That is a nice way you are going, I really like these explorations :-)
I am not sure that 3 XM-l's in a SRK sized light will out-throw a MT-G2 in a single-reflector light of the diameter of the SRK. I will have to calculate that (or has someone a ready proven answer?) but my feeling says that it will not be that far off. Also the price of three XM-L's are close to one MT-G2.
A concern that may not be a real world problem: I found in my weird but fun handbuild 9V light that two leds of different tint, even if almost on top of each other, will give funny shadow effects because the light of the different colour come from a slightly different angle. Does this happen to these lights as well (reflectors will make this effect less, but the leds are further apart than in my build).
The MT-G2 needs much deeper reflector in order to "throw". It will not throw much at if its in a similar sized (with and depth) reflector as SRK triple.
Lets take a look at the SRK@32W vs MT-G2 in much deeper and larger reflector (ZY-T13) @ about 21W.
SRK, modded to 3A+ to the emitters and NW XM-L2 (80+ CRI). About 32 Watt - mouse out
ZY-T13 MT-G2 @ 3,29A. About 21 watt- mouse over
Let compare with pictures from this thread (pictures have different exposure and WB, which is the reason why I do not take SKR de-domed vs ZY-T13 with MT-G2)
SRK, modded to 3A+ to the emitters and NW XM-L2 (80+ CRI). About 32 Watt - mouse out (same light as the mouse out in the previous shot)
SRK, stock 2,3A to the emitters, 3 de-domed CW XM-L (T6). About 22-23Watt? Mouse over
I think its quite clear that the 3/3 de-domed XM-Ls in a SRK reflector will EASILY out throw an MT-G2 in much larger an deeper reflector. So should 2/3.
1/3 XM-Ls de-domed will probably do the trick as well. At least be somewhat similar. Again, the XM-Ls are in a smaller reflector. And Im not even putting (de-domed) XP-G2s in the equation if throw is the goal.
Relic38 answered a question for me here. Ill quite him since he have the numbers.
His MT-G2 light uses more energy, about 34W vs 28,5W for the SRK, it has a slightly wider reflector, it has a much deeper reflector, and none of his XM-L emitters are de-domed....
I think this backs up what I said above. 2/3 de-domed XM-L2s will easily out throw an MT-G2 despite sitting in a smaller reflector. And you can still save the tint/CRI and maintain output that are probably slightly higher than an MT-G2, if not pretty equal. If you want less throw. 1/3 de-domed.. The flexibility is great!
______________
[quote=djozz]
[/quote]
I think I have noticed what you describe when holding two lights side by side. When emitters are combined in the same (SRK) reflector, I have not experienced the effect.
I hope others will share their experiences in this thread when it comes to mixing emitters in similar ways as I described in OP.
Although I agree with everything said by the OP, I think it is a bit unfair to pass judgement on the MT-G2 just yet. Folks have been experimenting with xml's way longer than with MT-G2's. It's just a baby. Give it a chance to mature.
Additionally, dedoming the MTG2 creates a whole new beast. Just look at the reduction in surface area from that huge dome to the crystals underneath. It's something you have to see in action first hand to appreciate. The only 2 people that seem to have spoken about successful MTG2 dedomes so far are myself and Ohaya. And, we have barely done anything yet.
I must qualify what I call a dedome in my case. I do leave scraps of silicone right over the crystals as I don't want to remove any of the phosphor layer. I hope we figure out how to completely remove all the silicone without phosphor loss. I haven't attempted that step yet.
I'm not trying to take anything away from RaceR86's work or statements. I think it his work is awesome and I agree with his arguments about the strengths and weakness of the xml's vs mtg2's, as we currently understand the mtg2. It is looking like mtg2's may be best used in only big reflector lights with lots of battery capacity. We may end up finding out that in that situation, the xml may be the inferior thrower.
EDIT: I just wanted to say I don't want to derail this thread into a xml vs mtg2 debate. Lets get into what the heart of the experiments in the shown in the OP. This fantastic thing with mixing emitters of different types, bins, tints, cri, and dome status. It appears that great results can be realized. I agree with the OP that these multi emitters are more than floody enough most of the time. What a great way to customize one's light on so many different levels. This is going to be great!
My experience so far has been limited to mixing tints and bins in 3 different lights. In each case I used 2 emitters of one tint and 1 different emitter of a different tint. Like the OP, I have found that the overall beam is impacted and quite uniformly. Only the outer clover leaf edges of the beam look different. I don't find this part of the beam very useful. I only really see the outer edges on white walls.
In the first 2 lights, I found the one warmer emitter over powered by the other 2. In my last light, I used 2 warmer emitters and one higher bin cooler, but still warm emitter. It was better, but still the one lost. So it looks like I need drivers that power the emitters separately to get a better balance.
I'm looking forward to getting more throw out of my multi emitters. Thank you very much for the work you have shown us RaceR86.
ImA4Wheelr, my goal was not to pass judgement on the MT-G2. I just wanted to compare the triple-emitters against it because I would consider it the "rival" in many cases. Thereby seeing some interesting discussion around the topic. :)
I just wanted to put some focus on the possibilities of emitter mixing in ways I have not seen done before.
As a "modder" my goal is always to try and see what kind of beams I can suqeeze out of a certain form factor. And this combination of emitter mixing can certainly improve many multi-emitter lights, depending on what type of beam you want. And that beam can be quite similar to an MT-G2.
I think its more beneficial/easier to just combine more similar emitters in order to get a better "balance" than to play with current. Whatever people do, its interesting to hear about the results, or thoughs. :)
[quote=Nightbird95]
Thanx for sharing these RaceR86. This makes me want to mod my SRK though I'm still finding it hard to remove its bezel. :) Has anyone tried this on the BTU Shocker yet? :~
[/quote]
Tom E have done de-domed emitters in a BTU shocker, many people does de-domed emitters in various lights. I have never seen any talk about neutralizing the color tone though. When I say color tone, I am not talking about Kelvin/the warmth in the light. I am mainly talking about the color of the light.
Thanks RaceR86. Sorry, didn't mean to put words in your mouth. I should not post late at night. I get sloppier than I normally am.
I'm a bit defensive about the MTG2 as I have a soft spot for it. The first light I put one in pulled 250kcd. It out threw everything I had in a big way. I couldn't understand how people thought the emitter could not throw when it devastated everything I had after putting it in a $25 plastic light.
Then I got a TN31 and it out threw the TN too. Then I modded the TN and now the TN out throws my first MTG2. But, I have plans to change that. Again, sorry for having a chip on my shoulder. It's in my pocket now.
So, I am psyched about what you've reported. Yeah, people have been mentioning ideas of various mixes here and there, but it hit home for me seeing and hearing what you did in reality. I have to tell you. I had set plans for all my multi-emitters. This thread has me looking at them in a totally new light. I've decided to scratch those plans and think about what I really want those lights to do.
[/quote]
Im glad to hear that and I look forward forward to hear what you come up with and how you like them. :)
Lets compare the two SRK with mixed emitters vs a few other NW emitters.
-On the top, representing the green-ish tint. De-domed XM-L2. Supposedly U2 1A. But I got this from KD. Im guessing it was T6 1C, if not a B.
-XM-L2 3B from FT
-XM-L2 4C from FT
-XM-L2 3A from intl-outdoor
-Info on the lights with mixed emitters in OP.
Looking away from that my 3A and 3B looks extremely similar to each other. I think its quite obvious that the emitter mixing worked its charm! Even when being 30cm from a white wall, there is not much signs of the various colors in the lights with mixed emitters. The XM-L light used to have a fairly green-ish hue. A bit like the de-domed XM-L2. Look at in now! :)
Too much greenish/yellowish tint. No problem neutralize the hue by adding an emitter with more red tones. :)
So, what do you guys and gals think? I know, photos are not the best way of comparing various tints, but I think this shows the differences in the various colors fairly good.
Very nice comparative beam shot photo. Was all that taken in one shot?
The tint improvement is impressive and consistant with my mixes as far as how the whole beam's tint is changed. When I aim a SRK type light at a wall, I get 3 faint clovers on the outside of the beam. Those are generally to tint of the nearest emitter. I don't see those in your photo. It may be the way the lights are oriented. I think I see some thing that may be clovers on both sides of the 3A beam. Since the light are aimed away, the other clovers would be way to dispersed and faint to see in the photo. Is that what is happening here?
Yes, all lights on at the same time and taken in one shot. All pointed at a proper white cinema screen.
The angle and and especially the slight overlapping with the other beams is minimizing the "clover" effect on the SRK/M6. Outer edge of the spill does not look that round and nice when pointed straight on a wall.
btw, the tint of a specific emitter is seen on the opposite of where it is placed in the reflector. In real life use im not able to spot it..
You're right. I misspoke. The lowest point for light to spill out is either the short walls in the center of the reflector or the distant walls on the far side of the reflector (No sure which one ends up actually cutting off the outside of the clover spill). So clover spill is on the opposite side of the emitter placement.
Interesting, and nice work for the picture! I can see the difference in color around the edge of the mixed emitters, but if you are outside/moving and not shining on a white wall I dont think you’d be able to tell much. Is the greenish dedomed XML2 that green in real life? I have a mixed multi-emitter with dedomed T6 and its more “neutral” definitely not green…do dedomed XML2s come out “green” typically? I’d heard dedomed color isnt really different depending on which color emitter you start with to dedome (CW, NW, WW), but this seems to say otherwise unless XML2s go “green” or the color is “off” in the picture…
I’ve actually found I like to vary color tones now, I get tired of CW and its too reflective bright in some circumstances, but after using a NW on the yellowish side I really liked that tint, and then started using a warm white and really loved using that for a while, ran out of power in my warm white and found I like CW again more…its interesting, I seem to get “bored” of one color tint, but I’m really liking warm white’s reduction in night vision recovery time.
I’ve been experimenting with this on my bike, of all things, with two S5 Convoys. One has a 1B and the other has a 5C1 emitter. As I change relative settings I can mix the colors together in different intensities. Kinda cool, or warm, or anywhere in between.
De-domed CW emitters that leans towards the green/yellow side of CW emitters, like 1B and 1C will get much more of a green/yellow tint after de-doming than the ones with more red tint. I have not noticed any difference between XM-L and XM-L2. It depends on the tint you start with.
Yes, the outcome after de-doming will depend on what you start with. Normally you can subtract about 1300-2200 Kelvin, and add more green/yellow, atleast when de-doming CW/NW. If you are de-doming WW you will end up with very WW. So yes, there is a large difference between all the various emitters. Generally, you would like to add red tones, like I have done with my two lights in this thread. That fixes the tint and makes it more white.
In real life, the eyes adapts to colors, to some extent. So if you walk around in the nature with a de-domed CW XM-L, it will not look that bad, because it renders trees and everything fairly green. And green nature doesn't look that bad. :p
If you're eyes are adapted to nice NW light with a dose of red in it, then the de-domed CW XM-L (especially 1C and 1D) will easily look as green as above. Then it looks like :Sp
I have seen worse green than the above too. When looking at the picture, most colors are more visible. But it nicely portrays the green-ish tint compared to the others, which have more white light.
I prefer to start with 1A or 1D before de-doming. But even then, its far from great.. Which is why i "fixed" the tint by adding a more red emitter.
Im a bit like you when it comes to tint. I need change... Which is why I have a lot to choose from...
BTW, the two lights in this thread are in a large beamshot comparison with other lights here.
I kinda started like that. Most times I bring two lights with me for comparison, sometimes 3 or 4. I often try a bit of mixing. If I only bring two lights, and use a bit both of them a bit, I usually prefer the combination of them.. :p
The dedomed T6s I have went yellowish, maybe a bit of brown. Have you dedomed a warm white, like say T4-7C and if so what did you get?
And no green in nature is not bad, but when you are hiking in the green forest at night, adding green to the green is probably going to be an overabundance of green…which is why I didnt really like the idea previously. Its probably kind of neat to have in a city like setting.
