I got a feeling that when djozz said it’s not the same as looking at it in person that the issue maybe with colour balancing in his camera. But I’m no camera guy either.
You can get 100 CRI from both an incandescent bulb or the sun but that doesn’t mean objects can’t appear more blue or yellow. The way I understand it, higher CRI produces more visible colors so outside you get the full spectrum but it’s mostly blue because of our atmosphere. Inside under an incandescent lamp, you still have the full spectrum but less blue light is being produced. If you don’t have equal intensity throughout the spectrum for a comparison chart, the extra blue from the sky will make the yellowish charts look worse than they are and vice versa.
CRI comparison is only useful when using the same color temperature.
I am still learning this colour reproducing trick, and I am not doing really well..
My holy grail was to get on my and your monitor exactly the colours that I see in real life. I knew that was difficult, but I thought it to be possible to get close. That appears to be not true, far from it. Several reasons. The main reason is that the dynamic range of the real life colours can not be reproduced on a monitor, You miss out at least the vibrant reds, yellows, blues. For that reason those charts above do not show the best performing leds very well, on screen the charts look closer to each other than they really are, in real life differences are further apart, some differences are even absent on screen.
Another reason is that a (at least my) camera is not so good in capturing bright red and bright yellow, bright blue is much better. That said, in the digital colour chart that lightme provided (thanks for that, I find it very informative :-) ) the bright yellow and bright red tiles are also not as bright as in real life.
Perhaps the best way, to at least get the fairest idea of the differences between leds, is not to try to adjust the images on screen to match the real life colours (as I have tried above), but just show them without colour correction.
I just edited that post to indicate that. Every chart I find seems to be little different. Some have lighter shades but duller colors. Only you know what they’re supposed to look like.
Ok, you all decided to ignore my post, but nonetheless my reception of the colors isn’t that wrong - at least my colleagues back me for that. So i suspect you all to simply ignore the facts! :þ
the one thing I have noticed in de-doming XM-L2’s is that it doesn’t matter which one you start with they all end up the same exact tint when de-domed as long as you don’t destroy the phosphor layer or whatever that’s called. So isn’t it basically the dome itself that is giving the tint and CRI or am I missing something?
I think the 5B1 shows a bigger difference between tints in the reds and blues. Even the yellows look close with the Nichia but it does have them beat with greens and tans. I think it’s just a little too warm. That 3C ain’t too shabby either. Both also have better greyscales indicating a more neutral white.
http://hyperphysics.phy-astr.gsu.edu/hbase/geoopt/aber2.html
If you look at the light emitted from the edge of a domed mule, you’d see that it’s yellow and with a reflector, it forms the yellow corona around the hotspot. I don’t dedome but I suspect it gets rid of that aberration and more yellow hits the reflector’s sweet spot.
The 5B1 shows a clearly better purple than the dedomed Nichia, but the blue is similarly pale/dark to the blue of the dedomed Nichia. All in all the CREE 5B1 isn’t that bad, but the untouched Nichia still rock’s da house, sorry!
So you don’t deny that the tints for certain colors on the Nichia are closer to each other? And the other two are also more neutral? If it wasn’t so warm, it’d be perfect but it’s changing the true colors. Overall, the 5B1 chart look darker so I’m guessing that raising the XML’s voltage a bit will brighten things up.
I would rate the LEDs in following order:
1 ) Nichia 219A 4300K 92CRI
2 ) XM-L2 5B1 80CRI
3 ) XM-L2 6A1 80CRI
4 ) Nichia 219A 4300K 92CRI dedomed
5 ) XP-G2 mystery LED
6 ) XP-G “high CRI”
7 ) XP-G2 3C
8 ) XM-L2 0D
But this is only my personal perception. YMMV.
I own a Balder BD-1 modded from the original XP-G R5 1C to 4500K Nichia 219A B10. This light is so dam’n good in color reproduction, i even use it in macro photography to brighten up dark flowers and other objects in front of the lens.
If I had to make a list, I’d ignore how vibrant the colors appear and look for the chart that shows the most distinctly different colors. The dedomed Nichia would be dead last. The medium light grey is nearly the same as the light skin and yellow-green looks like yellow. Many of those colors are supposed to represent what we see in nature so (to me) having colors match defeats the purpose of high CRI especially outdoors. Honestly, I’d love to have both to compare before I jump to conclusions.
There is absolutely no point dedoming this wonderful led with the best CRI around and beautiful neutral tint, causing the tint to go warm and the output to go down, other than: I was curious about it :-)
No point, unless someone is looking for the benefit of a dedomed LED + the highest CRI.
If I am looking to throw as far as possible some green light, I will choose that :
More seriously. We are living in a society obsessed with gaining quantity, always more quantity, quite often unnecessary.
It is easier to score higher lumens using some ugly dedomed emitters (some Korean's bird shit signature)
than appreciating nuances and details...
I personally discovered the 219B dedomed properties by accident (I scratched the dome when hot during manipulation) By curiosity, I fixed back the reflector and was positively surprised by this "specific warm light"
The 219b dedomed definitely keep a high CRI, also add-on a nice & comfortable tint* - some kind of soft amber (with an orange dominant) and a hint of pink.
Any wood surface, skin or warm objects look like hot-braise illuminated (incandescent).
For a true neutral white with High CRI the latest 219B-v1 (with dome) do a perfect job. Really neutral.
For comparison:
(wall color, off-white with a tiny hint of green, ... It proves that the 219C reacts more on greens...)
About the 219C sample, I had to de-saturate the "green coloration" rendered (increased) by the camera sensor (S5 WB set on daylight)
here is what the camera reproduced:
Both 219b (with or without dome), reproduce colors quite well and do not disturb the camera sensor with "extra greenish"...
High CRI is not based (exclusively) on the temperature K, even though warmer LED tend to cover a wider spectrum.
*Comfortable tint:
For more than 100,000 years, human eyes have been genetically optimized to work with orange/red source of illumination during night time. Fire-torch light.
More lumens are always welcome, but they should come along with high CRI. The 219c will be interesting with a 90+ CRI rating.
Haha. Yes, I did the same thing with my first Nichia C from RMM not long ago — I just touched the dome accidentally with my clamp right after soldering the wires to the board and zip, dome gone (luckily leaving a fragment right over the connecting wires). Mentioned it in RMM’s thread and he said that kind of accident is how he learned about dedoming too. Soooooo easy to do.
Lovely result, too.
Is there some kind of sealant that can be painted on to protect the phosphor from volatiles? I recall reading that the phosphor will absorb anything that outgasses and change color over time.
That kind of neutral coating should be available...
Some led even have a thermochromic coating (cheap alternative to nanophosphors)
By the way, did phosphors have been damaged on your 219C? By checking some other posts, dedoming the C seems quite difficult.
...Or is it the method?..
Also, the new manufacturing process for the C series seems not to include an extra 1st (protecting/or filtering?) coating like the B. Could you confirm?
About the C tint, do you have some images sample of your dedomed 219C - outdoor pics?
I hope its not against the rules to bump such an old thread, but I did want to thank diozz for this thread. I used the hot dedome method, and some of the phosphor came off my 219b but it still works wonderfully.
I had two hot dedomes, one was from a fresh emitter swap, and the other was induced after I tried how a 5700K 219B would look. It looked absolutely awful.
The first one did not have any phosphors come off, and has a very warm color. The 2nd lost some of it and has a very clean neutral color. I got these LEDs with the intention to dedome them. I used a cheap razor blade as well.
For anyone trying to dedome them, I have had success so far, and its not that bad, but its still a rather intense process. heres some of the phosphor that came off.
This is indeed a rather long time ago, it isa 219A and I can see now that the it has a different way the phosfor layer is applied than the 219B and 219C (those have a low rim around the phosfor, this 219A led does not have that).
Is there danger of degradation on the LED? One dedomed with 2700k ish and this one was 4500k ish.
I have not had anything happened to my dedomed leds yet (my flashlight do not get much runtime at all and certainly not on highest setting), but some have reported dedomed leds failing early.
