Okay, if you dont believe me, there will be more for the rest of us! Use a good quality battery. Thats all I have to say. Its direct drive in high mode. That should have told me to use a high discharge battery in the beginning. You cant use a recycled battery and expect good output in DD.
You can test for direct drive or not direct drive easy enough, just jumper LED- to BAT- and see if current increases. (or LED+ to BAT+, some drivers do it opposite)
They added that note when they stopped carrying the East92B driver a couple months ago. According to that very same note you shouldn't be able to buy the 2A version. They shouldn't have brought the driver back unless it's direct drive again, and they did, so it should be direct drive, and the first test supports that. This is great news even if it does have blinkie modes.
They also say a 200 lumen flashlight is 1000 lumens. :bigsmile:
I guess the opposite applies here. You know whats going to happen, you guys are going to order these and they will be 2A versions. Lol. It would be my luck. At 3.00 each its worth the risk if you ask me.
I will test all 20 that I ordered today when I get them. With a quality 18650.
Don't just check the current with the driver, also measure the current of the same cell on the same LED without the driver. Even if the driver does 4 amps that doesn't mean anything, if the same cell & LED does 6 amps without the driver in the circuit then the driver isn't DD on high.
The description on FTs page is kinda contradicting. They have the warning, but they also have the product in stock. Why not remove the warning if its the proper DD version?
Even when FT said they had the proper DD version several months ago, they didn't. No trust in FT from me when it comes to these types of things.
Im not tempted to order any more of these until its properly verified its DD and they deliver the correct product consistently.
I kind of agree. If the driver they’re currently stocking is truly DD, they should remove the warning (and others, and I have asked them to do that on their forums) and replace it with some new test results. So far, every driver (not many, but a few) that I’ve ordered, other than the 7135 ones, have not met their own specs.
Then again, I do believe what Hyprmtr (also on the FT forums) posted, and I want the working driver, so I’ll place an order for a couple to test myself, as soon as they respond to my ticket about shipping. I would hate to order these, and then have them get stuck in limbo like my current/last order with them.
You answered your own question, when you said “chips stacked”.
Plus, with the 7135 board, and with stacked chips, I don’t believe it’s “direct drive”.
Aren’t the 7135s current regulators?
So, I think that it’d be more accurate to say something like “if you stack enough 7135 chips, you might be able to get emitter current almost as high as you would with direct drive”.
But then, how many would you have to use to get 5 amps?
If they’re 350 mA 7135s, you’d need > 14 x 7135s. So assuming 8 x 7135 on the original board, need to stack 6 add’l.
If they’re 380 mA 7135s, you’d need > 13 x 7135s. So assuming 8 x 7135 on the original board, need to stack 5 add’l.
Yeah I know with my 13x 7135(~4.4A) drivers it is essentially direct drive on high unless I am using Samsung 20R batteries. NCR18650PD can’t even get max current. That is with 2.5mm copper braid on the springs and 22 gauge emitter wires. Xml2 on copper.
