After taking it completely apart, cleaning it thoroughly, oiling it, and carefully putting it back together...yes, it is on par with the ZT EXCEPT for one thing: The screws are much easier to strip on the Enlan as they're softer and not as deep.
As Vectrex said I did the opposite of hollow grinding, the edge instead of a perfect V is now like a gothic arch.
Since I just convexed the edge not the full height of the blade and because I did it by hand with sandpaper and leather heat was not a issue.
I could have used the belt sander, in that case all that was needed to not ruin the heat treat is to mantain the blade cool while grinding, it is important to not use gloves so that you can feel the heat, and dunk the blade in water every couple passages on the belt. Also is important to notice that because the edge is much thinner than the back of the blade it will heat much faster.
So this is called convexing? I usually put a sanding paper disc on my Dremel and use this to convex my edges. Hand must be trained a little to keep the angle on that little machine but it is easily doable. Don't think I am doing it on a $100-200 blade, though.
I'm sure they'd love to. :) Trouble is Ernest Emerson was smart enough to patent what is, in hindsight, a very simple, straightforward idea. He (or his patent lawyer) just made it seem like the best invention since the microbrewery, while sticking to the legal basics which is one reason why the patent is still valid.
See for yourself. I guess that's the main reason you don't see wave-style hooks on a lot of knives, even 12 years after he filed the patent. And I think that's a shame because it's a great feature. Most legitimate knife makers simply don't want to be sued.
My old Commander is still a favorite of mine and I really want one of those waved Enduras. I just don't want it bad enough to pay 65 bucks for one. ;)
I can't imagine a U.S. patent stopping a Chinese company from make waved knives, considering these companies make axis locks, spyderholes, and "inspired" designs.
Yes, what s.c. said. Same goes for Michael Walker's linerlock, for that matter. While I sympathize with the patent holder, the fact is such designs get copied mercilessly - especially by the Chinese. Heck, I have a copy of the Emerson Commander from DX - the manufacturer not only copied the wave feature, but the entire knife and packaging. SRM may be in a slightly different position, being an OEM supplier to various US companies, and is therefore held to a higher standard of conduct. But the knives we have been buying seem to be intended for the Chinese market anyway, which might insulate them from some criticism.
I was just putting myself in the place of a savvy Chinese project manager when I saw that nice, tall thumbrest on the EL01.
This'll probably be my next budget knife, after the postal strike around here is dealt with. Haven't owned any Enlan blades yet. Thoth, what did you grind with?
Postal strike in Canada is no big deal. Its a rotating strike in different cities, then it will only deliver on M-W-F. I ordered some knives a few weeks ago, and they were both delivered to me fine yesterday.
