Which driver to buy for 3x MT-G2 I have lots of room and heatsinking?
25 posts / 0 new
18sixfifty
18sixfifty's picture
Last seen: 2 years 3 months ago
Ok so I bought another J-19 and it’s on the way. What driver should I buy to get the most out of 3 MG-T2’s? There is plenty of room and the pill is large enough and screws into the head which is huge and the body of the flashlight is heavy too. So I really want to push them hard. I’ll be running 3 king kong unprotected batteries. The current driver is 26mm.
Would this one work?
http://intl-outdoor.com/boost-7led-3-modes-23-cells-input-circuit-board-...
I’m a junky, I mod lights so I can sell lights so I can buy more light to mod so I can sell lights to buy more lights to mod.
comfychair
comfychair's picture
Last seen: 5 years 8 months ago
The 9A driver with LEDs in parallel (3A each) will waste less power than a boost driver with LEDs in series.
18sixfifty
Is this the driver you are talking about?
http://intl-outdoor.com/9a-3mode-5512v-circuit-board-p-561.html
How many lumens would I be looking at with this driver? 3A each doesn’t seem like much.
blueb8llz
Last seen: 42 min 39 sec ago
oh man, ive got to see the final results of this masterpiece! lemme me know if you wanna sell it after its finished hahah.
comfychair
It would be the same current to each LED as the 7x boost driver, without the inefficiency of a boost driver. Still close to 60 watts just for the LEDs not counting waste heat from the driver. The boost driver would be even worse.
18sixfifty
Ok I see and I guess that makes sense. That is probably as hard as I should push the batteries and stuff anyway. I think I’ll go ahead and order it unless you have any better suggestions. It sounds like it would run them pretty well.
Thanks a lot for the help.
18sixfifty
OK, Well I went and ordered the stuff so I’m now officially broke and will be stalking the mailman.
I’m now going to have one of these with XM-L2 U2’s on copper driven super hard and one with the MG-T2’s on copper driven moderately hard. It should be interesting seeing them side by side.
RaceR86
RaceR86's picture
Last seen: 5 years 11 months ago
Is the 9A driver suitable for 3 cells in series??
"Input: 5,5-12V
MAX 15V"
A general question. Lets say the pill had space for two 9A drivers (and those work perfectly with 3-cells) , could both of those be wired to the same contact board?
A theoretical 18amps divided on 3 MT-G2s with the right batteries.  J)   J)
Mode spacing:
bright - extremely bright.. OMG you gotta be kidding me bright!  J)
BLF LED database – collaboration spreadsheet and latest news about where to buy LEDs
http://budgetlightforum.com/node/19342
18sixfifty
“Input: 5,5-12V
MAX 15V”
Mode spacing:
bright – extremely bright.. OMG you gotta be kidding me bright!  J)
They need to make some better 32650’s Seriously I have no idea if that would work but it would be amazing if it did.
comfychair
I think even the best cells on the planet will fall from 12.6 to 12 or less as soon as it's switched on. It runs great on 3 cells. It's juuuust a tad too much for a single MTG2, but it does work and does put out an honest 9A to the emitter. With my ex-laptop Panasonic 2900s I measured 6.6A at the tailcap, never checked the input voltage under load though.
The LEDs are happiest at around 3A anyway, beyond that the heat they give off takes off like a rocket while the light output increases at a much less extreme rate.
18sixfifty
comfychair wrote:
I think even the best cells on the planet will fall from 12.6 to 12 or less as soon as it’s switched on. It runs great on 3 cells. It’s juuuust a tad too much for a single MTG2, but it does work and does put out an honest 9A to the emitter. With my ex-laptop Panasonic 2900s I measured 6.6A at the tailcap, never checked the input voltage under load though.
That’s cool, at 3amps each they should run pretty well then and still make for one very bright light. Still not sure if this mod is worth the money but it’s fun anyway. These are on octogons and the heat sinking is good so it should be a happy light that can handle being on high with no problems.
Ouchyfoot
Ouchyfoot's picture
Last seen: 10 months 4 weeks ago
I sure hope the MT-Gs will fit. I’ve been trying to build a triple and I can’t find a reflector that fits. The holes can’t even be opened up to accommodate the emitter because there is no room for expansion. I keep having my plans foiled because of this. Does anyone know of a triple reflector that will fit or can be widened to fit MT-G2s?
RaceR86
RaceR86's picture
OCTOGON
NOCTIGON
Smile
18sixfifty
RaceR86 wrote:
OCTOGON
NOCTIGON
Smile
LOL yes noctogons not octogons.
18sixfifty
This light has a fairly large spacer outside the emitters. It fits around the outside of the square board that the emitter sits on. I don’t see why it wouldn’t fit.
Can’t you simply take a round file to the reflectors you have? That is what I did with the double MT-G2 I built.
RaceR86
RaceR86's picture
18sixfifty wrote:
RaceR86 wrote:
OCTOGON
NOCTIGON
Smile
ROFL..
noctigons not noctogons... You'll get there..   Big Smile
18sixfifty
Oh jeeze I can tell it’s getting late. I wonder how many ways I can misspell it? :~
PilotPTK
Last seen: 7 years 12 months ago
18sixfifty wrote:
Oh jeeze I can tell it's getting late. I wonder how many ways I can misspell it? :~
Assuming you at least get the number of letters correct:
208,827,064,575
If you also get at least the first letter right:
8,031,810,175
I am currently extremely busy with work. Please do not expect a response from me quickly. I will be dropping in as time permits, but the amount of time I can dedicate to responding to topics and PMs is very limited.
18sixfifty
208,827,064,575
8,031,810,175
I don’t even have the spare time to spell it wrong that many times.
18sixfifty
PilotPTK What do you think of the driver selection?
Ouchyfoot
Ouchyfoot's picture
All the ones I have gotten have no room for expansion. You would be burrowing behind the reflector walls. The edges of the taper come flush to the existing XM-L holes. Sometimes even the pictures look like there is an edge that can be expanded, but it ends up being an optical illusion caused by reflection. I want one badly.
18sixfifty
What do you mean by expansion? I just open up the reflector itself by taking a round file to it and removing part of the reflector. I have done this on quite a few mods to let more light in, it increases throw quite a bit actually.
18sixfifty
comfychair
If the reflector has a flat area around the emitter hole, opening it larger doesn't screw anything up. But if the taper goes all the way to the emitter hole, enlarging it cuts into the sides and effectively shortens the reflector, does the same as poking the LED farther up, which is the one thing the MTG2 does not like at all when it comes to getting the focus good. The wider the flat area around the hole is the better the reflector works with the MTG2.
18sixfifty
comfychair wrote:
If the reflector has a flat area around the emitter hole, opening it larger doesn’t screw anything up. But if the taper goes all the way to the emitter hole, enlarging it cuts into the sides and effectively shortens the reflector, does the same as poking the LED farther up, which is the one thing the MTG2 does not like at all when it comes to getting the focus good. The wider the flat area around the hole is the better the reflector works with the MTG2.
Ok I see.
