EA4 didn't survive labor day weekend!
your theory is very logical explanation.
well certainly you can troll and having good knowledge at the same time :smiley:
Perhaps it would help to seal the light in a zip-lock bag while it’s cooling down? Then no or at least minimal humid air would be present to do it’s dastardly deed.
A plastic bottle with o-ring seal that is large enough to hold the light will make a good travel canister, a silipak for absorbing moisture would also be a good idea, placed inside the bag or canister to aid in pulling ambient moisture from the sealed container. Simple enough to do under extreme conditions to help guarantee the light.
Hmm, would like to read some research done on this, never tried to use light for that much time outdoors in bad weather, so Im curious whether it matters or not what kind of light you bring outdoors!
Would drying it first, then opening it to release hot gas and allow cool gas to equalise pressure for a few minutes possibly diffuse this issue ?
Sounds like something a bridge dwelling troll could test :wink:
It’s how you keep condensation out of a multi-thousand dollar camera lens in a temperature transitional situation. How is it any different? Believe me, a $2,000 12” long 3” diameter lens that’s been in the direct sunlight for hours can seriously pull some humidity out of an air conditioned room! Exactly what sports shooters do with $12,000 lenses. Just wondering why you think a $30 flashlight is so special?
Hot aluminum and hot glass in a damp cool environment, with sophisticated electronics (my Image Stabilization system is more than $500 by itself), looks like a very similar situation to me!
Yeah, think so. Drop the light in a zip-lock bag, squeeze out excess air, leave it to cool. I’m betting you’ll see problem solved.
this phenomena can be observed with half empty mineral water bottle (or just any other plastic water bottle).
when the half empty bottle is stored in room temperature (25 celcius or higher), it can creates fog by itself inside the bottle on the dry surface part eventhough the bottle cap is tightened. be sure it is water tight because otherwise there will be leakage everywhere when carrying.
im not surprised… nitecore makes crap.
:slight_smile: need some coffee now, but the laughter is a good way to wake up!
Sorry, I did read all of it but must not be awake enough to interpret what I’m reading. Have no recollection of your post, but remember the ones before and after. Sucks getting old! :stuck_out_tongue:
Kreisler is probably right. Even my watch (movado automatic) did not survive steam when I have to wear suit in hot weather.
My G-Shock has never had issues with going into sauna and into either not-so-warm shower or outdoors afterwards.
I will test it the same way this winter, Im sure it will survive without any ill effects!
My 12xT6, Xiaozhi, 3T6 and Warrior recently spent a few days in the exact same conditions (moisture/wet tent, night rain, condensation inside the tent, and all were heated up a lot before bed) and all survived with flying colors! Now dont ask me why I needed so many high powered bright lights when there were only two of us most of the time! I withstood lots of similar questions/female complaints on my lights and extra batteries and “reasoned” in my “defense” it was because my dogs also each needed a light. :smiley:
I wonder if the damp iPhone trick would be a cheap easy way to avoid this problem. Stash it overnight in a zip lock bag with rice. Cheap and easily acquired desiccant with the added bonus of being an extra food source.
I wear g-shock because I don’t take off my watch, ever, except to clean it with a toothbrush, or to do some settings or something before putting it back on, that means all bathing and showering, swimming, desert, mountain conditions, weather, everything, and I have never had a problem with g-shocks.
Several weeks ago we were in the Peruvian Amazon and ran 3 cheap Costco headlights, a Convoy S2, and a Zebralight sc52 for about an hour continuously in the evenings. We didn’t have condensation problems with any of them. It’s fairly humid and the temperatures were in the low to high 60s (just guessing, we had to put on jackets at night). Does there have to be a bigger difference in temperature to get condensation?
I didn’t check for condensation so it’s possible there was some and I just didn’t notice.
Don’t be ashamed B42, you are among friends… we are all scared of the dark too. :stuck_out_tongue:
ftfy :wink:
I took my EA4 tent camping last weekend. We got some rain but the light didn’t get wet. I was more worried the switch would balloon. It did fine, but I worried about it, so I bought a D40A when I came back, just for good measures :wink:
A G-Shock isn't using enough power to heat itself more than a fraction of a degree above ambient temperature.
I was thinking of a hot bath in a cool room.
Fair enough, its definitely sealed better than flashlights, good point.
I have had water condensation on the outer part of its mineral glass, but never inside.
