I’ve made no secret of the fact that I am more of a user/hoarder than a modder/flashaholic, but I have really like P60 lights and it would be neat to have one that used AAs. I am totally going to try this.
As for that tail cap, all of my Ultrafire hosts look like the two on the right side of your pick. That radiused tail cap really caught my eye.
Btw, how was LED SuperMall to buy from? Any issues?
Good luck in your attempt. Worst thing that could happen is that you ruin a cheap reflector.
If you are not aware, by making the reflector slightly shorter and thinner you will increase “the spill ring”, and decrease throw a little.
My package from that store arrived after 12 days, so hopefully shipping is normally fast (or maybe I was just lucky). No issues or complaints from me, but then again, I have only used them once and have not been in need of support.
Not too worried about that. I sometimes buy hosts with 18650 drop ins in them because I can’t find the same empty host anywhere. Since I run primaries, these drop ins just sit around taking up space. But they will totally work in a three AA setup, so I can bugger up a couple and I won’t really be out anything.
I’m mechanically inclined, so I’m pretty sure I can do it. :nerd_face:
I see what you are saying. Colored 501Bs are usually fairly easy to find empty for a fairly low price.
I don’t think that was the case with the colored 502s.
After reading your post a few months ago I bookmarked the Manafont link, I figured this would be a great P60 based light for friends without worrying about Li-Ion education. I ordered a couple of them a few weeks ago and just got them today.
I’m going to go with an XM-L P60 in one but after looking at the light I have other ideas for the second one.
I’m curious though about how many amps the switch can take, what is your drop-in drawing?
Nice find,
Matt
Edit:
Done, installed an Int’l Outdoor 3 mode neutral XM-L drop-in. I liked the Int’l Outdoor reflector so I cut down a spare smo reflector. After all the fitting was done the beam was somewhat crappy so I ended up stippling it, added a gid O-ring between the reflector and lens just for giggles. As expected, the beam is all flood but nice and bright, I’m getting just under 3.0A with eneloops.
Don’t know how long it will survive at 3A, I just ran it on High and just after the 5 min point the light dimmed down. Turned off and waited about 2 minutes and all seems fine. I don’t know if this drop-in has thermal protection but the switch still feels fine. There’s little thermal path but the whole body of the light was hot.
A few notes on the host, it has O-rings for the head and tail cap but they’re so thin I don’t think they touch anything but the body. The body however is built like a brick, the walls are thick enough that you could probably drive a car over it without damage. Then again there’s the threads on that body, screwing on either the head or tail cap was like fingernails on a chalkboard. No problem with cross-threading but just not something you’d want to do often.
A thorough cleaning and lubing resulted in very clean, well lubed crappy threads. Oh well, it’s cheap host.
All in all it took me about a half hour to make this into a nice little light for gifting to non-flashaholics.
And a quick teaser for my plans for the second one, I have a few spare heatsinks like this kicking around, just need to decide/order the LEDs.
I used a 3 amp drop-in. Never had it on high for more than 7 or so minutes of continuous use. Did not have any issues. The button is fairly similar to one of the Omten 1,5A switches being sold from FT. If stock switch should say "bye, bye, Ive had it". There are replacement options that could be fitted or be made to fit.
Stock tailcap spring looks quite crappy, so copper braid mod would not be a dumb idea btw.
Right now, I mainly have it as a back-up light. I don't use my P60s that much. And I prefer the complete P60 reflector to this cut one. (The one in my bling AA light is good though, barely cut anything off it). I just like having the ability to put whatever I want in a 3xAA light. :)
It's a bit hard to tell from pictures alone. So the reflector is actually touching the material of the head just like in a P60 host then? I sort of figured from the pictures in the OP that maybe some heat might be transferred via the spring but I wouldn't have figured it to be much.
I was actually going to ask about heatsinking..... Interesting that you used a 3A dropin and got up to 7 mins on high. Did you ever do a tailcap test to see if it was actually drawing this much as it seems a lot of heat for such a small host?
I owe you guys an apology. I kept walking past this thread without dropping in. Being the quiet night it is I dropped in. I’m glad I did. Its full off modified lights. I like em all thanks guys. It still amazes me what you all turn out with what you have at hand. Its very inspirational. Cheers.
Its only the top of the head that is properly touching the body. If i were concerned about heat I would just wrap it.
No, I did not measure the tailcap after 7 minutes, but (first gen) XM-L + 3 good AA seems to hold fairly high current. In that light, I could not care if output is not perfectly regulated at a constant 3 amps..
I have not used the light lately, I just have it standing ready if I want to put one of my various P60s in it. Its nice having the option of putting whatever I want in a 3AA light, weather it should be a multi-color led, UV-led (soon to be made), a Nichia on copper pushing max output (2A+), or a more regular drop-in...
Actually, my cousin just recently just saw my multi-color drop-in in action and wanted it. Police strobe is cool! ;) So I just took it out the the host, put it in a super cheap black 501B that I had laying around, and then I had a fairly cheap light ready for him at no time. If he was not familiar with li-ion and electronics, I could have just given him the 3xAA light instead. Its nice having options. That is the beauty of P60s. Easy customization on the spot. Having various hosts with various battery types just adds to it.
When that is said, personally, Id take a nice and short 18650 with a a proper reflector 98% of the time.
Yep, the P60 format still has a lot of appeal as far as I'm concerned - for exactly the "mix and match" reasons you describe. Thermal constraints mean it isn't the best choice for super-high output in the hands of the uninitiated but as a general purpose light, it's quite adequate.
I really like the 3AA option and your use of such an economical host makes it all that much more affordable. Good light to hand out to kids for camping and running about. I don't think this Manafont one will replace my 3AA Javelin, but for the price difference I might get a couple just to play with.
is the one in camouflage a wf501b? i’m looking for something like that for my little brother but don’t know if there’s any take take AA batteries, he’s crazy for camouflage stuff.
