I have a FandyFire UV-S5 and a CW SRK, the beam looks way better on my two, a lot better spill, I can’t believe how tight the hot spot is on the video, nothing like mine.
tabs
Well, I placed my first order with willbuying.com, after I had a chat with Mofei, owner. Ok, so I bought the XM-L2 HD2010 — a XM-L2 U3 (hope it is) and a new emitter that is a Chinese 15watt version of the MT series. Will use a 5 cree in series driver
I bought one, and it’s great. I have an updated skyray Kung too, and his L2 version is brighter. The color of the light is cooler white. This L2 version has a nice snug button… The updated one I have has a button with a lot of wiggle.
I got his HD2010 in the XM-L2, and it is very bright, and is a definite thrower. Changing different batteries, I have had it pull over 4 amps. I got the “grey” one, but it looks silver to me, nice torch, but — I talked him down 10% on my order, so I got it for like 28 dollars, but he whined and jumped the price up to like 36, after I bought mine. Still haven’t mess with the emitters, I bought. still waiting for the drive I bought from
18sixfifty hope icarus doesn’t come in the package :Sp
I been thinking of modding 4 SRKung heads for the high-beams on my SUV. ( one problem would be the cooling of them runing continously, and the voltage difference woudl need some kind of converter or new 12 volt drivers.
The Kung M4 i have is brighter than both the Halogens on high now.
My Kung is brighter than my HID headlights and HID fogs! Mostly because the Kung spotlights a much tighter beam. My car spreads out a much wider even light. Also, because my HIDs setup are 5000k fogs and 5000k headlights.
Its probably better if you just upgrad your halogens to HIDs. You can pick up a decent dual hi/low HID setup for $50. If you want really bright independent high beams, use high mount HID fog lights.
My low-beams are already 50 watt HIDs, ( only the high beams are still Halogens, but using the 100 Watt bulbs.) there is enough room in the Highbeam lens on a Avalanche 4x4 to hold 2 Skyray kungs in each one of them… i want the “instant-on” mode of the high beams to deterent those ignorant constant-high-beam drivers around here blinding all of us.
Fabricating Kungs into your housing would be a pretty big project. I would personally stick with your setup, an carry a Kung in the car with you to shine at highbeamers. That way, they wont think you’re just one of them… and you can hit them at any direction… and not just the ones in front of you.
I am thinking about getting the black one here. 4 x XM-L2 seems like the one to get. Anyone have this exact one that can comment on it? Is there another one (at approximate price) that is a better option? Thanks.
I bought one of these and will let you know how it works out once I get it. And by “you” I am referring to that one person on this forum that hasn’t bought a skyray king yet, but is contemplating it.
It used to be ” me and you”’ and now it’s just you.
