Power to the mcu goes through the reverse polarity diode next to led+(red wire). Check voltage there as well. If that’s ok then yes, the mcu is fried. Try a bit less flux or clean it off as it can block test leads from making good contact.
If it is the component I circled, then the end nearest the red emitter lead is showing input voltage (e.g., if the power supply is 3.65V, then I see 3.65V at the end of the diode nearest the red lead).
The other end of the diode shows 0V.
The markings on the diode has “||| S4” with the “|||” (3 lines) away from the at the end of the diode that is away from the red lead.
Is that diode bad then?
I can try to harvest the same diode from another board?
Or, can I just short across that diode, just to see if the driver starts working again, and then harvest/replace the diode?
Short the diode to test your mcu.
If it works then replace the diode for actuate low voltage detection (presuming the mcu is programed for that). As long as you don’t use batteries over ~4.2v and don’t care about low voltage detection or reverse polarity protection it will be fine bypassing the diode.
Is the zener for reverse polarity protection? If so, shouldn’t it be in PARALLEL with the input, rather than in SERIES?
EDIT: This is like going down a rat-hole :(.
I shorted across the zener, but I did that my bench supply voltage dropped to 0V.
So, I did some more checking, and it looks like MCU pin 4 (GND) is shorted to MCU pin 8 (Vcc)!!
EDIT 2: I am about ready to give up on this board. Things are really messed up.
I compared this board to another board (that kind of works, powers up, at least), and:
- I removed the diode completely from this board, and EVEN THEN, the MCU pins 4 and 8 are shorted to ground!!
- Poking around, I found that on this board, the “bottom” end of resistors R1 and R2 are both tied to MCU pin 8, whereas on the other, semi-working board, only R2 is tied to MCU pin 8.
I guess that if there was a complete circuit diagram of the board, maybe there’d be a chance to figure out where the short might be, but w/o a diagram, it’s really tough, because the vias run under some chips, etc. and I can’t figure out what’s going where :(!!
I would jumper across the diode to see if it’s the problem just be sure your polarity is correct. The voltage drop across the diode should be .6V, from the output of the diode to gnd (across the mcu) should be Vb - .6V. Vdd on the mcu is connected to the 7135 closest to the red wire via the pin on the 7135 that is closest to the red wire so a bit of solder is all it takes to bypass the mcu(common problem when adding new led+ )wire. That bit of solder should convert a non functioning multi mode driver into a functional single mode driver if the processor is the problem. If its the processor and not the diode you can use the diode as the jumper and maintain reverse polarity protection for the 7135’s.
I did jumper the diode, but then, I found the problem that was causing the ground… somewhere else, naturally.
It was actually on the OTHER side of the PCB.
Earlier, I had grounded the 4th star, to get just 2 modes. Then, when I was testing, I soldered a wire to the ground ring so that I could attach my power supply, so I just soldered that wire across from the ground ring to the 4th star.
HOWEVER, I hadn’t noticed that the bare part of the wire was too long :(, and it was touching the small cap that’s on that side of the board.
If you look at relic’s circuit diagram, that cap is going to GROUND, so it was causing the Vcc of the MCU to be grounded!!
I re-solder my test wire, and then VOILA - I got light, and LOTS of it…. With the 11 380mA 7135s, I measure slightly more than 4000mA from my power supply!
COOL!!
Probably what happened earlier was that that lead was on there but not touching the cap, and when I moved the board around, it must’ve pushed the lead to touch the cap, causing the ground :(…
Believe me, it’s a relief. I was starting to think that there was something inherently wrong about the 7135 mods, but really, shorting that diode, and also, that old hand-drawn diagram from relic that I linked in post #202 was what did the tricks. Once both of those were in place, it was more eliminating the possibilities and tracking down the short (which wasn’t exactly in the most obvious place).
Now that I have this one board working with the additional 7135s, which was more of an experiment to test things out for myself, I’ll feel a lot better doing stacking mods for other lights.
Yup! That schematic also helped me in understanding the driver. That’s the one I use on my DIY driver.
It would be great if we have a database of schematics for each driver!
On this last board, I decided to stack the 7135s on the spring side of the board, whereas on an earlier board, I had stacked the 7135s on the non-spring side.
I know that I need to remove the small original spring and put another, conical one, inverted, instead.
This driver is going into an Ultrafire S5, which is a small tube-style 18650 light:
The way that the head is arranged, originally, there was a reflector, a tiny pill with the emitter and driver, and that slid into the head. There was small circular wire ring that goes behind the driver, and then a retaining ring screws in behind all of that and pushes everything up to the front of the light.
When the retaining ring is screwed in, it touches that circular wire ring, which then contacts the outer ground ring, and that’s ow the path to ground is made.
In my case, I replaced the reflector and emitter with a 3up optic and a 3up star with 3xXP-G2 emitters and the 7135 based driver.
The thing is, with 7135s stacked on the spring side, when the retaining ring is screwed in, the 1st thing (and only thing, really) that it presses against are the 7135s, so it never gets to touch the ground ring on the spring side of the driver :(!
So, in this situation, how can I get the retaining ring to contact the ground ring/negative on the spring side of the board?
What would/do you guys do in this kind of situation?
Thanks,
Jim
EDIT: I kind of gave up on this driver (with 7135s stacked on the spring side) with this light. I found another problem, where the spring would bend over and touch the retaining ring, causing a straight short from battery positive to battery negative, so I think that the driver is not safe in this light.
So, I added a 4th 7135 to the 1st board, and put that into the light, and it’s ok now. The 1st board now has 4 7135 (380mA) on the pill side, and one of the “partition boards” from FT soldered to the original tiny spring, and then a spring on the other side of the partition board for the battery +.
Thought I would add my 2 cents. After adding way too many 7135s this past week (almost 100), I've found that soldering on the first piggybacked chip gets really easy after a while. Get it lined up, touch iron to 7135 on board for about 1 second, touch pin on piggybacked 7135 and drag up.
Where it was a lot harder was doing the double stacked 7135s... I couldn't figure out why sometimes I could get it to bridge while other times I couldn't, and it seemed like the more I did the worse I was getting! On one board I got so frustrated that I had to just walk away from it for a while. I tried three different types of solder... more flux... nothing was working. Well, turns out that what I needed to do was walk away from it for a while! The key is not letting the 7135s get too hot; if they don't suck out enough heat fast enough you can't bridge the gap. So when I was getting more practice and working faster I was actually working against myself. Now I start multiple 7135s and move around the board when I'm double stacking so that the next pin/chip has cooled down when I come back to it to bridge the next pin.
Hope that makes sense... you all probably know this stuff and it made total sense to me after I realized what was going on but I just thought I would share.
A quick word of appreciation to the OP and others that have chimed in with helpful info in this thread. As a relative soldering noob, I was pretty intimidated by the idea of stacking, but this weekend I did a zener diode mod and stacking for some floody MT-G2 goodness.
It actually went way more smoothly than I could have ever expected, so if anyone’s sitting on the fence about giving this a try, I’d say “go for it!”.
Forgive me for asking if this has been explained already but I skimmed through this thread and could not find the answer… probably because it’s a beginner question, even for a beginner
If I have a driver board with 8 x 380mAh chips and add one 380mAh chip I will get a total of 3420mAh when running on 100% mode, that part I get…
But how does it affect the other modes? The driver I would be adding to has specified 5% as low mode. Does the 5% low mode utilize all chips and draw 5% of them all (making it brighter with an added chip), or does the 5% utilize only one chip and adding one chip to the driver may or may not affect the 5% mode depending on which chip gets the new one added on top of it?
And a theoretical question: If I have a driver with 11 x 380mAh chips and have a programmed mode so output is for example 1500mAh, would there be a noticeable difference in run time compared to a driver with 8 x 380Mah chips running at the same 1500mAh current? Is there a loss in efficiency by having more chips on board?
Ok - 5% is 5% of the total amp limitation of the 7135's. The 7135's cannot be individually controlled on Nanjg or QLite drivers. 1500 mAh is an amount of energy, like in a battery, not a current, so not sure what you mean. A programmed mode in a Nanjg or Qlite cannot be for a specific amp limit, but represents a percentage based on PWM's. Typically with 7135 based drivers, high mode is a true 100%, while medium and low modes are implemented using PWM's. PWM is usually a very fast alternating ON/OFF, where 50% represents the LED on at 100% level for 50% of the time, and 25% means it's lit up at a 100% level for just 25% of the time, but flickers at a high rate where normally you can not perceive it's occurring. The higher the PWM rate, the less noticeable it will be. If you shine a light on low or medium mode at a ceiling fan for example, you can probably notice the flicker.
The reason of why you can only drive the LED at 100% and why PWM's is used is sheer cost and space savings to fit all these components on a very small board for a very low cost.
Also to clarify, 7135's only limit the current (amperage), they do not control or regulate the current at the summation value of the 7135's. So if your light and battery reach's the 7135's total in current, for example 3.04A, then that's the best you can do, but as the cell depletes it loses voltage, which results in loss of amperage, so you could end up at a lower amperage level, like 1-2 amps, when the cell is nearly depleted.
Hope this helps - not sure of your level of understanding these issues...
Oh I see. All chips are always used to 100%, but it’s the frequency that determines how bright the light appears. Makes sense.
My bad. I meant 1500 mA as in 1,5A current… But that question is irrelevant now as I understand that the driver will be running at it’s max capacity no matter what mode, it’s just the frequency that changes with the modes. Thanks for the explanation.
Yes - effectively, PWM's act as partial power - it even fools the DMM's when measuring amperage. It's a real simple way to address the problem, specially since the PIC's have the PWM support built in - real easy to program.
