I have uploaded the test video
Tempting indeed. I wonder if this is brighter than CNQG’s XML2 King? They list their XML2 King as brighter than their XML Kung.
I guess if this is using the same driver this should be brighter than both.
Is it using the same driver?
I have not seen their driver,may be same driver,even if,4pcs >3pcs,it is more brighter
Do you have any comparison beamshots between this and the normal king?
Anyone have personal experience with this particular brand? Are the stated lumens accurate?
The SRKung posted in this thread seems to be using the original SRK host. The SRKung for sale at other sources use an updated host. See the photos below for comparision
SRK original
SRKung of this post
SRKung updated host
Notice how the “rails” on the body of the SRK M6 (original) are the same as the SRKung posted in this thread but the SRKung M4 updated version has “grips” in the rails
EDIT: the M4 also has updated head section as well. Not saying the Kung posted in this thread is bad, its just in the original kings body so its all in your taste i guess
Umm, ok. Host? But is the light as bright as is stated? What’s the run time?
They are almost never as bright as stated, but this claim is not very far off from what is possible with XML2s, it will be very bright if you aren’t used to LED lights, brighter than your car brights are. This seems like a reasonably good deal for a Kung with XML2s, but I don’t know anything about this particular body style or seller. With good batteries, runtime on high would be over an hour usually.
If you like this kind of light, buy a black version, then find the forum post for $13.80 per pair Panasonic batteries and get in on that deal for 2 sets of those and buy an xtar WPII charger would be my suggestion if you are new to this
Thanks, B42. This is a really nice looking forum with lots of helpful people. I’m pretty new to LED lights. I have a Fenix E21 that’s good for what it is. I recently bought an Ultrafire (this one, I think):
So I also bought two 18650 cells that I was told were Panasonics. I also have a Nitecore i4 Intellicharger. The Ultrafire I have is no doubt less than 1300 lumens, but it does seem to be very bright. Gets very warm if it’s been on high for a while.
The Kung I have gets hot fast, this one is XML2 (cooler), but it probably will get hot enough to be uncomfortable in 10-15min at least if its driven well and sooner if good heat sinking. The body looks like old SRK body which got hot in about 15min. You might want to look into Solarstorm/Fandyfire Warrior model too: it has a variable light setting for the low mode (kung is two light output lvls fixed), uses 3 batteries and doesnt get as hot as my Kung (painfully hot by 12min or so). I got the XML2 version for $45 from www.cnqualitygoods.com. It throws further than Kung, but has a whiter light, and the variable low is a plus and a minus: it has PWM, which you can see while moving fast and some people dont like, but the ability to change light output is so nice compared to Kung.
Remember to use batteries all at the same voltage and same type preferably in whatever light you get.
Nobody is buying, so make us a discount, maybe somebody will buy something.
I have a FandyFire UV-S5 and a CW SRK, the beam looks way better on my two, a lot better spill, I can’t believe how tight the hot spot is on the video, nothing like mine.
tabs
only $2 more than price I paid but gen 2 XML…
good upgrade I say…
plus no need to wait for the bidding
and yes, that Kung host is different with the one scattered on ebay…
Well, I placed my first order with willbuying.com, after I had a chat with Mofei, owner. Ok, so I bought the XM-L2 HD2010 — a XM-L2 U3 (hope it is) and a new emitter that is a Chinese 15watt version of the MT series. Will use a 5 cree in series driver
(early) for 17 Vf, and about 700Ma. Hope the HD is drawing as much amps as the FT version…Oh, got a discount to sweeten the deal :bigsmile:
Flomotion, anxious to hear the result of your order. Anybody bought one of these SRK’s yet?
I’ll be interested to see the results on the xm-l2 hd2010, its a good advertised price, particularly if its driven well.
Have uploaded the SRKING CREE XM-L T6 video,if you have interest,see our official Youtube video.see difference in T6 & L2.
I bought one, and it’s great. I have an updated skyray Kung too, and his L2 version is brighter. The color of the light is cooler white. This L2 version has a nice snug button… The updated one I have has a button with a lot of wiggle.
I got his HD2010 in the XM-L2, and it is very bright, and is a definite thrower. Changing different batteries, I have had it pull over 4 amps. I got the “grey” one, but it looks silver to me, nice torch, but — I talked him down 10% on my order, so I got it for like 28 dollars, but he whined and jumped the price up to like 36, after I bought mine. Still haven’t mess with the emitters, I bought. still waiting for the drive I bought from
18sixfifty hope icarus doesn’t come in the package :Sp
I been thinking of modding 4 SRKung heads for the high-beams on my SUV. ( one problem would be the cooling of them runing continously, and the voltage difference woudl need some kind of converter or new 12 volt drivers.
The Kung M4 i have is brighter than both the Halogens on high now.
