I’m sitting here at work, waiting very impatiently to get home and play with this Shocker Tom E modded for me. I have a sucky point and shoot camera, but I might try to figure out how to take some comparison shots with my other throwers (TN31, TK70, Flexcandles Asgard). Unfortunately, I do not have a lux meter, so I can’t do any lux testing either
I will, however, be happy to test the current at the switch with some different batteries. I have the Samsung INR18650-20R batteries which have a rated max discharge of 22 amps. I also have some NCR18650PD’s on the way, but they probably won’t be here for a week or two. I will try and post as much info as I can.
A big thanks to Tom E for modding this light for me! I absolutely cannot wait to get home and play with this thing.
A tip from the CPU heatsink lapping savants: Go to a local glass shop and ask if you can have a piece of thick (5/8” to 1”) scrap glass. It is the flattest, hardest, least flexible surface you will find and is about as good as it gets for making sure your lapping is completely uniform and flat. If you want a mirror finish after using sandpaper, you can polish it with some 3M rubbing compound.
There’s no way I’d ever be precise enough to get three emitters perfectly aligned in the reflector holes while soldering them down. I’m sure it can be done, just not by me.
Updated OP with maybe some info that might answer this - bottom line is not very long... . You don't want to go out for a stroll with this thing on high. Of course your arm would tire, you'd drop the head down, then go blind from the reflected light off the ground... Or, you would get that warm, cozy feeling working it's way up your fingers, and figure you'd better drop it to medium or low, rather than just dropping it before that funny smell you are noticing... burning skin... Medium mode though is 2,000 lumens - gotta love this thing!
Agree - Pana PD's are a nice compromise, but even on KP 3400's, it's an incredibly powerful light that would get at least some runtime. We kind of reached the limits on this form factor of 3 LED's, 3 18650 cells. This just kind of proves what's possible, not necessarily practical.
that’s boss! i knew you had something up your sleeve tom! looks like you perfected the shocker.
now im glad that my shocker was on your queue and not one of your earlier shockers. but your earlier shockers were no slouch either, its just that put polishing touches to the already madness.
I'm no expert at focusing, but it looked pretty good to me as is, with the stock plastic alignment pieces - beam pattern has the usual clover effect on the outer edges of the spill and center beam, but I see the same thing stock. I heard they needed focus adjustments but I don't see the need - no dark spots, throw and output seem appropriate, etc.
I'm thinking yes, perhaps... I assume you mean measuring distance, and 8-15 meters would probably be better. It's scary - also the #'s would be better with Samsung 20R's - maybe test this evening...
