Sibeile IMR18650 2600mAh (Black)
Official specifications:
- Sizes: Length: 65.99 mm Diamter: 18.13 mm, weight: 30g
- Voltage: 3.7v
- Full Charge voltage: 4.2V
- discharge cut-off voltage: 3.0V
- capacity: 2600mAh
- internal resistance: 80mOhm
- max charge current: 1C
- max discharge current: 3C
- Top: flat
- Dishcarge temperature range:-10Ā°Cā60Ā°C
- carge temperature range: 0Ā°Cā40Ā°C
- storage temperature range: 1 year:-20Ā°Cā25Ā°C, 3 months:-20Ā°Cā45Ā°C, 1 month:-20Ā°Cā60Ā°C
After shipping the samples to me, some print was added to the box.
Very good match between the two cells, capacity does also match with specification.
Conclusion
These cells has good performance for 2600mAh cells, with nearly constant capacity, but I doubt the IMR rating.
As usual with good unspecified cells, the rating can only be acceptable.
Notes and links
The batteries was supplied by Sibeile for review.
