Hello everyone, you can now get Tiablo flashlights here at Lightake with free worldwide shipping!
TIABLO Unique Design Characteristics:
1 Special purpose flashlight for hunting, searching and explore.
2 Unique body designs with perfect handle.
3 The high difficulty of process on the rear of lamp is much beneficial to imitate-proof.
4 It can be used by headstand. For example, in a space of 30sq.m, headstand TIABLO can make the same irradiation as a 25W daylight lamp.
5 Military grade and hard anodized finish in black color is much wearable.
6 Infinitely Variable Brightness System suitable for various distance lighting requirements.
7 Multifunctional circuit
8 Double circuit design with high-efficient electricity driver and multifunctional setting of birghtness adjustment.
9 With premium stripe for present
Tiablo A10-G Cree 7090 XR-E R2 2-Mode 260-Lumen LED Flashlight Black
This version of the A10 is designed specifically for use on any universal 1-inch flashlight gunmount. The brass insert inside the tube has been removed, allowing the light body a smaller diameter. The circuitry is the same fully variable and programmable circuit in the classic A10.
Specifications
* CREE 7090 XR-E LED. WC R2 LED
* Step up and down constant current driver, with high efficiency dual mode DC-DC regulator (PWM / PFM) and circuit to protect Li-ion battery from over-discharging. Working voltage is 2.75V to 8.5V, under the circuit will flicker to remind users to replace battery.
* High output: 1A at 260 Lumens for 3.5 hours
* Function: multifunctional circuit with advanced Mini computer chip, and it can set according to customers?variety requirement
* 53 mm diameter x 50 mm deep reflector provides greater efficient illumination over longer distances than the standard with similar power
* Support battery sizes Two 3.0V CR123A batteries or one 18650 Li-ion battery
* Type-III hard anodize high quality aerospace grade T7075 aluminium construction
* Switch: Tactical forward clicky switch
* Waterproof Capability: IPX-8 standard
* Toughened ultra clear glass lens with AR coating
* Weight: 180 g
* Length: 175mm Head diameter: 57mm Housing Diameter: 25.4mm
Tiablo A50 SST-50 3-Mode 900-Lumen LED Flashlight Black
Tiablo A50 SST-50 Product Features
- Brand Tiablo A50 SST-50 3-Mode 900-Lumen LED Flashlight
- Special tactical flashlight for hunting, searching and outdoor sports
- Super large smooth aluminum alloy reflector, raise the reflection efficiency
- Type-III hard anodize, Aircraft aluminum
- Smooth reflector and toughened ultra clear glass with AR coated led
- Tactical clicky switch: High-Low-Strobe
- Constant current high efficiency circuit, voltage range is 4V-8.5V
- Unique sculpture for the torch body
- Can be used as candle to illuminate 30m sq, approximately 300 square foot area, similar to a 25W daylight lamp
- Powered by 2xCR123A or 1x 18650 batteries (not included) or powered by 2x18650 batteries (not included) with extension tube (included)
- Water: beyond 5m depth (manufacture rated)
Tiablo A50 SST-50 Specifications
Model: A50
LED: SST-50
Max output: 900 Lumens
Reflector: Smooth reflector
Color: Black
Working voltage: 4.8V to 8.5V
Switch: Tactical
Lens diameter: 56.5mm
Length: 175.0mm
Net weight: 255.1g
Weight (including the packing):435.0g
Tiablo A9 Cree 7090 XR-E Q5 2-Mode 256-Lumen LED Flashlight Black
Specifications
* Cree 7090 XR-E LED. WC Q5 LED
* Step down constant current driver. High efficiency with dual mode DC-DC regulator (PWM / PFM), working voltage is 2.75V to 10V.Supports three battery sizes: one 18650 Li-ion battery, or two pcs CR123A, or RCR123A battery.
* Two stage output:
o 1. High output: 1A at 256 Lumens for 3.5 hours
o 2. Low output: 300mA at 60 Lumens for 8 hours
* 42 mm diameter x 36 mm deep reflector provides greater efficient illumination over longer distances than the standard with similar power
* Water proof: waterproof to 5m/15ft
* Tactical type switch: Low/High/Off button
* Weight: 155 g / less than 5.5 ounces excluding the battery.
* Length: 158mm Head diameter: 45mm Housing Diameter: 25.4mm
Tiablo A7 Cree 7090 XR-E R2 3-Mode 230-Lumen LED Flashlight Army Green
Specifications, Features, and Instructions:
Model: A7
LED: CREE 7090 XR-E R2
High output: 230 Lumens for 2.5 hours
Lens: Toughened ultra clear glass with AR coating
Body: Hard Anodized Type III Aerospace Grade Aluminum Alloy T7075
Colour: Green
Battery: Two CR123 batteries or one 18650 Li-ion Battery
Working Voltage: 2.7V to 8.5V
Switch: Tactical
Button: Metal Precision Designed
Waterproof: IPX-8 beyond 5m depth
Size: Head diameter 32mm, Length 134mm
Weight: 130g excluding battery
