Xtar 18350 900mAh (Black)
Official specifications:
- Capacity: 900mAh
- Voltage: 3.7V 3.33Wh
- Size: ø18.0±0.2mm x 36.3±±0.5mm
This battery has slightly better capacity than specified.
The battery does very good up to 2A, at 3A the cells show variations.
Conclusion
The battery has good performance and at can match some IMR cells at 2A (It has more capacity and about same voltage).
I will only rate the battery as acceptable, because it uses an unknown cell.
Notes and links
Comparison to other LiIon batteries
