Aww, thats no good, J-19 with 3xMTG2 cant fail! You did save me having to buy it off you for now though, and having to explain a large flashlight purchase…
It has to be from the driver itself. It’s not on long enough to get hot from the emitters. The heat doesn’t even get a chance to build up before it drops down. The thing that got me about the 7x driver was that it didn’t drop down and instead just burnt out. I didn’t expect that at all. This is the third one of these drivers that I have used and the other two dropped down with no problem at all. Well other than dropping down quicker than I would like them to. So far the best build I have done with one is a 6xU3 that light is just unreal bright and it runs on that driver really well.
Do you know if there is any difference between the 7x and the 9x drivers from Kaidomain? They seem like they are all the same to me.
Yep it’s a bummer but I was afraid it might turn out this way. These MT-G2’s pull so much power it’s unreal. I don’t know the numbers or even how it breaks down but the XM-L2’s seem to be more efficient to me.
I don’t know about efficiency but in the same reflector light the MTG is an absolute flood of light compared to a skinny little beam from the XML-2 not that we would of said that six months ago. In throw the XML-2 is in its own league.
My guess on the thermal protection is an integrated temperature sensor in the MCU. Most small MCUs made in the last 8-10 years include one. In most cases not overly accurate, but good enough to protect from overheating.
I guess in some cases, the driver designer went a little cautions on the cutoff temperature.
The LusteFire driver doesn’t appear to have any intentional thermal cutoff, although I figure catastrophic ‘cutoff’ would occur if left on for too long with no cooling. I’m not sure if that driver is available from anywhere on it’s own. Would be interesting if it was, or was requested through a certain popular online store
Living with the step-down may be your only option until a driver can be sourced. There’s are not many drivers available that can deliver a sustained 50-70W of power.
It’s a shame but I don’t see any good options, so I think I’m just going to pull it back apart. Too bad the 7x driver burnt out it was a thing a beauty while it lasted. What gets me is that although it was bright it still wasn’t as bright as my 6xU3 and it runs fine on the same driver. I wonder if the driver itself had a defect and that’s why it didn’t drop down or possibly something else wrong with it altogether.
Well does anyone need a 9amp driver? I have one to sell you cheap.
Three h6flex Taskled drivers, Master/Slave, set at 6600mA per led. I'm considering it. I talked to George about it. It's feasible, but it might be too much for the Master at 6600mA each, It should be good at 5000mA each.
Someday when I got $125 to buy drivers, but I bet it would be a kickass light!
There’s got to be a driver to do it, if it didnt get hot then it wasn’t to do with heat, either too much current or a pre-broken driver, and it kinda sounded like a faulty driver to me if it didnt even get as bright as that other light even for a little bit. They should easily do 2k lumens each…
You would think that there must be one someplace, but the problem is that choices are limited due to size as well. I really thought the 7x driver was going to do it. Oh well someone will find a driver one of these days and I’ll revisit this build when they do.
I already pulled it apart and mounted 3 new XM-L2 U2’s on noctigons I didn’t dedome these so it will be floodier kinda like a shocker on roids. It’s getting driven very hard with a low PM driver. It will outflood and outthrow a stock shocker easy.
My driver that does the advertised 9 amps on the left, and 18sixfifty's driver on the right which only does 5.6 amps no matter how many cells you throw at it.
Anyone spot the problem? :facepalm:
One thing I did figure out while running them out in the open, the heat is coming from the FET and/or other stuff on the topside of the upper board, under the choke/inductor/whatever. The part that has zero connection to anything that could keep it cool(ish)...
I honestly don’t have a clue how these things work so you would have to point it out to me. Although from the picture it looks like you stacked resistors or did they do that?
I haven't touched the resistors on either one. There are 3 more pads for more resistors directly opposite those, and both drivers have 3 R200s there. So one has 9 resistors and the other only 6.
