Agreed! Best to clear up any questions before ordering. It will save many headaches down the road.
Another question that came up…there is not a order limit or cap at this time. 10 units is the minimum order quantity needed to offer the GB price and not the maximum number of units offered.
In the Solarforce light, the copper pcb was not a true one. It had a dielectric layer under the emitter. So I put a Noctigon in it, and did some tweaking to the driver for an estimated 4.86A to the emitter. It’ pretty dang sweet! While not throwing a “beam” of light, it puts light on a building 610 yds away.
Interests me that the MT-G2 is being said to “throw”. With 72 small dies making up the larger die surface, can it throw? Regardless of reflector? My reflector measures 71mm inside the bezel. Not much of a difference. De-doming the MT-G2 pretty much ruins it’s gorgeous tint, in my humble opinion. And I have yet to hear of anyone successfully doing it such that the phosphor stays on all those 72 dies. I really would like to see it done and see what it can do in that regard. So far, the general consensus is that de-doming makes it COOL instead of warming it. I’m not stating facts here folks, this is jut what I’ve been seeing. I can say that the one I de-domed did not take it kindly.
I’d love to see results of this work, hopefully before the group buy timeline runs out. Might end up doing some digging for moolah my own self…
Just a guess, since I have not seen the TN31 or K40 in person but this is the deepest single LED reflector I have seen. Even more so than the PowerTac X3000 and Thunderbolt. I suspect based on this alone, Niwalker decided to market it as more of a throw MTG2. I also suspect the claim is meant to be relative to other multi cell single emitter MTG2 lights, not true throwers.
I've tested the TN31 copper stars and the K40, and seem to be direct thermal path - both have thermal pads on the surface that test positively for continuity to the base. I've also got one of vinh's modified TN31's he said he did the sinkpad mod to, but it has the same large, stock copper star, so I think he's referring to the mod as a generic mod, in general he'd swap out for a SinkPAD but not if the stock is as good or better.
The important dimension for throw is width -- this is the major factor, but there are other minor factors. Dr. Jones wrote this up as did others with much better knowledge of optics than me, so absolute #1 factor is width, depth will reduce the spill area, maybe help slightly with throw, but not much, if at all.
For lumens, its funny -- I just measured 1,142 lumens @30 secs on a Convoy S3 EDC at 3.5A with XM-L2 U2 1A on a Noctigon. So this little tiny reflector can produce that - no throw, of course...
Selfbuilt does actually say that the reflector on the Niwalker is deeper.
Clearly, the BK-series is using a large reflector – it's one of the deepest ones I've seen, in fact. Overall dimensions and appearance are again very similar to the Thrunite TN31, but the BK-FA01 is actually slightly deeper. For an equivalent drive level, I expect it should have at least as good (if not better) throw than the XM-L2 version of the TN31.
Now while width of the reflector is the bigger factor to producing a thrower, the depth, and shape also matter. Based on what I've observed, the increased depth helps to concentrate the beam more.
The Armytek Barracuda, and Crelant 7G5CS for example (both lights I used to own) had almost identically wide reflectors. The Barracuda has much better throw.
All of that said if throw is what you're after, the MTG2 is not the right LED for that. The XML version of the light, stock no mods, has more than double the throw.
Still, compared to most flashlights, and certainly multiemmiter lights, it is a thrower.
My hope for the light is that with a boost from Vinh it will gain a bit throw simply through added power, and it will make for an overall more practical light.
What I am absolutely torn on, is whether to ask Vinh to dedome it, or leave the dome on.
I used to the term sinkpad as heat sink nowaday. I forgot that sinkpad is a brand. What else are you confused about from the list below?
*Direct copper bonding.
*New permanent thermal adhesive from copper sinkpad to host.
*Upgrade larger wires where needed.
*Upgrade High stiffness low resistance springs where needed.
*Touch up poor connection where needed.
*Tune for best beam focus.
*Lube O-Rings where needed.
*Dedome LED for extra throw.
*Current boost to the max while keeping reliability and Factory UI.
FYI, if I recall, when I de-domed an MT-G2, the light tint got cooler (the opposite of other emitters). There was at least one other user that saw the same thing when he de-domed his MT-G2.
Same effect I observed with my accidental dedoming. I'm hoping this is because I didn't do it properly and took off a lot, if not most of the phosphor.
Even so, even after that, the tint was still better than a domed xmlt6. Nowhere near as nice as it was with the dome (with the dome it was just gorgeous) but still nice.
