Thanks HKJ, this comparison concurs with my findings, I only use Eneloops and keep the lithiums as backups due to long shelf life.
lithiuml91l92_appman.pdf
861.01 KB
Good read.
I believe that these batteries can only deliver a low current, i.e. they are not good for flashlight usage.
At the current time I will not say yes to test them, I have way to many batteries in queue.
Guys, do lithium 1.5v AA batteries need any special charger to charge? Is Nitecore I4 suitable to charge them right?
They are not rechargeable, you will have to buy a new battery when it is empty.
Oh, I didn’t know. Thanks.
There are Lithium primaries (which these are) and Li-Ion rechargeables.
Li-Ion in AA size are sometimes called 14500s. They are 3.7V (fully charged 4.2V) and they need a proper charger designed for these voltages.
Sometimes people get confused between the two types as they sound similar.
Most of the time, you can also get 3.2 volt (3.6 volt charge voltage) 14500 cells.
Here I have some data of primary lithium (NICE, ENERGIZER.)
Thanks for clarifying this. I just thought for some reason that there are also rechargeable lithium 1.5v AAs, but now I see that there still are only NiMH )
Very useful info! This should be a sticky IMO.
Thanks for doing this comparison.
Thanks for the comparison chart. In my place, alkaline and lithium batteries dominate the stores. I don’t bother which one is best to use for certain devices. As long it works well.
Very nice visual here, Thanks HKJ!
Thanks HKJ.
While it is online, I thought I would post this link to an 18 page pdf from energizer. It has some comparisons to alkaline and nimh.
861.01 KB
Thanks HKJ. While it is online, I thought I would post this link to an 18 page pdf from energizer. It has some comparisons to alkaline and nimh. http://data.energizer.com/PDFs/lithiuml91l92_appman.pdf
That is an excellent write-up on lithium batteries. The comparison curves do (of course) look very much like the curves I have published (See bottom page 6).
The article does also include performance at different temperatures.
Your curves look more scholarly, but I suppose Energizer doesn’t want to scare the children. :bigsmile:
Some people believe that including less detailed contents, makes the information easier to read. That is probably correct, but personally I often prefer more detailed information.
Nice comparison, I knew the basic differences but these graphs tell the exact story, thanks!
Great test review which shattered my notions about Alkaline batteries !
So which type of batteries are good for flashlights that are not used until emergencies like in the car’s glove compartment and those used primarily at home for power failures.
I sense there is a trade off between capacity at higher loads and shelf life. From this review the primary Lithium batteries seem like the wise choice for these applications, but they are way too expensive here for me to use them they cost like $15/4. If the Eneloop have good storage life I might just switch them all over.
Lithium is a very good choice and if you expect the batteries to last many years the price of lithium is not that bad.
2000mAh eneloop is the second choice, they are rated to hold a charge for 5 years.
