Anodizing isn’t a coating at all, but an acid bath with voltage applied to make the acid agitated and “cling” to the surface. A dye in the water/acid solution is what makes for the colors. So it’s not a coating at all, unless HAIII is not traditional anodizing.
Anodizing is considered a coating. The official U.S. Military term for anodizing, in fact, is "ANODIC COATINGS FOR ALUMINUM AND ALUMINUM ALLOYS" (As defined by MIL-A-8625)
Anodizing simply increases the thickness of the natural oxide layer that forms on Aluminum. The acid doesn't "cling" to anything. The dye is applied after anodizing is complete, but before sealing. Dyed (colored) Anodic Coatings are considered to be of "Class 2", while un-dyed natural color coatings are "Class 1".
Visually, it is near impossible to tell Type I, II and III apart. The significant difference is coating thickness, and that isn't something you can see. Type II coatings are between 0.00007 and 0.001 inches in thickness, whereas Type II coatings are between 0.0005 and 0.0045 inches in thickness.
I used to think so too. But then I got a SF L2 with type II ano, and it looked as nice and matte as a lot of type III lights that I have, so I can’t really say that anymore. Now, I would say that I could not tell the difference between type II and III just by looking at it.
I wouldn't consider that a definitive test either. Whether or not it changes color with heat will have more to do with the type of dye the anodizer used then it will the Type classification.
There are a lot of things that determine the type. Thickness, Weight, Process, Type of Acid, Rate of Growth, Current Density, Bath Temperature. The thickness is, however, one of the few observable/measurable qualities, and as such, is usually the confirming test for Type III.
Anodize of any type should not "rub off" very easily. You have to remove the aluminum oxide in order to remove the anodize - which is amazingly difficult to do.
What do you think could cause an anodized coating to fade with only exposure to skin oils and a couple showers? I have one which has lost quite a bit of its color (click for bigger versions):
This shade of turquoise is a relatively subtle color though, so look what happens if I change its hue by 60 degrees to show how the same fading would look in blue: (all I changed was hue, nothing else)
Was this even anodized at all? Could it have been anodized and dyed but not sealed? Any other ideas what would explain this?
Does this mean we can have white coloured anodized type 2 lights?
If this is possible, I want to request that every light from now on is white anodizing.
Anodizing dyes are technically not opaque - they are translucent. Because of this, white is pretty much impossible - it will always be tinted toward the color of the base material - in this case, grey.
