Have anybody a Trustfire P7-F1 ?
I want to know the deep of the reflector and found nothing about it.
I will chanche the LED to a XML and will use THIS reflector.
Will it fit ?
Will it fit ?
OK, now i will use THIS Host, because SST-50 Reflector is ~6mm deeper.
In this Host a adaptation of a SST-50 Reflector and a XML should be easier ;)
I have one of those. I remember a rather jaded colleague who's seen most of my new lights saying; "That's bright". And that was with a P7 in it - measured at 434 lumens at switch-on. Mine says it's an Aurora AK-P7 - another C2/C8 body light.
Aurora AK-P7 was other option, but the pill of the Aurora is little bit other.....more difficult to install the SST-50 reflector.
The pill of the Trustfire is much longer and i maybe can easy remove 6mm.
