Single XM-L TR-J18-like
Does this look like the Same light?
Looks like the very same flashlight, without the shipping cost though.
If DRY driver is fitting without further modification, it would need the extension tube for the third battery, or I am wrong?
DRY is a 12V driver?
That site requires you to email for a shipping quote (so shipping on top of that price). We should do a group buy on this! Could be a fantastic host!
I also believe the DRY driver works fine with 2 cells. I'm thinking you just need more voltage in than you need out (i.e. 2 li-ions for 8.4v can drive a 6v MT-G2).
-Garry
ugh… that website is weird but they have good prices on most lights.
you could purchase it and then wait for the e-mail confirmation for the shipping quotes.
they need to learn a lot about selling online like eg: fasttech, wallbuys, lightmalls etc.
it’s been almost 2 months now and i’m still didn’t get the shipping quotes for my purchase :Sp
So you tried buying from them? Not going well then?
-Garry
How about this $29.20 @ DX
Nice find! I like it, although as a mod host, not that attractive due to the lack of high output drivers with electronic switch.. (I assume its electronics, and if its mechanical, or rebuilt to mechanical, there is very limited space for a driver circuit.) Also, less surface area due to lack of heatsink fins.
For those who like to keep their lights stock, it might be a very nice option, if the driver is decent that is. :)
What is up with the hole in the hotspot?
“What is up with the hole in the hotspot?”
Need more distance for better spot if It has big reflector :wink:
i gave up buying from them
i like. big light with big head and with a side switch.
this is on my radar for now.
First impressions:
- 1.0A at tailcap (other modes 0.5A, 0.15A, strobe, sos)
- Next mode memory
- Fast, almost unnoticeable PWM
- 540lm (OTF, after 30s)
- 34kcd (= 370m) throw
- Aluminum reflector, dimensions 53x46mm (OD 58mm, lens 58x1.9mm)
- 22mm press fit driver (was not properly seated, causing flickering & higher modes not working - pressing it properly in helped)
=> Looks like a decent mod host.
Here are some photos of the most interesting part of the light:
Thanks for the information the :slight_smile:
The pill looks like having very limited room for driver, might not be able to fit the IOS driver inside.
Do you mind taking pictures of the reflector base?
Thanks _the_! Yeah, what is the depth in the driver area? How's the overall quality?
-Garry
+1 Wondering about the same, and thanks for sharing first impressions.
BTW, who is going to see how far that stock driver can be pushed?? J)
Thanks for posting those pics - the pill looks rather nice. Hope mine gets here soon.
Overall quality matches the TR-J12. Not great, but totally ok for normal usage.
I'll try to take the requested measurements & photos later today (still busy at work).
About 12.5mm x 21mm + 1.5mm x 22mm => 14mm total
Some bonus pics of the reflector:
the lck led 5a 3 mode driver will fit in there……just an fyi, it can probably be resistor modded for more output if you wish too, the toroid is ’kin huge compared to the 3a version.
edit, dunno about the lectronic switch though lol
What "lectronic switch"? Does that driver use an "lectronic switch"?
-Garry
