Test / Review: Sanyo UR18650ZTA 3000mAh (Magenta)
Official specifications:
  • Nominal Capacity: 3000mAh (0.2C, 2.75V discharge)
  • Minimum Capacity: 2900mAh(0.2C, 2.75V discharge)
  • Charging Voltage: 4.35 ±0.05 V
  • Nominal Voltage: 3.7V
  • Charging Method CC-CV (constant voltage with limited current)
  • Standard charge: 1450mA
  • Rapid charge: 2900mA
  • Standard charge: 3hours
  • Rapid charge: 2.5hours
  • Max. Charge Current: 2900mA(ambient temperature 25°C)
  • Max. Discharge Current: 5800mA(ambient temperature 25°C)
  • Discharge Cut-off Voltage: 2.75V
  • Cell Weight: 48.0g max
  • Cell Dimension: Height: 65.00mm max, Diameter: 18.25mm max,
  • Operating Temperature: Charge : 0 to 45°C, Discharge: -20 to 60°C
  • Storage Temperature: 1 year: -20~25°C, 3 months: 20~45°C, 1 month : -20~60°C
This battery is designed for 4.35 volt and need a special charger to get the full capacity.
Looking very careful on the shrink wrap, it is possible to see the battery type.
I am not very impressed with the capacity, but the voltage is high compared to 4.2 volt batteries.
Test at 4.3 volt charge
Reducing the charge voltage to 4.3 volt, looses about 120mAh in capacity.
Test at 4.2 volt charge
At 4.2 volt, the capacity is down with about 360mAh and the voltage advantage is gone.
Conclusion
Being a Sanyo battery it is very good, but I wonder about the low capacity, it might be due to age (If I read the datacode correct the battery is from 2010).
Notes and links
Thanks for the review HKJ. I was curious about these cells.
I like the UR18650ZT cells. These ZTAs offer no capacity advantage and the voltage advantage is already there in the ZT.
The capacity surprised me, but if it really is from 2010 then I guess it’s expected.
Haven’t seen a 4.35 volt cell before so thanks, this was interesting!
Thanks a lot for the review! Frontpage’d and Sticky’d.
I just finished testing 1 year old laptop battery with cells also 1 year old:
2456mAh from 4,2V
Result is obvious: These batteries are overrated.
Not bad, you got more capacity than I got in this test.
