djozz
(djozz)
September 14, 2013, 2:00pm
2
Thanks for the nice test!
This is a very nice driver indeed. Because it works up to 5.5V, it would be nice to use it in a 4xAA NiMh configuration, the light will have a moderate but efficient output with good runtime and because of the good regulation it has a very good AA-alkaline compatibility.
HKJ
(HKJ)
September 14, 2013, 2:08pm
3
djozz:
4xNiMH will get you an input voltage just above maximum voltage and four alkaline will be about 6 volt, it might work or it might blow the driver.
My guess is that the 5.5 volt is because some of the chips has this as maximum voltage.
djozz
(djozz)
September 14, 2013, 2:16pm
4
HKJ:
djozz:
I think I will try this out sometime in a future mod, see what happens. Thanks again for testing how nice this driver is :-)
ryansoh3
(ryansoh3)
September 14, 2013, 2:33pm
5
Very nice review, thanks a lot!
Can you spot a sense resistor that could change the output current?
HKJ
(HKJ)
September 14, 2013, 2:41pm
6
My guess would be the R100 resistor behind the white wire:
ryansoh3
(ryansoh3)
September 14, 2013, 2:43pm
7
Interesting, thanks for the info.
I would like to use this as a laser driver, but a laser diode has a higher Vf then an LED. (about 5.5V)
I wonder if that would work out…
HKJ
(HKJ)
September 14, 2013, 2:55pm
8
I cannot tell you, I do not have a laser diode to test with.
Seems like a great driver for a 3xNiMH Mag mod. I love the efficiency. Thanks for the testing and review, HKJ.
bdiddle
(bdiddle)
September 14, 2013, 3:14pm
10
I wonder how it works with 2x cr123
+1
Seems like a missed opportunity (IMO) that it’s not ‘officially’ spec’d to handle them.
bdiddle
(bdiddle)
September 14, 2013, 3:26pm
12
Well…… looking at the 5.5v spot, it pulls .5 amps. Looking at his review of panasonic primary 123, it has a voltage of 2.75 at that current. Looks like it would work.
HKJ
(HKJ)
September 14, 2013, 3:28pm
13
You cannot guarantee that it will always run in high mode.
bdiddle
(bdiddle)
September 14, 2013, 3:29pm
14
I am actually only interested in a single mode. Is the memory on this the kind that will revert to high if I short one of the caps?
HKJ
(HKJ)
September 14, 2013, 3:33pm
15
I doubt it, it is stored in a EEPROM inside the microcontroller.
bdiddle
(bdiddle)
September 14, 2013, 3:43pm
16
doh. Almost the perfect driver. I am looking for a driver for a rifle light that is high only and can do 18650 and 2x CR123.
Maybe we can get Hank to sell these as 1 or 3 mode.
Thanks HKJ for these driver reviews, very informative.
I look forward to the smoke reports for those adventurous enough to over amp and/or over volt these tiny buck/boost driver chips.
Just as a follow up, it looks like a TI TPS63000 driver chip for this driver. The data sheet . The max output is 800ma for the LED in the Boost mode. You can see from HKJs Hi mode chart, how the internal fet switches start doing double duty in the boost mode.
FlashPilot
(FlashPilot)
September 14, 2013, 7:21pm
19
Thanks for the review HKJ. Now if only someone could create a similar spec driver that would boost 3A to the LED.
Ouchyfoot
(Ouchyfoot)
September 14, 2013, 9:50pm
20
I’ve been using this little driver for a while in a small Crelant clicky. It’s been wonderful, and I’ve had no problems. It drives a Nichia 219 with one 14500.
RaceR86
(RaceR86)
September 15, 2013, 1:56am
21
Looks like a sweet driver. :)
Thanks for the review!
