Those are some insane numbers, competitive to 60-85w HID in both lumen and throw. Who still want a HID NOW?
I did not fond the larger form factor of shocker. But I should think about it again……
I dedomed its three XM-L2 T6 1Bs then re-installed it back to the shocker. I replaced its AWG 22 silicon wires with a new set of the same wires because the silicon protection of the lead wires also dissolved in gasoline. :~
I used the same stock BTU Shocker driver which gives a tail cap reading of 3.35 Amps at 12.04 volts. I then turned the flashlight on and TomE was right - the same flowery spill with a little tighter hot spot. The only difference is that the beam is already neutral white and 3 dark spots are still eminent in the hotspot at 2 meters. Lux readings at 3 meters might not give good results. :~
I took the lux reading at 6 meters and the result was 5341 lux which is equal to 192 KCD at 1 meter, a 44% increase over the 133 KCD stock readings.
My Shocker now beats my modified T-08 in throw and I’m loving this light even more. Thank you very much for the tips TomE!
Hhmm, 3 dark spots at 2 meters. Hhmm. Didn't notice that - I'll re-check this evening. Tailcap amps remained the same? I'm thinking you should have gotten double the kcd, or close to double, because I'm thinking that's what I'm seeing, but my amps are way higher, and using U2's.
Its not that dark, just not as bright as the edges. Its more like 3 doughnuts that did not converge fully yet.
I did not get the tail cap readings again because I did not do anything to the BTU driver. I just assumed that its the same 3.35 Amps like when the LEDs were not yet dedomed. :~
Or am I missing something? Does dedoming the LEDs change the tail cap current? :~
Ummm, gotta get it shipped out, probably tonight package it up, and got softball at 6pm, and, I'm not really set up so good for outdoor shots - didn't get around to mounting lights reliably, and no decent place to go I know of, small backyard, fences everywhere - I'd shock the neighbors for sure at the house.
I’m really wishing I would have nabbed one of those K40’s…… really starting to regret not doing it especially now that a certain someone has something they are mailing me soon…. 0:) I have a few good spots for some beam shots but nothing even remotely close for comparison other than a stock BTU….
I'm looking at my K40 now. Can't believe it, but they broke off one of the screws to hold down the PCMCB and used epoxy to cover it up, so on one side, a screw secures it down, on the other side, epoxy was used just to cover the hole. I'm gonna pull the emitter off and reflow it - looks like it's not straight, so maybe it was a bad reflow as well, yikes... Probably will have to re-tap the hole - cleared it out by drilling out the pices, tried the other screw and it won't tighten up - I know the bit I used was smaller than the hole, but who knows - maybe they used a bigger screw and that's why it broke.
Tom, that’s really messed up for a torch of that $$$. That is something one would expect from a cheapo brand/model but certainly not something in that range.
That is exactly what I was thinking when I read it as I have done that exact thing (not with a torch have you) a couple times and not realized it until the “oh s**t” moment. Got to love the “what do we do now?…. ahh screw it, just glue it…. not like anyone will open this thing up anyhow!”
A closer examination earlier revealed that the reflector was not properly seated over the LEDs. I placed layers of kapton tape over the copper stars to ensure that the reflector won’t short with the lead wires. The result is that my centering rings cannot be fitted properly over the LEDs because the tape was too thick. I removed the excess tape leaving a single layer over the lead wires allowing the centering rings to fit properly and the reflector to be properly seated over the LEDs.
Upon testing its beam, the dark spots were already gone. The misalignment and improper seating was the culprit of my ugly beam earlier.
I also took its lux readings at 6 meters and the average is 6265 lux which is equivalent to 225 KCD. A 17% increase over the improperly seated/aligned reflector and a 69% increase over the stock light. :bigsmile:
Sorry I don’t understand something here, you got 225kcd after dedoming the LEDs, the lux numbers seems a bit low for a dedomed XM-L2 BTU Shocker…
Tom E got around 180kcd by just simply swapped the LEDs into XM-L2 on Sinkpad with stock BTU driver. Or is it you did not mount your LEDs on Sinkpad/Noctigon?
Well that’s what I got after swapping my stock XM-L LEDS with dedomed XM-L2 T6 1Bs on ordinary copper MCPCBs. I did not use Noctigon or Sinkpads, just ordinary copper MCPCB. I ordered my XM-L2 T6 1Bs from Simon Mao and my copper MCPCBs from LED-DNA.
The lux readings of my stock Shocker (XM-L) was only 2690 at 6 meters or 133 KCD. It increased to 3870 lux at 6 meters or 192 KCD when I swapped dedomed 3 XM-L2 T6 1Bs on copper MCPCBs in it. It further increased to 4540 lux at 6 meters or 225 KCD after realigning and re-seating the reflector properly over the LEDs.
