Nice mod!
Pushing 3A into an MT-G2 will get you close to 1500 lumens OTF, I’d guess. Based on my results with the ZY-T08. That’s a nice mod, and someone (garrybunk I think) was just asking about this host/emitter combo.
Not a huge difference between emitter and tail though when using the MT-G2.
Thanks for the info!
If you have 2,3 on the tail, then you have modded it for roughly 4,6A to the emitter when using an XP-G2. If so, that is the furthest I have read someone have pushed the stock driver circuit (you have modded the stock driver circuit right?), and way higher than Im at now.
If so, I have a feeling it should be able to do that current to an MT-G2 as well then… 0:)
Nice mod RaceR86. Is the reflector in this light identical to the HD2010. From memory the internal reflector measurement is 53mm. The reflector in the Small Sun ZY-T621 is identical to the HD2010 and one day I was planning om modding it to MTG-2. Just got to much other stuff on.
I’m pretty sure that the HD2010 and ZY-T08/T13 reflectors are different. I’m going off memory. I have a particularly painful one of grinding through into the finished side when trying to clear wires in the HD2010. The beam profile is a little different too. The HD2010 has a bigger hotspot and more friendly to use in midrange.
Im not sure how far the trimpot will let it go in terms of output. Ill get back to you if I find out… Could always use resistors though. I normally use resistors.
Based on what I have seen with this driver and an XM-L it seems like LED current are pretty equal to tail cap current x 2.
But if you are seeing 2,3A at the tail with and XP-G2, then that seems promising in terms of what the driver can handle.
Ill take beamshots with the setup I have right now (MT-G2 at 3,29A), then I might be tempted crank up the lumens! J)
Crank it up man! Gotta at least push 4A through it! And definitely report back on heat management. (I just noticed "FTP" in my last post - stupid iPhone autocorrections even though the word was typed correctly!)
Ohoya, I can not answer your question direcly, maybe others will, but you may find my various measurements with this driver interesting.
Lots of info have been added to the OP! Various beamshots too!
Ok, thanks, I understand. FYI, the reason for my question is that I’m interested in trying this light and the MT-G2 but with increasing the current, but don’t have a trimpot, so was trying to take the “easy way out”.
Unless/until someone with more electronics knowledge finds an easier or better solution I would say don’t bother if extreme output is your goal.
For those who are happy with a budget alternative to the 100$ CRELANT 7G5MT MT-G2, this light is a good option.
But people should ask themselves, is it worth modding the ZY-T13 when you have other lights out there like the King, KUNG, Warrior, M6 etc etc that can be modded too.
Thank you R86 for all the hard work and reporting. Very informative.
So I guess one easy solution (should one want to go MGT2 and high current in this host) would be to just go direct drive. Save the fairly unique driver and use a contact board in its place. Not sure if the tail switch could take 7 or so amps though.
