East-92 4amp 17mm driver
Hey Ken,
What type of battery were you using when you tested the drivers?
I used a panasonic 18650 the green one with black stripe on top. You know the one without the buttontop. Lol. :smiley:
Great - I may have two more rubbish drivers on their way :frowning:
If you look real close, does the battery side of the PCB say “East 092B” by any chance??
The good DD version from my HD2010 has nothing printed on the battery side.
It says east 92. There is not a b at the end. You can barely read it in the black part of the battery side. All four of mine say the same. Hopefully I just got the last batch of 3a drivers. Let us know if you get the good ones!
Ken
Can I ask a question: Why do you (we) think that they have a “new” version that works as well as the “old”/original DD version? Have they (FT) indicated that that’s the case?
Maybe I assumed too much, but seems to me since they said they would stop selling it until they had versions that performed same as the originals, and they started selling them again, these performed the same as the originals. I added two to an order placed last week just to see what's up.
comfy,
If you read through some of the threads on their (FT’s) forum, it’s anything but clear what the permance of the driver that they’re currently shipping is, e.g.:
https://www.fasttech.com/forums/1127405/t/1028856/output-current-it-is-over-4-amps
A number of people (including myself, multiple times, and other BLF members) have asked on their forums, but they (FT) haven’t responded in a clear manner yet, as far as I’ve found. I hope that the ones you get are good, and if they are, I’ll be all over a couple of them, but it just doesn’t seem like that’s going to be the case.
Update… I just tried an unprotected 26650 TF flame. I did get 4.1A to a XML2 LED on a copper sinkpad. This was a bench test and not in a light. I just ordered 20 of them. Haha!
I also ordered some li-mn 18650 batteries. Since most of my lights that take a 17mm driver are 18650 lights. Has any one did a current test on this driver with a li-mn 18650?
Ken
This was with the driver from FT, right?
https://www.fasttech.com/products/0/10001752/1127405-3v5v-5-mode-led-flashlight-direct-drive-driver-cir
Thats it!
Thanks for the confirmation. I’m ready to order a couple from them, but I posted on a ticket asking which shipping method they suggest at this point, as I don’t want to end up with two orders being stuck (already have one that hasn’t move in almost 2 weeks).
Thanks again,
Jim
Hyprmtr,
BTW, you also have modes with that driver, right?
They say there its not the 4-amp version though, only just above 2 amps.
Yes it does have hi-med-lo-stobe-sos.
It looks like they will soon be out of stock agian if everyone orders! Haha!
Ken
Okay, if you dont believe me, there will be more for the rest of us! :smiley: Use a good quality battery. Thats all I have to say. Its direct drive in high mode. That should have told me to use a high discharge battery in the beginning. You cant use a recycled battery and expect good output in DD.
Ken
You can test for direct drive or not direct drive easy enough, just jumper LED- to BAT- and see if current increases. (or LED+ to BAT+, some drivers do it opposite)
They added that note when they stopped carrying the East92B driver a couple months ago. According to that very same note you shouldn't be able to buy the 2A version. They shouldn't have brought the driver back unless it's direct drive again, and they did, so it should be direct drive, and the first test supports that. This is great news even if it does have blinkie modes.
They also say a 200 lumen flashlight is 1000 lumens. :bigsmile:
I guess the opposite applies here. You know whats going to happen, you guys are going to order these and they will be 2A versions. Lol. It would be my luck. At 3.00 each its worth the risk if you ask me.
I will test all 20 that I ordered today when I get them. With a quality 18650.
Ken
Don't just check the current with the driver, also measure the current of the same cell on the same LED without the driver. Even if the driver does 4 amps that doesn't mean anything, if the same cell & LED does 6 amps without the driver in the circuit then the driver isn't DD on high.
The description on FTs page is kinda contradicting. They have the warning, but they also have the product in stock. Why not remove the warning if its the proper DD version?
Even when FT said they had the proper DD version several months ago, they didn't. No trust in FT from me when it comes to these types of things.
Im not tempted to order any more of these until its properly verified its DD and they deliver the correct product consistently.
