Supfire M6 - resistor mod (Update testing XP-G2s on copper in post 59-60)
Thank you RaceR. Good info. Based how you got your SRK to throw, I can’t wait to see your xpg2 mod beam shots. Best of luck.
Okay. I looked at the photo closer and now I see they’ve been stacked. I think I’m definitely going to give this a whirl when my light arrives. I’ll most likely swap XM-L2s on Noctigons too.
I’ll probably have some more questions when the time comes.
EDIT: I may wait to see how your XP-G2 swap goes. I’ve been considering the same thing for a while, and wondered why nobody ever uses anything but XM-L in these triples.
nice write up!
now, if we wanted to just add one extra resistor, what ohm would we want?
That would depending on how much current you wanted.
When I added 2x R120, i got about 3,2A.
2x R120 should be the same as one R060.
If you add one R056 (the same value as stock on the driver circuit). That would probably give you around 3,3A.
so would a r030 be the same as adding three as you did?
Racer, do u know how hot it got before the mod? Or how much hotter is it now?
Thanks for this bro! Good find/work!
nice write up, I’ve just received my m6 and I’m thinking the same as you, nw or hi cri xp-g2’s would be the way I’m thinking of doing things, yes there would be a lumen drop, but the throw increase would be interesting.
It would be the equivalent of adding an R040, if there were such a thing. So adding a R030 instead would result in even more current flowing to the emitters. That is, if the cells and other components can deliver it.
EDIT: Adding a R030 would be the same as adding 4 R120’s.
thanks! not too knowledgeable with the electronic parts of this hobby. should have divided the original resistance by three, instead i divided the r060 by two, which would be dividing by 4
For those of us that are new to the resistors and mods, online calculators can help out a lot.
Racer added three .12 resistors for a result the same as one 0.04
[quote=fishmaniac] Racer, do u know how hot it got before the mod? Or how much hotter is it now? Thanks for this bro! Good find/work! [/quote]
Texaspyro did some numbers.
The stock M6 is already hotter than a hot SRK ;) I increased output with more than 43% with the resistors I used. That adds a lot of extra heat to a light that is already hot on high. 0:)
[quote=gords1001] nice write up, I've just received my m6 and I'm thinking the same as you, nw or hi cri xp-g2's would be the way I'm thinking of doing things, yes there would be a lumen drop, but the throw increase would be interesting. [/quote]
Thanks.
I have some XP-G2 R5 3Cs, ill see if im happy with that combo, if not, ill just swap the emitters. It might take a week before I try it. Have to play with the stock XM-Ls a little first. :)
Might even swap the driver circuit one day too, ill see how the "off" feature grows on me. UI would be so much better if strobe and SOS were hidden. Its annoying to cycle through them in order to get to off, and its a bit annoying to wait for 3 seconds in order to turn the light off too. The normal SRK is much nicer in that way. No regrets buying the light though! :) Its nicely built. I always considered it a mod host, like all other lights I buy... 0:)
The advantage with this light compared to the kings are that I can more comfortably adjust high higher due to having a medium, which is now basically a high... :p I now consider high to be turbo.. J)
I know I have a stack of xm-l 4c emitters so I’ll likely fit them, cw is far too harsh these days and that’ll get me by till I can properly mod it, it is a good quality host that’s for sure. I just lock out when I want it off, quicker than a 3 sec button press lol
lol.. I did not think of that. Thanks, Ill try it out.. :)
Lol…nice one man! And with the super beefy contact point, I will not hesitate to try this.
its a dammed big twisty lol.
I just had a play with the m6 vs my convoy l2, whilst the l2 does feel heavier than the m6, I’m not sure I don’t still prefer the toilet plunger. They are though both completely different lights, big flood vs tight throw, both probably annoy my neighbours tbh, they’ll get used to it I guess, and cw really isn’t my thing, those emitters need swapping out stat lol
i can’t resist it,must wait until mine get here :smiley:
I’m still trying to get my mind around this.
So if I wanted the equivelant of 2 X .12 resisters, I would need 1 X .06 ?
impressive! i need to get someone to build me one or a srk like this
my hands are too fat and shaky to do resistor mods
A little off-topic, but I just got some “Wire Glue” from Ebay (http://www.wireglue.us/ and http://www.ebay.com/itm/290695765305?ssPageName=STRK:MEWNX:IT&\_trksid=p3984.m1439.l2649). The wire glue website says that you can use it to solder SMD devices.
Could it be used to do the resistor mods like this one?
Also, could it be used to solder stacked 7135s chips?
There’s also a “review” of sorts here:
i am thinking of starting to use a conductive epoxy to start attaching drivers to the pill
