Correct. You can tell the difference between crap anodizing and good anodizing by looking at it (for the most part), but you can not tell the type.
You can torch it… if it turns orange relatively quickly, it’s type II, and if it doesn’t budge even after a few minutes, it’s HA-III.
I wouldn't consider that a definitive test either. Whether or not it changes color with heat will have more to do with the type of dye the anodizer used then it will the Type classification.
Haha, I see. I guess no lights would have to be baked to determine this.
Is it simply the thickness that determines the type of anodizing?
Coatings of moderate thickness 1.8 μm to 25 μm (0.00007” to 0.001”)[9] are known as Type II in North America, as named by MIL-A-8625, while coatings thicker than 25 μm (0.001”) are known as Type III, hardcoat, hard anodizing, or engineered anodizing.
However, the process does change between the two.
Source: Anodizing - Wikipedia
Haha, I see. I guess no lights would have to be baked to determine this. Is it simply the thickness that determines the type of anodizing?
Coatings of moderate thickness 1.8 μm to 25 μm (0.00007" to 0.001")[9] are known as Type II in North America, as named by MIL-A-8625, while coatings thicker than 25 μm (0.001") are known as Type III, hardcoat, hard anodizing, or engineered anodizing.
However, the process does change between the two. Source: Anodizing - Wikipedia
There are a lot of things that determine the type. Thickness, Weight, Process, Type of Acid, Rate of Growth, Current Density, Bath Temperature. The thickness is, however, one of the few observable/measurable qualities, and as such, is usually the confirming test for Type III.
Interesting, thanks.
I guess the only realistic way of measuring would be through experience.
For example, my grey SF L2N I think has type II anodizing because I already can see some rubbing off, although it’s only been on my desk.
Anodize of any type should not "rub off" very easily. You have to remove the aluminum oxide in order to remove the anodize - which is amazingly difficult to do.
Yeah, I meant to say that I’m seeing some patches of metal on the edges of the light.
Here’s a shot:
Interesting.. didnt know all that.
Whenever I see a light that doesn`t look like good quality anodizing, I usually just called it HA II (though now I now that it doesnt exist).
For me it was just guessing.. I thought there was something like: 1=paint, 2=shiny paint like substance 3=thick layer
but I stand corrected..
What do you think could cause an anodized coating to fade with only exposure to skin oils and a couple showers? I have one which has lost quite a bit of its color (click for bigger versions):
This shade of turquoise is a relatively subtle color though, so look what happens if I change its hue by 60 degrees to show how the same fading would look in blue: (all I changed was hue, nothing else)
Was this even anodized at all? Could it have been anodized and dyed but not sealed? Any other ideas what would explain this?
Seems like this is a complex issue. Pretty interesting discussion so far though.
Does this mean we can have white coloured anodized type 2 lights?
If this is possible, I want to request that every light from now on is white anodizing.
Anodizing dyes are technically not opaque - they are translucent. Because of this, white is pretty much impossible - it will always be tinted toward the color of the base material - in this case, grey.
PPtk
knee jerk, totally non expert, probably wrong first thought:
paint
What do you think could cause an anodized coating to fade with only exposure to skin oils and a couple showers? I have one which has lost quite a bit of its color (click for bigger versions): This shade of turquoise is a relatively subtle color though, so look what happens if I change its hue by 60 degrees to show how the same fading would look in blue: (all I changed was hue, nothing else) Was this even anodized at all? Could it have been anodized and dyed but not sealed? Any other ideas what would explain this?
That's a fine example of REALLY crappy anodizing...
Damn. Well if a white light ever comes out I’ll probably get that.
ChiX’s cerakoted lights come to mind.
ToyKeeper:What do you think could cause an anodized coating to fade with only exposure to skin oils and a couple showers? I have one which has lost quite a bit of its color (click for bigger versions): This shade of turquoise is a relatively subtle color though, so look what happens if I change its hue by 60 degrees to show how the same fading would look in blue: (all I changed was hue, nothing else) Was this even anodized at all? Could it have been anodized and dyed but not sealed? Any other ideas what would explain this?
knee jerk, totally non expert, probably wrong first thought: paint
Not an impossible theory.
Bort: ToyKeeper:What do you think could cause an anodized coating to fade with only exposure to skin oils and a couple showers? I have one which has lost quite a bit of its color (click for bigger versions): This shade of turquoise is a relatively subtle color though, so look what happens if I change its hue by 60 degrees to show how the same fading would look in blue: (all I changed was hue, nothing else) Was this even anodized at all? Could it have been anodized and dyed but not sealed? Any other ideas what would explain this?
:bigsmile:
You want the hardest most durable finish you can put on aluminum, and it happens to be white? Here you go..
http://www.whyco.com/images/Cerafuse_aluminum.pdf
I could try to explain how tough this stuff is, but I wouldn't succeed. You have to see it to believe it. It is absolutely unbelieveable.
Wow, from what I’m reading, it’s 3-4 times harder than HA-III anodizing?
