Yes, i know benchmade did the axis but the thread is about budget knives like ganzo and enlan.
Well, it seems that we don’t reach a valid conclusion about if the axis lock of ganzo is worst or better than the enlan. But a question: do you think that there is a relation between the milimeters engaged by the axis and the possible fail lock?.
If there is a real relation then ganzo has a bad/weak implemented axis lock and enlan a good implementation but somebody has done lock up test from its ganzo or enlan with axis lock?.
I was thinking to buy another ganzo knife last model but when i compare the axis with the enlan’s i don’t trust very much on it has a safe lock up and it closes on my hands…
The QC is not as consistent in this budget category as in the higher price ranges that’s why you should test every invidual knife by a spine whack before using it for heavy duty tasks, stabbing etc.
Regarding the quality of the Ganzos with axis lock my G710 has a better (smoother) action than my Benchmade 550. So you can find a Ganzo with a proper axis lock too.
Has anyone tried opening up an axis-lock knife to adjust the omega springs to get better lockup/engagement of tang? It may just need some small adjustment.
It’s quite easy to disassemble a Ganzo axis-lock because of the cut-out in the liners:
For example the Enlan EL02 doesn’t have that cut-out so you have to unscrew one end of the axis bar to push it through the liners. (I sanded smooth both ends of the axis bars on my axis Enlans so I gave up the disassembling at that point.)
Yes, my g710 is incredible smooth but only engages 1 mm on the tang. My g704 engange a liittle more but it is not as smooth (the pivot screw is not the solution) and my enlan el04 isn’t smooth at all but engage a lot a lot more than the others and the sound “clack!!” is pretty impressive and safe.
I’ve had myEnlan EL-04MCT’s apart, they were both a bit too strong on the Omega springs, but were easy to adjust by bending.
This involved removing the scales to be able to get enough movement on the springs to bend them, they are easy enough to remove with the scales off. The Torx screws were all held with Loctite and needed gentle heating with a “jet” type lighter on the stand-offs to unscrew, a soldering iron might work as well.
My Ganzo G-712 was also a bit on the tough side, being a lazy git I stuck a pair of needle nosed pliers, anly oe point, through the slide hole in front of the lock bar, blade open - lock engaged, and levered the lock bar rearwards as far as it would go. This was enough to bend the Omega springs and lighten the action.
There was enough travel on the lock bar to bend thev springs and it still locks the blade firmly.
The Axis lock is safe as long as the lock bar engages on the flat potion of the tang, if the lock bar doesn’t rest on a flat then you can adjust by dremel or file until the lock bar goes far enough forward to engage the flat. Then you might have to bend the Omega springs to put more forwards pressure on the lock bar.
The Enlan EL-04MCT’s that I have, the lock bar moves further onto the flat portion of the tang. The Ganzo engages, softly, but it does engage.
Because of the shape of the G-712’s blade it is only going to get used for light cutting anyway so even a light engagement is enough. The pointy nature of the blade is too weak at the tip for anything else and I have plenty of other knives better suited to heavy cutting.
If you are in danger of the lock failing, any lock, then use a fixed blade instead. The Axis lock when made and adjusted correctly is one of the strongest types of lock that there is.
Your g712 enganges only a bit too? like the g711 of the videos?. I’m awaiting my g712 still, but i’m starint to see the ganzo brand from another point of view, a bad point of view.
Yes, about 2mm on to the flat portion of the tang, the Enlan’s about 3mm. I feel that this is plenty. As the lock pin wears it will engage further up the tang, a feature of the Axis lock is that the engagement doesn’t suffer as the lock bar and tang wear.
There is about 2-3mm space on the slot in the liners where the lock bar moves back to unlock and forwards to engage. If the lock bar reaches the end of it’s travel in this slot then there will be blade play in the up/down plane but the blade will still be secure. This can be remedied by elongating the slot towards the front so the lock bar moves further up the tang. The tang has an upward slope towards the blade. there is about 6mm of travel left for slotting the liners before the lock bar runs out of adjustment.
If passing the knife on you may want to leave a note for your great-great-grandchildren because the the adjustment wouldn’t be used up in a lifetime of normal care and use unless you work where there is abrasive dust.
The Axis lock is a very strong design relying on lock pin/liners/blade tang/Omega spring, on the Enlan/Bee, SanRenMu and Ganzo knives that I’ve got, 1xBee EL-04MCT, 1xEnlanEL-04MCT, 1xSanRenMu LB-763 1xGanzo G-712 all the Axis locks are good and strong, only the SRM-763 didn’t need the Omega springs bending to weaken them, they hurt my fingers to operate and that isn’t the way Axis locks should be, with a bit of adjustment they’re fine.
The pivots also needed slackening slightly and lubricating to swing freely.
Don’t forget we are talking low cost knives, in the U.K. a Benchmade Mini Griptillian costs £63 - $100 my Enlan EL-04MCT cost me a quarter of that, with Micarta scales not a plastic handle. I don’t mind adjusting and lubing my knives, a small price to pay for some very high value knives.
Edit ———- The Benchmade Bedlam that the Ganzo G-712 is a “clone” of costs £155 in the U.K. that’s $250. :exmark: I wonder why I chose the Ganzo G-712 for $18 - £11.35
Well, when my g712 arrives i will compare the three ganzos about the locking system. Now my enlan el04mct engages a lot more than the ganzos and has a louder (a lot) sound when open the blade.
I’m starting to think than the g712 will be my last ganzo. But i have a problem, there is not models from enlan that i like (i have all that i like), srm are too small, navy… i don’t confide in it, inron… psss i have the my803 and the lock system is a little bad, may be harnds? may be a mora knife… mmmm Who knows… :bigsmile:
The lock on the Ganzo G-712 does close with a softer sound than the Enlans, unless you put a bit of wrist action into it.
I don’t think that there’s anything wrong with the Ganzo’s lock, it’s just a different view on how the Axis lock should be engineered.
This is my first Ganzo and it won’t be my last, there’s at least 6 others that I want to add to my collection. :bigsmile:
But if you engage 1mm on the tang cleary is less safe than if i put 3mm. Almost you could close with your hands staying locked if there isn’t almost touch between tang and lockbar.
Well, we’ll see…
You could always strip it down and gently remove metal from the tang’s flat section but as they are carefully designed to have a slight slope upwards towards the blade you would have to be very careful not to overdo it. that would work for the tang. If it’s the lockbar hitting the end of it’s travel in the slot then elongating the slots in the liners would work.
As long as the lockbar is on the flat portion of the tang then it will lock the blade in position, as the lockbar and tang wear-in then the lock-up becomes stronger.
If I had access to a lathe then I’d make a new lockbar slightly smaller diameter.
i had the same concerns, so i decided that this was going to NOT be a hard use knife. btw here is a link to a guy torture testing a Ganzo g704 (multiple videos). very interesting results.
