Thanks for the positive comment and encouragement guys.
I worked on it more tonight, but I ended up blowing 2 emitters. This driver can really deliver the juice. I just reflowed a new emitter and dialed back the trim pot a lot, but its late and I need to crash. Hopefully, it will be at some semi sane level of current next time as this project is starting to go from budget to not so budget now.
Got it running tonight. That trim pot is real accurate for dialing in current. Set it to about 6.75 amps. I say about because I measured current with the pill out of the light. There could be resistance in the light that brings in down. There could have been resistance with the DMM that could have under measured (doubtful though).
The hot spot is much smaller now. Measured a 237kcd. Hopefully, I can improve that. I will hopefully take some pictures this weekend.
Yeah, that is amps at the emitter. Not sure if it is fully focused or not yet. Probably not far off.
I just took it for a walk last night. It's a light saber with some flood narrow faint spill. One has to be careful to not continually get dazzled by the concentrated beam/hot spot. Running it on low is about the only way to walk around with it on.
I will do this mod to my dedomed MT-G2 DST. Will only have about half the throw, but it will light up a big area. That is more my type of light for general usage. It won't run on Ni-mh, etc though.
I'll try. I still don't have the night time beam shot skill.
I don't know the current the emitters fried at. Here is what a happened. I'll admit ahead of time that I was not exercising the due care (from the emitters' perspectives). I was trying to dial in the trim pot. Started it at the mid point and got 4.3amps. That is pretty much the stock current. Expected that given the trim pot's specs. Started the process of turning a few turns and then reconnecting cells and testing current. After many iterations, I became concerned that I had a bad connection or bad trim pot. So, not wanting to unsolder the trim pot and test it, I decided to just short the trim pot, connect cells for a split second to see if current jumps. The emitter flashed the moment I connected (2 cells) and then the emitter no longer worked. No current flowed after the flash and I didn't see the current reading at the time of connection.
The second emitter. So I knew I had a good connection to the driver, but maybe the trim pot didn't work. So I turned the trim pot all the way up. Based on what I read about the lowest resistance the trimpot was capable of, I figured I was going to end up there anyway. Connected the cells and the same exact thing happened again. Flash, no longer worked, no current flowed after the flash, and didn't see the reading at the moment of connection. Probably didn't even register a reading as fast as it happened.
I know, I know. I knew better. Was tired and impatient. I need to not mod when I feel that way.
EDIT: I will add that this driver is deceptively beastly. I don't know how far the trim pot is from max, but it is further than I expected. Looking at the voltage sense resistors, they are physically large. Don't know the size spec, but they dwarf the typical sense resistor you see on drivers. I'll add this. I have a TN31 that I have to fight to get it in 6 amp territory. This driver gets there easy and is rock solid. The current doesn't fluctuate. I need to find a way to make this driver a slave to another MCU.
Up to 309kcd. Fabbed a copper spring (actually a dome) and that really increased the out put. Guess the half-ass copper tabs were not putting enough pressure on the cells.
Dropping the emitter back has really brought the light near focus. Right now the top of the reflector centering ring is flush with the inside of the reflector. Charging up some cells and will work on fine tuning the focus.
I guess what does looking so inexpensive have to do with flat-out raw size, big amps, and skilled determination ?
You could take a .99 cent store flashlight with these same basic dimensions and turn it into one relative blasting beast if one were so determined.
Never necessarily judge any light’s potential just by the look of its tube. :bigsmile:
This light has always had the bones even at $22.98 much less $12. One just had to recognize what it already had compared to others way more expensive that didn’t have it.
Unfortunately, I don't know the answer to your question. I have to remove the tail cap to measure draw. So that takes the copper dome spring out of the equation. Out of the light, with good connections, the emitter was getting 6.75 amps. At the tail, current settles down to the following readings:
High 2.83 amps
Med 1.23 amps
Low .29 amps
To complicate matters, I also turned up the trim pot 1/2 turn. So I should be getting more than 6.75 amps to the emitter. I need to center the emitter base. I will remeasure everything then and report back. Do you think I should up the current to the emitter to 7.5 amps while I'm at it? I'm quite tempted to.
Could you give us a close-up of where you connected the pot, and a link to the exact pot please?
This is the trim pot. Most of it's range is not used because it goes up to 10 ohms. I only have the above pictures for now. Next time I take apart the pill, I will try to remember to move the inductor out of the way and snap a picture. Legs 1 and 2 are soldered to the red wire. Leg 3 is connected to the black wire. Polarity does not matter. The 2 wires run over the top of the vertical pcb and connect to each side of the voltage sense resistor bank. If you magnify the below photo, you can see the wires soldered on each side of resistor R200.
I agree. I told someone else that with this light you are buying potential. I wish I had a lathe like MRsDNF. He has replaced the weak points of the light and turned it into a proper beast. Actually, if I had a lathe, I would still lack his amazing skill. Well, one needs to have dreams and folks to look up to. So at least I got that.
I don’t think your imaginative creativity will run out either. Look at what O-L creates with just a drill press.
Where there’s a will there’s a way. Finding someone that has a lathe that shares your passion isn’t close to impossible especially if you turn them on to that passion as well. Then you both benefit equally.
I even had one once. Absolutely stock looking 1964 2-door Falcon with a hi-po 271 hp 289 4 Hurst on the floor. ’Twas light on it’s feet and shocked more than a few in a cloud of tire smoke.
The only thing missing here is BEAM SHOTS. :bigsmile:
Great job ImA4Wheelr, that’s quite a thrower you have there. Thanks for sharing, you have got me thinking about what to do with that second DST still in plastic. Really like the driver mod.
