Using my DIY bench power supply and DIY driver with 15x7135 I’m now getting 5.04A!
Placed the driver on a P60 pill and modified VBat- connection. I still need to improve my driver to emitter wirings similar to HKJ.
I had the same problem with my Nanjg drivers on my Convoy C8. The increase in tail cap current seem to be diminishing every time I add a new 7135. I wanted to ask the same question here in this thread but decided that I should seek the solution myself.
Yesterday, I made a new set of lead wires for my DMM, copying what many here in BLF did in getting the current readings of their flashlights. I used about a foot long (per color) of AWG 16 Automotive Wires, 2 Banana Plugs and 2 Alligator Clamps. When I used it to get the current readings, I was astonished with the results:
1) The LED current reading of my K40 (with 4 R100s added in parallel) became 5060 mA when the highest I could get using the stock lead wires of my DMM was only 3040 mA;
2) The LED current reading of my Small Sun T08 (direct-wired) became 5377 mA (yes, higher than my K40 which explains why it has a brighter beam) from the 2912 mA reading using stock lead wires;
3) The tail cap current reading of my Convoy C8 (with 12x 7135s) became 4169 mA from the 3012 mA reading using stock lead wires.
+1 x 10
I have a Skyray Kung 4 xml’s that I modded using 4-2800ma amc7135 boards for a total of 32 amc7135 ic’s. The tail cap reading with stock leads from a fluke 87V was about 6 amps. Changed the fluke leads to some short 16AWG silicone wire with banana plugs soldered in. I get a reading of 9+ amps now with partially charged batteries. Hoping for at least 10amps fully charged. So yes the leads size and length can make a huge difference in correct tail cap readings even if they are quality leads.
Are you all talking about the leads from my bench supply to the driver? For the positive, I’m using some short (about 12”) lead that I made using 20AWG stranded wire, connecting the power supply to the positive of the driver. I am using a switch on the negative lead, so for the negative, I have power supply => a tailcap switch => the negative ring of the driver.
I’ll try to cut down/improve the path on negative lead, and see if that makes a difference, but the reason I have the switch on there is that I had trouble getting the driver to switch to high mode.
Great work everyone with the stacking! I like the idea with the solid copper wire, will have to try it.
I will look into moving the pics from Photobucket, I think I am hitting my monthly limit.
Another thing I have noticed. 33/67 solder forms bridges much better than 40/60 solder. In the several times that I have tried both types, the former always seems to make things easier. I did everything in the OP with 40/60, but use only 33/67 now.
What I do to eliminate the switch resistance is after going to high mode, I bypass the switch using short AWG12 jumper.
Big difference in current/LED brightness!
One thing I found also is the multi-meter/probe resistance also affects the reading. By-passing the meter and using extra-polation I gained additional 200mA! I’m getting 5.2A on 15x7135.
I’m referring to the test lead wires of the DMM. I’m posting the picture of what I did:
Attached to my DMM are the test leads I made yesterday. They’re made of 1 foot long (per color) AWG 16 Automotive Wires, Alligator Clips and Banana Plugs (soldered directly to the AWG 16 wires). The pair at the left of my DMM are the stock test leads that came with it.
I have a slightly different setup. I don’t use a DMM (except for verification.
I am using a bench power supply, so I’m reading the current to the driver from the power supply display itself. For the emitter current, I have clamp meter, so no resistance on the driver-to-emitter side.
Anyway, I don’t think it’s my leads.
I tried another identical board, with original 8x7135s, and measured 3 amps (at the power supply).
I then added 2 7135s and measured 3.7 amps at the power supply.
I’m out of 7135s so I can’t add anymore. I tried harvesting one from the earlier driver, but I lost it (literally) somewhere.
I have some more coming in from FT. but those probably won’t come in until some time next week. I can try to harvest some more from the earlier board, but I’m kind of beat for now.
Easiest way I’ve learned to desolder chips is to cover all 3 pins with solder and when you melt that they all soften together then slide the chip off the boards.
No bibihang. I bought my AWG 16 wires from a local store. The banana plugs I used was from old test lead wires. Banana plugs are the the ends of your test lead wires that you insert into the DMM slots.
Sorry, I forgot to mention that both the earlier and 2nd board were 3.04A boards from IS, so they had 8x7135 (380mA versions).
The 2 7135s that that I added to the 2nd board were the 350mA 7135s.
I ran out of the 380mA 7135s earlier (and now ran out of the 350mA ones also).
EDIT: I started harvesting 7135s from the 1st board, and got the 2nd one up to 4 amps (from the bench supply), and only left it on for a second or so, but then later, when I tried to power the driver+emitter up, it doesn’t work anymore :(.
Something I’ve been wondering about. I’ve been reading how everyone keeps getting higher current reading from their DMMs by upgrading to shorter, thicker wire. Wouldn’t the truest reading of your drivers output be if you were using leads of the exact same gauge as those on the driver and emitter wires?
Ouchy, see this related post.
Testing using the best possible setup will give you an idea on what current your driver can deliver. If you’re not getting the expected current then it must be something else (battery, switch, wires, heat …).
So, I’ve visually inspected the board very carefully, both top and bottom, and I don’t see anything wrong. No solder bridges, no missing joints. Everything looked ok.
Putting the driver on the power supply, I am measure correct voltage when measuring voltage across the negative ring on the spring side and the + on the board.
When I apply power, and measure across the emitter, it’s showing like 0 - 0.02V.
The driver board appears to be dead, but I’m not sure what else to check?
Need pics to spot a problem. Otherwise can only assume toast. If the mcu is fried you can jumper from led+ to any Vdd pin and have a single mode regulated (high) board.
