That’s what was done in that BLF thread I linked, but I’m wondering if it could be used for other commonly-done things, e.g., resistor modes and adding stacked chips. I think that it’d work but not sure about how well it works when things get hot.
You guys are crazy…
I am normally a fan of resistor mods but the m6 gets unholdable hot in too short.
So before I even would think of a higher power, I would definitely try to build a handle for this.
Shame on you ohaya. Wire glue, after you just bought that nice soldering station.
Actually I have some too, that I bought from the same place on eBay. I haven’t used it yet, but I don’t think I’ll try it on resistors or 7135 chips. I can’t be sure “how” electrically conductive that stuff is. I originally bought it for installing P60 drivers into pills, but after I got my station I never needed to bother with the “glue”.
Resistors look pretty easy compared to stacking chips.
I’m going to have to take a look at the driver of my FandyFire Warrier to see if it can be “resister modded”.
I already know that the handle from my Roche M170 will fit, and pretty sure the one from my EYE40 will too.
glad i’m still keep my M170 handle :bigsmile:
I put one of my custom 9 amp SRK drivers in one of mine. It starts into the thermal management after a minute or so. An SRK takes about 3 minutes. The driver is measuring the temperature in the driver compartment, not on the flashlight body. The body was only around 10C above ambient when the thermal management kicked in. The thermal management in my driver keeps the light below around 55C. After 30 minutes or so, it has reduced the light to around 900 lumens (around 10 watts) At that point, the temperature has fully stabilized.
how does that compare to a SRK host?
That would depending on how much current you wanted.
When I added 2x R120, i got about 3,2A.
2x R120 should be the same as one R060.
If you add one R056 (the same value as stock on the driver circuit). That would probably give you around 3,3A.
Driver chip is AMC7136. its Current sense feedback voltage is 50mV
Your stock driver setting: 3x 0.056 ohms = 0.018 ohms
Stock drive current = 50mV / 0.018 = 2777 mA
After 2x0.120 ohm resistor added, 0.018 & 0.060 = 0.013 ohm
now drive current will be 50/0.013 = 3846 mA
The hosts handle the same amount of heat and stabilize at around the same temp/light level. The M6 driver compartment heats a lot fast than the SRK (maybe because the black body radiates heat back into it better).
Nice mod. Thanks for sharing!
Here's my quick calculations of your mod and a hypothetical mod with 1..5 pieces of 0.1 Ohm resistors:
RaceR86 mod | Planned mod | ||||
Stock resistor 1 | 0.056 | Ohm | 0.056 | Ohm | |
Stock resistor 2 | 0.056 | Ohm | 0.056 | Ohm | |
Stock resistor 3 | 0.056 | Ohm | 0.056 | Ohm | |
Extra resistor 1 | 0.120 | Ohm | 0.100 | Ohm | |
Extra resistor 2 | 0.120 | Ohm | 0.100 | Ohm | |
Extra resistor 3 | 0.120 | Ohm | 0.100 | Ohm | |
Extra resistor 4 | 0.100 | Ohm | |||
Extra resistor 5 | 0.100 | Ohm | |||
Resistance | |||||
Stock | 0.01867 | Ohm | 0.01867 | Ohm | |
w. 1 extra resistor | 0.01615 | Ohm | 0.01573 | Ohm | |
w. 2 extra resistors | 0.01424 | Ohm | 0.01359 | Ohm | |
w. 3 extra resistors | 0.01273 | Ohm | 0.01197 | Ohm | |
w. 4 extra resistors | Ohm | 0.01069 | Ohm | ||
w. 5 extra resistors | Ohm | 0.00966 | Ohm | ||
Feedback voltage (mV) | 45.5 | Calculated back from the measured 2.4A emitter current - takes driver losses etc. into account.. | |||
Emitter current | |||||
Stock | 2.44 | A / emitter | 2.44 | A / emitter | |
w. 1 extra resistor | 2.82 | A / emitter | 2.89 | A / emitter | |
w. 2 extra resistors | 3.20 | A / emitter | 3.35 | A / emitter | |
w. 3 extra resistors | 3.58 | A / emitter | 3.80 | A / emitter | |
w. 4 extra resistors | A / emitter | 4.26 | A / emitter | ||
w. 5 extra resistors | A / emitter | 4.71 | A / emitter |
That’s pretty awesome.
Thanks for the calculations!
Am I right that the upper limit to this mod is, in effect, direct drive? After all I believe that the cells are in parallel as are the 3 emitters. This is good as there is less danger in wildly over driving the emitter.
The TR-3T6 resistor mod had 2 or 3 cells in series. If I had this light, I wouldn’t hesitate to do this mod.
Nice calculations _the_.
Should be good guidelines. :)
[quote=dchomak] Am I right that the upper limit to this mod is, in effect, direct drive? After all I believe that the cells are in parallel as are the 3 emitters. This is good as there is less danger in wildly over driving the emitter. The TR-3T6 resistor mod had 2 or 3 cells in series. If I had this light, I wouldn't hesitate to do this mod. [/quote]
Most likely yes. We can not know how far the resistor mod will work until someone tries it though. Might be limits. But as can be seen, medium and low becomes higher too. About 3,6A to each emitter is already at the stupid amount of heat for this light IMO. It will be very useful in the winter though. Not only does it function as a light, but it will be a great hand warmer too! :)
4 cells in parallel will be able to kill 3 XM-L mounted on aluminium in DD, so DD is not a good idea on stock emitters. Put in XM-L2s mounted on copper and you should be able to output the amount of current you desire, if the driver will do that. But there is really not much point in going beyond the 3,5-3,6A range IMO. Not only due to vf of XM-L2s and the less great medium and low, but mainly due to heat.
I’m loving this thread. I’ve been seeing resistor modding in the forums a lot lately, but most of the chatter was between modders with electronics backgrounds. This thread is truly helping me understand what is going on. The before and after pictures by RaceR86 gave me immediate focus of the what and how, and each additional post has helped me with the why. Now I’m looking at all my lights a little differently. I can’t wait to get started.
One of the original emitters failed during the experiment (not sure why), so I don't have directly comparable results, but here we go:
2 x 0.1 ohm resistors did boost the emitter current to about 3.3-3.4A (with XM-L2 3C on Noctigon), quite well in line with my calculations.
Output jumped up to about 3100 lm (OTF, after 30s)
3 x 0.1 ohm resistors gave another 100 lm, up to about 3200 lm of nice neutral white light.
Light
Approximate min lumens
Approximate max lumens
SupFire M6-T6X3 XM-L2 3C (3x0.1ohm mod) | 390 | 3,196 |
SupFire M6-T6X3 XM-L2 3C (2x0.1ohm mod) | 381 | 3,102 |
BTU Shocker NW XM-L2 Mod | 52 | 3,079 |
BTU Shocker CW | 52 | 2,820 |
Solarstorm Warrior XM-L2 T6 1A | 94 | 2,397 |
Skyray King CW | 235 | 2,298 |
Trustfire TR-J12 | 338 | 2,195 |
SupFire M6-T6X3 | 301 | 2,190 |
BTU Shocker NW | 47 | 2,181 |
Skyray King NW | 230 | 2,096 |
Solarstorm Warrior XM-L U2 1A | 85 | 2,077 |
APEX 5T6 NW | 150 | 1,941 |
Blackshadow Darth NW | 169 | 1,532 |
Ps. Throw is now about 49kcd (440m)
Edit: Fresh cells -> 3309lm (OTF, after 30s)
_the_ that is sweet, and your calculations seemed good too.
Based on the resistor values, and amps, we seemed to get very similar results, so that is always nice to see. :)
Are you one of the people who have ordered AR coated lens from CNQ? Would be nice to see your lumen comparison on your modded light with AR lens vs stock.
(I know many others have those lenses coming, and some will probably share, but the more numbers we get, the better)
Edit: did you measure current with 3 x 0.1 ohm resistors?
Not yet.. But I think I need to order some.. ;)
Didn't have time for unsoldering the emitter leads again for measurements. Sorry. Might do this later (I know, I should buy a clamp meter)
I have a feeling you will order at least one pretty soon. Im still waiting, I want to see some numbers before I pull the trigger.
If you find the time, this day or another, please check emitter current with 3 x 0.1 resistors. Considering that you only saw a 94 lumen gain going from 2x 0.1 to 3x 0.1. Im wondering if you are not seeing much of that calculated output (3,8A) due to vf and such of the copper mounted XM-L2s.
Some may be familiar with my other SRKs (SRK/UV-S5), both modded. A little comparison here.
I tested both of those vs my current Supfire M6 (not supbeam as wrote on one picture). Mouse-overs below.
Camera settings:
1,6s, f5, iso400, 17mm (aps-c), WB was 5000K on first comparison, and 5200K on the second.
What other members have noted, or showed before. The M6 have less flood, and a more defined hotspot with slightly more throw. Otherwise, not a huge difference compared to my other modded king. In real life, there is no doubt M6 appears brighter due to the more harsh light. Output difference is not that much though. Due to tint,CRI and such, id take the SRK easily. Much nicer in real life. But its impressive to see the output of the M6 with stock emitters (and modded driver circuit).
When it comes to throw, I compared it to my SRK with de-domed emitters and a much lower current. The treeline in the distance are 120 meters away. The de-domed SRK wins fairly easily, not a surprise really. Due to not having that much bright spill, I would say its a better thrower in real life than in the picture. Lots of bright spill and flood kinda limits the ability to see things in a distance. The M6 outputs a lot more light though(!), and still have decent throw despite running close to 3,6A to XM-Ls on aluminium. And when XM-Ls are on aluminium, gain above 3A is not that much.
Camera settings:
it seems there is some mistake on 2nd picture RaceR,it supbeam instead of supfire :bigsmile:
