5.75A to emitters TK70!
Yes! I cant believe it myself! I lost the high/mid/low modes but I still have strobe and sos.
Man you modded such an expensive thing!
I have had this light since about 2008? Maybe it was 2009. I dont remember. I had problems with it a couple years after I got it. It would flicker and turn off by it self. It was a PITA getting it apart. I ruined the stock T6 emitters when I took it apart. So I upgraded to xml2-u2 emitters. I couldnt stop there! Haha!
Ken
Quick update,
I got it put back together and measured lux at 10 meters. I got 2190 lux. I used (3) 26650 flames I made a short filler with a piece of brass to get the contact in the battery tube. I did measure current at the emitters with the light assembled and it was 5.1A. Probably because of the extra resistance of the brass spacer. Beam shots tonight! (Still daylight here)
Ken
2.4A
5.1A
There it is. I barely got one shot in. Camera battery died. Im charging the battery in the camera. I will probably fall asleep before it charges. I been up since 4:45 this morning!
Ken
Thing looks beast! Thanks for the shots.
looks beast?
it IS beast. lol
219kcd!!
Dedome them!!
Thank guys! Im going to do some run times and heat tests today hopefully. Will update.
I have dedomed a lot of leds. Im not to crazy about tbe color afterwards. Im happy with 219kcd!
This light is sure a lot lighter now with 3 lithium batteries!
Oh yeah, strobe is wicked on this thing!!!
J)
Ken
What is the input voltage range of a stock TK70?
Stock TK70 takes 3-4D size batteries. Alkaleaks or Nimh
Working Voltage: 4.8V - 8.0V
Max Input Current: 6.5A - 7A
From a quick google.
I think my input current was less than 3A with the 3 lithiums. I can check later to verify. Dont hold me to that number just yet.
Ken
Thanks for your link.
The Thai TK70S version uses either 2 li-ion or the usual 4 nimh
http://www.thaipowerlight.com/Fenix-Flashlight/Fenix-TK70s
All TK70 can use 2 Li-ion cells. Not sure about 3 though.
Two of either links will be good enough?
http://www.fasttech.com/products/1420/10002171/1156400-feilong-32600-37v-5000mah-rechargeable-li-ion-batt
(as long as the D cell)
http://www.fasttech.com/products/1420/10002175/1156800-feilong-32650-3-7v-6000mah-rechargeable-li-ion
Yup!
Have you tried this set-up or something similar? Aside from the weight savings, what are the other things that can be gained with such set-up?
Shorter and better balance with a dummy cell near the head. I would prefer a 2D tube but cant find one.
I just measured tailcap current with 3 fresh 26650s. It was 3.84A on high. It stayed at 3.84A for 30 seconds of run time. I suppose my driver is safe!
Ken
