I paid $2.82 on ebay.
Thanks, fran! Seems like a useful device for my Soshine SC-F3 and other USB devices. I know from my ammeter the Soshine pulses over 1A during charge but would like to see draw at the USB point rather than measuring in circuit with the cell using a DMM.
Ordered one from him, thanks :)
Looks like the r050 is the currentsensing resistor, so there should only 0.05*2.5=0.125 voltage drop. That’s not too bad…I ordered one to test it.
I ordered three. I figured as soon as a couple of friends see it, they’ll ask me to order them one anyway.
I received mine yesterday, will post some pics tomorrow. It is a nice little device.
Thanks Chloe
Mine shipped last week, I will not have it until 2 weeks….
More info will be apreciated
I ordered mine on the 15th. Hopefully I'll be getting it soon..
Getting me one of these, you can still preorder http://www.kickstarter.com/projects/david-toledo/the-practical-meter-know-your-power
It is quite small but for some devices it can get in the way of other ports and plugs. There are small clips which are quite fragile but you can remove the case if you are careful:
Here you can see it just fits with the case removed:
With a device connected it alternates between showing current draw for approx 7 seconds then voltage for 3 seconds.
PCB:
You take some incredible photos Chloe, thanks for sharing!
Thank you, Ryan!
I can see that Chloe got the nice version, mine is not very nice in soldering:
Nice video.
I have not really tested it, but it does show 5 volt (I picked it up yesterday).
Thanks, HKJ! I got mine from Ebay.
It does look cute. Blue LEDs can be a bit too bright though. I like that the arrangement doesn’t block other ports.
Thanks for the video.
Looks a bit weird with the changing amperage…
Same here, and the photo on the dealers page shows the version you have.
It is the same schematic for the two, but mine looks like an earlier version. Yours version is optimized a bit: All parts are smd and the printing on the pcb is removed.
Probably because the charger has a pulsing current draw.
