5.75A to emitters TK70!
Shorter and better balance with a dummy cell near the head. I would prefer a 2D tube but cant find one.
I just measured tailcap current with 3 fresh 26650s. It was 3.84A on high. It stayed at 3.84A for 30 seconds of run time. I suppose my driver is safe!
Ken
wow nice mod! can you tell me how many lumens now?
I can only really go by Matches test on the XML2 led on copper test. At 5100ma I would be at 4800 lumen. I like this light a lot because the reflectors are deep and it really throws well! I believe there is not a true way to convert lux to lumen?
Ken
So you have the stock driver in and running at 12.6V?
And its not smoking?
Thats correct! I even tried 4 cells. It didnt like it. The light would only shine dimly. This driver is very robust!
The only mod I did to the driver was bridge the sense resistors. Thats it!
I have about an hour run time on it with this mod too.
Ken
The math doesn’t add up.
Input power is around 46 watts.
Output power at 5.75 amps per emitter == 5.75amp x 3.8(vf at 5.75A) x 3(emitters) = 65 watts.
I didnt think to do the math. I am just measuring current in real time. I could have a fualty multimeter. Or maybe I’m not using heavy enough wire on my meter to test?
The 5.75A was a bench test with a Pb 12 volt battery. The assembled test was 5.1A at the emitters. The current test to the emitters was done at a different time when I did the tailcap current test. I do have another meter. I can try and test the output to the emitters and the tailcap at the same time. What efficiency are you using for the driver?
Ken
I just did another tail cap current read. I used 10 gauge tin coated copper wire as short as I could I got a tail cap reading of 4.54A. That should be correct. I should be a little more thorough in my tests. I just get so excited to see such a gain in performance and I love to share my results. Thank you for allowing me correct my accuracy.
Ken
Am I getting it wrongly? TK70 stock driver can take 3 x 32650? Wow!
Thats right! BUT, I dont know for how long. I am uncertain if it will last nor am I certian how hard I am pushing the components on the driver itself.
Mod at your own risk! I am comfortable with it, but I do not leave my highly modded lights on for extended periods of time either. If this TK70 crashed I would not be upset because I took it in my own hands to believe information gathered to be true from the net. Everyone has been great to me on this board. The last thing I want to do is share false information and be “that guy” who told me it would work and it didn’t.
Okay I’m done. Hahahaha! Its dark out! Lets make it light agian!
Ken
Hi!
Looks like you are in direct drive. As I understand, it can happen when you feed a boost driver too high voltage to regulate. Why dont you try an H6FLEX from four cells and see if you can get 6.5 amps to the emitters? 8) BTW, did you get your 12x shorty today?
Hey there! You the person I been talking to on KD? Yes I did get it! I wrote a long reply about it on KD.
I really like the shorty. I figured a little less than 1A to the emitters with 3A tailcap current. I measured 1140 lux at 5 meters. The wires from the driver to the emitters are kinda small but all else is great!
The H6 is the exact driver Im going to use after this one smokes!
This post should really confuse a lot of people. Hahaha. Im talking about a new 12 led 6 cell light Ijust got today. I bet everyone else is wondering what the heck I’m talking about!
Sure. Everyone must understand the risk and joy of modding. :slight_smile:
I am planning to mod a 2Mcd 5000lm flashlight. Still planning and buying material stage.
Wow! I can wait to see that! Too much is never enough! Haha!
Ken
Ya, after experiencing many different lumens and candela, not so excited with flashlights in the market now.
I have been playing with 2000lm 100kcd, 1500lm 260kcd, 5000lm 90kcd, 1200lm 475kcd, 3800lm 126kcd.
Now I think I need 5000lm 2Mcd to see what it looks like. Then that is it, will stop this hobby temporarily for not sure how long. :slight_smile:
Yes sir, I am! So, the shorty needs some slight modding then, to perform properly? Big surprise! :open_mouth: Any particular plans yet?
Small mods will really wake this 12x shorty light up! I dont have any plans in stone yet. I was thinking of doing a emitter swap with XML2 LEDs and HB but I already have the AK-90 with that set up. Are you still thinking about XPG2 LEDs?
Ken
Wow! I thought I had some powerful lights! It goes to show somone always has somthing better, faster or more powerful!!r
Yes, I will try those to see what it will do to the light picture. Smaller emitters driven by the same current will always throw better, even if you loose 30% of the light output compared to bigger ones. Besides, I think 2A is the limit for this light(I have ordered a j 20 to feed 3A), and that level should match XP-G2s well.
