Test/Review of Sibeile IMR18650 2200mAh (Black)
Official specifications:
  • Model: 18650 li ion battery
  • Brand: Sibeile li ion battery
  • nominal capacity: 2200mAh
  • nominal voltage: 3.7V
  • battery material: Li-ion rechargeable battery
  • positive pole: Flat top
  • rechargeable battery: Up to 500 times
  • impedance: <60mOhm
  • cycle life: >500 Cycles
  • Operation temperature: Charge(0 ~ 45°C)Discharge(-10 ~ 60°C)
  • Storage Temperature: -20 ~ 45°C
  • Dimension: Diameter 18mm, Height 65mm
  • Weight: About 46g
After shipping the samples to me, some print was added to the box.
Fairly good tracking between the batteries and they work up to 7A.
Conclusion
The battery has good capacity, but there is a slight difference between the batteries, I will rate it as acceptable.
Notes and links
The batteries was supplied by Sibeile for review.
Thanks for the review again :-) , it looks like a decent battery.
What would your guess be?, does this Sibeile company rewrap Panasonics and other batteries (because some perform very similar to existing batteries) or do they make (some of) their batteries themselves? And if they just rewrap, why does such a company exist?
The chinese ways are very unclear to me...
I expect they rewrap, these type of companies are all over the world, not only in China.
While doing the rewrap they often add some value, like protection or button top.
Another job, that some rewrap companies does, is select the good Chinese batteries.
