Nice find! I like it, although as a mod host, not that attractive due to the lack of high output drivers with electronic switch.. (I assume its electronics, and if its mechanical, or rebuilt to mechanical, there is very limited space for a driver circuit.) Also, less surface area due to lack of heatsink fins.
For those who like to keep their lights stock, it might be a very nice option, if the driver is decent that is. :)
the lck led 5a 3 mode driver will fit in there……just an fyi, it can probably be resistor modded for more output if you wish too, the toroid is ’kin huge compared to the 3a version.
I have not been able to make it do more than 5,2A best. My testing have been limited though. I went back to stock, 5A. Unless someones makes it do 5,5A+ then Ill consider 5A the limit..
LCK-LED (/intl-outdoor/lightmalls) driver is the default "backup driver" for small pills... Ideally, Id like to use a driver that can do higher current in this light..
good to know, it is just a modded ld-29 at the end of the day, it must have limits. I’d not seen any testing reported though, guess you were keeping it under your hat.
Well, I don't write about everything I do. And its not that many weeks since I did it.. Most people does not have much interest for minor details. I have tried to share various small stuff in my flashlight collection thread. But little response/interest/questions.
fyi.. The LCK-LED and the IOS driver are the same driver, just different resistor values. That driver is easily resistor mod-able. Also, the FT $8 (FT-2-3-lithium-5-mode-3a-led) one is also the same driver, just a different inductor - I resistor mod'ed that one.
Racer86 - good info. I work with EE's, one guy who has worked on LED designs before. Basically the circuit design and components is based on the max amps spec to a degree, so you could have been seeing a brick wall there for this design with the 5.2A limit. Of course your test may depend on the voltages in and out, ie 2-3 cells, 1-3 LED's, etc. Using the TI website tool to design your circuit, if he puts in 6A as output, the parts get rather huge, too big for driver sizes we need - it was interesting, but of course that auto circuit generation is based on everything being within spec I'm sure, while we tend to go over a bit beyond the limits .
