Updated with some pics and current draw.
Has anybody compared the new switch on the S15 to the older type on the S10?
I dont own a S10, so I cant compare for you. What do you exactly want to know about the switch?
The switch is soft rubber on the S10. My copy doesn’t have a positive clicking action, but my S10Ti does.
I took the S10 apart to swap the emitter and discovered that the rubber button operates a small, fragile, metal switch that is flexible. I ended up having to insert some copper between the rubber button and switch to allow it to operate properly. I read online that others have mentioned switch problems with the S10, so i’m hoping they have sorted the problem with the new Blue switch of the S15.
Also, do you have a Zebralight SC52 to compare to the S15?
Thanks
Matt
Sorry, no ZL SC52 here...
This switch feels good.. no problems yet.. except for the moon mode, when I click the switch too fast to Turn it Off, it turns on again.. I have to click it a little longer.Its a matter of milliseconds.
Ok, thanks
Thanks a lot for the review! Frontpage’d and Sticky’d.
I'd love to pick one of these up one day. I'm a huge fan of the Olight Baton series and have an S10 & S20. I prefer the S20 due to subtle differences in the UI and that the S20 has strobe where the S10 has a pretty useless SOS. It's safe to say that my S20 is my favorite all around light as well as my current EDC. I've tried other lights but keep coming back to the S20. Can't say enough good things about it.
Nice to see that the S15 has a hidden strobe instead of hidden SOS. It should be a great light like the S20 is. ;)
Excellent review, BTW! :beer:
Great stuff. Price is nice but at $40 it wouda been a steal.
Wow, looks like nice light, given its sub-40$ price point, could this be the best-brightest(not the thrower type) 2*AA light?
I don't know.
Haven't really tested it with 2cells against other multi cell lights yet..
I should probably take a look into it, when I have some spare time.
That would be great, take your time ;)!
Excellent review, thanks!
Just received mine from: andrew-amanda ebay store (Flashlight-Scope-Outdoors)
Sellers website: www.andrew-amanda.com#
Best price from US seller (less than Chinese sellers!) and arrived very fast (3 days!)
I also ordered a 3rd battery tube for operation with 3xAA.
Another Pro of this light is that it carries a 5-year warranty from Olight.
Considerably smaller than my Olight S20:
Although the head is exactly the same size:
Size comparison:
UltraFire C20 - Trustfire Z8 - Olight S20 - Xeno E03 - Olight S15 - SK68 - DQG Tiny 18650
The LED appears to have the same greenish tint as my old version S20, but I only compared them for a few seconds, I’ll need to do some more comparison since that issue was suppose to be resolved on the 2013 models in this series. (Supposedly there was an issue with the AR lens coating)
Also the 2013 S15 has a slightly better UI than the 2012 S20 in that it is much easier to activate the (much needed) electronic lockout feature. (Hold down switch for 2 seconds, as opposed to cycling through all the modes 3 times for the older version)
Thanks Olight for improving on this series. Now please exchange my 2012 version S20 for the 2013 model with improved switch, improved UI, higher output XML2, and better tint!!!
Same head size is a good thing. It means it can use the fantastic Xeno e03 wand, although you'll want to remove the clip if you're going to use the wand a lot.
Nice little light.. 3AA version might look a bit funny?
Anyway, enjoy your new light!
Interesting, thanks. I don’t believe I received a wand with my E03, I’ll have to look around. I never gave the wands much thought until you said this, I take it those make it useful as a “mini table lamp”?
Do you think the xeno wand is better than the Olight wand that is available for this? Although I’m not sure I’d want to keep taking the clip on and off.
Depends on how you look at it!
I’ve been wanting a 3 or 4 AA light for a “long” time, (no pun intended!) So now I can have that when I want and also a great EDC pocket light too. This is perfect for me that it can run on either Li-ion or primary’s, and convert to 3xAA for higher voltage with longer run time.
One of the reasons I like my Olight S20 and my Ultrafire C20 is because they can also run on 2xCR123 in a pinch.
Thanks.
I don't have the oLight wand, but I have the similar Nitecore and Nitecore knockoffs, along with some silicone diffusers.
The Xeno wand just does a really good job of providing even light output. Even when you look at the diffuser, you don't see a hotter spot like you do with other wands. It's kind of like a fluorescent tube in the way it glows evenly. If I was going to spend a lot of time in a tent, like often happens in winter camping trips, I'd want to a light that works with the Xeno wand so I can use it as a lamp for my tent.
Which reminds me of a ton of different diffusers I bought a long time ago to do a comparison between all of them.. there is definitely a huge difference in the way they work...
I didnt, and still don`t feel the urge to do the comparison... too much work ;)
Too bad you're in Tokyo. If you were in the USA, I'd be tempted to make an offer even though have most of those.
