now carries an AR lens that fits the DST? That might give you a nice little bump in lux. Post 38:
AR lens in stock for sale now. http://www.cnqualitygoods.com/goods.php?id=1970 Double side AR coating lens 27mm x 2mm, Reference Flashlight—- P60 drop-in Type flashlights 42mm x 2mm, Reference Flashlight— C8 Flashlight 55mm x 3mm,Reference Flashlight—Sky Ray King Flashlight (Note : Some clone kings only has 2mm thickness lens) 58mm x 2mm, Reference Flashlight—Ultrafire HD2010 Flashlight AR Coating lens can upgrade the brightness by 10% to 20%. Thanks Ric
Thanks Ohaya. I’m in awe of the close up pictured of your dedome. Those pictureds and the dedome are amazing. They also show a lot of the anatomy of the emitter. My dedomes are not clean like yours. Mine are really partial dedomes. I think you have the only successful, fully dedomed MG-T2.
Actually, I didn’t have any problem centering with the dedomed MT-G2, but I did have problems when it was domed… as you said it would “wobble”, and everytime I screwed the head on, I was afraid it was going to chop the dome off.
But, since dedoming… no more wobble. I just screw the head onto the pill, and I got what was in the pic I posted.
EDIT: I noticed that the updated results after changing to the Efest batteries isn’t in the OP?
Defiant Super Thrower - 52.3kcd at 4.5 amps
2 NCR18650 laptop pulls in direct drive. Read 4.5amps before lux measurement. AR lens. All my set ups posted in this thread so far have been on Noctigon copper bases. Peak lux reading was 5,630 at 10 feet.
Hi,
It looks like we’re getting almost exactly the same tailcap current now!! What body/tube are you using with your DST? I had asked awhile ago on the DST thread about a body for 2x18650, but didn’t get any responses, so I’d be interested!
Just using the stock tube with pennies wrapped in copper tape as a spacer. I should be pulling about 5.3 amps with the NCR18650’s. I have some 18650 IMR’s that are a tool pack. I need to liberate them and see what my current goes up to.
Well, I’m currently about .3 amps ahead of you, so GO FOR IT :)!!
Did you do any of the spring/braid stuff on yours yet?
Thanks for the info. I have some 18650 dummy batteries, so I may try that with some Efest IMR 18650s I have.
