KK 4000 protected from CNQ might be a good option. Never seen a test on them. But expect performance like KK, but generally 0,1V lower voltage due to protection circuit. Battery length might be an issue?
There is also the Soshine 26650, but they are probably not as happy with high current+ as the KK. Id guess they are out due to that. They were testet here. They are very long too! In that same thread some IMR cells were mentioned. Those might be an even better option than the protected KK for your light (but then there is obviously lower capacity).
I'm not a battery guy, but it sounds like you need IMR's. They don't come with protection, but are supposed to be safer as long as one follows the normal safety conventions. Less capacity is probably why you sound like you are avoiding them though.
I think he just wants as many options as possible. I agree that IMR’s are probably the best bet. Although I think the protected king kongs would work to. But I don’t know if I would take the chance when the IMR’s will work for sure and they have a lot of capacity when there is four of them.
I don’t know for sure but according to the batterywiki site IMR is Safer than INR but INR is still supposed to be safe chemistry and won’t runaway and discharge from use but can if punctured, incinerated etc.
i use kk 4000 inr’s because i was told they are safer.
but i would tell the guy to just purchase these MNKE’s instead, they are hard to come by and they sell out quick http://edcplus.com/mnke-imr26650-3700mah-p-5.html
i bought my mnke’s here and they are the real deal.
Wow, is it my imagination, or have Enerpower cells gone up in price? I was looking at them a while back and we had almost a possible group buy but they couldnt lower the price much. Another problem with them Werner brought up back then was the 8A discharge rate, they could not go higher as I remember, and with 15x 2A thats OK, but 15x 2.2A+ and it’ll pop protection…
is the light 15 emitters in parallel though? it reads to me that the emitters are wired series/parallel, I think they have gone up in price, I’d have to check on uk ebay because I know they were £33/pair plus shipping.
I also seem to remember the cells would do more than 8a but that’s where the protection tripped, its still, as far as I’m aware the highest limited protection circuit, what I’m saying is, if they wont do it, you might have to rule out protection circuits.
I also dont think I could get them shipped here then ship them across to you for less unfortunately.
I do know I want some, but almost a hundred quid for six is a bit much for me lol
just checked, their £36/pair on uk ebay or best offer with free shipping, I might have to put a bid in once I’ve sorted my PayPal out, its not verified yet and I’ve hit this years limit lol
Yeah thats exactly what stopped me last time…very steep.
I think it was said above its actually 3 sets of 5 wiring. HJK’s test showed 6.5A in the 3400 panasonic cells that were tripped, so we know its at least drawing over 26A. I’m questioning the wiring setup though, if its say just 27A that it will draw, thats 9A to each set of 5?
There are no real good possibilities, i know you dont want to hear it but it is like it is. These lights never have undervoltage protection. here is the devils circle: You need high maximum current because otherwise you would carry unused mass=> buy good batteries for high current=>they are empty fast=>need undervoltage protection=>there are no good batteries with good protection=>leads to lower current=>carry 2 kilos for a 3000lumen light I am away from 26650 in series lights because of this fact, the new multiemmiter light from kaidomain looks promising with 3p2s configuration. back to topic The enerdan groubuy price was 22Euro, so i would say the ebay link is similiar...maybe a bit more expensive with shipping and so on.... It looks like the circuit can handle more current but they don`t guarantee it. You have the 4s light so with 8A you get 110W, I would call this acceptable. I guess in reallife you get less current as the drivers are dissapointing. So go for the enerdan cells... I have not understand how the leds are wired.
There are three emitters that are wired in series. So it goes + + + and then off of the three negatives four more emitters are wired in series. So what is that 3S5P? I got a large jump in lumens when I wired it with 20 gauge wire and put the copper on the spring. I am guessing that it’s direct drive but I don’t know if it’s true or not because it does work with two batteries it’s just not bright that way. I never tried it with protected batteries. I just didn’t think of it. It didn’t seem to be making any of the batteries that I used overheat and I have had that happen before when I was really pushing the amps through them.
Let’s say for the sake of argument that it’s 3S5P direct drive with 4 cells. How many amps would that be? I have NO idea how to figure something like that out.
No you aren’t, that’s exactly what I’m saying: how could it pop protection in 4x26650s with 5A discharge and 4x18650s with 6.5A discharge in that configuration…I’m thinking it has to be parallel…
That would give you a lot of amps, super duper lot of amps…
Has it pwm in high?
I have the 9xT6 which is direct drive with 3 batteries and 3s3p LEDS , but on high it has still PWM. This beast pulls 9-10A, the battery voltage goes down a lot so it sinks a lot fast.
If the LEDs are 3s5p, than every group gets 1/5 of the current through the batteries, so 10A*1/5=2A.
And every LED gets 1and1/3 of the voltage, so it is like a single XML on direct drive with 1.33 batteries…so it will see a lot current.
as werner points out, if it were 15 in parallel you’d need what? 45a? I just dont see that, as 18sixfifty says, its definitely series/parallel, but if its direct drive on high, it’ll pull much more than 3a/emitter string. This is starting to give me a headache, I’m going to end up going getting a note pad and pen to doodle on if I carry on.
I am thinking now that it probably is direct drive on high and that’s why it had crap weak assed wiring to start with, it naturally limited the current to an acceptable level, rather than build a boost driver that could go 16v in 45v out lol
hell, even asking for a 15a buck driver is pushing whats available, never mind the poor 1.5a omten clicky at the dark end, I guess we are at the limit of whats feasible in a portable aluminium tube at this point.
