Lumintop SD10 1D cell flashlight
Hmm! I really like this one. FINALLY a nice looking 1D light, and it even works with 3xAA and Li-Ion.
I assume this runs ok on an alkaline D cell? Do you think the lumen rating and output are rated on alkaline use?
-Garry
1×32650
10lm / 280h
100lm / 26h
800lm / 7.5h
3×AA
10lm / 150h
100lm / 15h
500lm / 6h
1×D
2lm / 60days
30lm / 80h
200lm / 7.2h
Like the idea for an extender too!
What I meant was, is this light rated 200 lumens for 7.2hrs on an alkaline D cell or NiMh D cell?
-Garry
Ah sorry mate. Gotcha now.
If I had to guess I would assume they used alkies purely because they are far more common. It seems like D capability is more of an added perk for emergencies with this light, rather than a main power source.
I would expect slightly less output on NiMh.
Will this light live up to its runtime claims?
3×AA
10lm / 150h
100lm / 15h
500lm / 6h
1×D
2lm / 60days
30lm / 80h
200lm / 7.2h
I suspect they are using alkie and the hours seem long. They might be counting the slow run down as they fade out.
I don’t want to live in a world where there are only D cells. :slight_smile: This seems to be a real ‘end times’ flashlight.
It certainly has that potential. :slight_smile:
Think it will run good with NiMh too. I don’t have any NiMh D cells, but plan to run eneloops when not running li-ions. It’s always nice to have options… the more the better!
I the “end times” there will only be C cells left.
lol probly right…. maybe a few 9 volts too :stuck_out_tongue:
GAH!!! Who knew?! :open_mouth:
i got mine
its great
any battery i have will fit
18650, 26650, 32650, 3x aaa, 1x D, 1x C
talk about a doomsday light :slight_smile:
very good output on 3x eneloops, im guessing around 500 lumen otf
Nice! By any chance do you have a Nitecore EA4 or a SWM D40A to compare it with?
What is the average capacity of good name brand alkaline D cells? I know you can order good LSD D cell NiMH’s with ~10,000mAh but off the shelf your lucky to find energizer 5000’s.
Because of the pretty simple UI and different cell capability I’m thinking this will be a great light to recommend to non-flashlight people so I figure they’re not gonna put much research into battery choice, what would they be better off with, ~5000mAh (rated so most likely less actual) NiMH’s or name brand alkaline’s? [forget about the one-time use vs. rechargeable aspect, what ones will be longest running?]
i had two ea4s but sold both… its about the same size - similar output to the eye as well… beam is a little less smooth looking but build quality is top notch… (aside from flimsy battery carrier)
i like it better than the nitecore personally
Have both. And D40 looks brightest, ea4 close, LD10 not so close.
What battery/batteries were you using in the LD10?
Well, I currently have a D40A and an SD10 on the way, and I already have the EA4W, so I’ll be doing a full review as soon as I receive it.
cant wait. i only have the ea4w, but bought it when there was no sd10 or d40a. do have the new xintd x3, but they really are not a comparison
