Test / Review: Sibeile IMR18650 3400mAh (Black)
Official specifications:
  • Nominal Capacity: 3400mAh(0.2C, 2.50V discharge)
  • Minimum Capacity: 3350mAh (0.2C, 2.50V discharge)
  • Charging Voltage: 4.2±0.05V
  • Nominal Voltage: 3.6V
  • Charging Method: CC-CV (constant voltage with limited current)
  • Charging Current: Standard charge: 1700mAh, Rapid charge: 3400mAh
  • Charging Time: Standard charge: 3 hours, Rapid charge: 2.5 hours
  • Discharge Cut-off Voltage: 2.50V
  • Cell Weight: 48g max.
  • Cell Dimension: Height: 65.00mm max. Diameter: 18.25mm max.
  • Operating Temperature: Charge: 0 to 45 °C Discharge:-20 to 60°C
This battery performs like the Panasonic 3400mAh cell with added protection.
The cell used can be discharged down to 2.5 volt, in my test I only discharges to 2.8 volt, i.e. I do not measure the full capacity. But then, not all lights will be able to use the full capacity.
After shipping the samples to me, some print was added to the box.
The discharge curves has good tracking, but the protection in this battery has a rather low current limit, it prevented doing a 3A discharge test.
Conclusion
With the exception of the low current limit this cell has good performance.
Notes and links
According to Sibeile the IMR text will be removed from the next batch of cell.
The batteries was supplied by Sibeile for review.
Thanks!! The low over-current cut-off will not appeal to many flashaholics.
Thanks for your work, HKJ!
I will stick to generic Protected ncr18650b. Great resilient wrapper, original Panasonic, everybody has them. Wallbuys 13.80$ per pair.
Same with Eneloop, they've become inexpensive (ebay). Why would i bother buying something else.
Thanks HKJ. Would the low current capability of the battery be because off a cheap battery protection circuit?
Are you sure they are genuine?
got link?
Thanks for the review!
The protection test graph seems a little wonky. I think it should start at 0.0A and should be scaled to a maximum of 3.0A to accurately show the data.
That would have been better for this cell, but I have kept same format as for all other 18650 batteries (All chart are made from the same scipt).
I see, thanks for the clarification.
HKJ
Thanks for your reviews. I’m interested for battery voltage versus current chart. Do you have this data. I may have missed it. Looking for good batteries that doesn’t sag too much at high current. :beer:
You can always use my comparator.
Excellent! Exactly what I’m looking for.
Thanks HKJ!
Goes to show the Chinese will put IMR on anything just for marketing purposes.
Thanks a lot for the review! Frontpage’d and Sticky’d.
