Now that is a really impressive bit of work. I'm not one for pocket clips, but you definitely made it much (Match?) better than it came from the factory.
Match
Legend!
The foam is mostly there to keep the edges of the metal discs I used from contacting and completing the circuit (and therefore bypassing the QTC completely). And yes, that little screw is a PITA, one of the reasons I installed the little QTC sandwich in the battery tube and not at the head.
Thanks for the nice comments, guys!
I do use a dremel for a bit of the work, but I actually use a good set of files more. The emitter for example, was filed by hand.
I don't have an LD15 for comparison, but later on I'll measure it in the I.S. to give an idea of output.
Mine E07 also came with a poorly cut slot in the brass screw in the base. I just never used it enough to hurt any cells. I did file it flat first before cutting the notches, filling with solder, and attaching the qtc. (Just noticed that pic isn't showing up....will have to fix that later).
And I don’t even know a high CRI XP-G from a normal XP-G :~
Yes Mr .Match You are the man ...and your wife, she's the woman .
LOL!
Really nice work, as always, Match! 8)
Jekostas, I've thought about doing what you did with the qtc a while back except I would use 3M super tape for the foam insulator, but can't figure out where to get copper, brass, or even aluminum disks. All I can find are washers and obviously that won't work. :D I could cut my own out of sheet stock but the resulting imperfect roundness and/or time shaping the disks is a real put off. I'm sure open for suggestions.
Johnny
What i have to say? Great work. I'm waiting for matchforce.com, a on-line shop where i can buy match modded light..
Filing Emitters by hand - hahah - last time I did this I used a file that was too coarse and it bit into the aluminium and I lost grip and filed the dome of the emitter of my neutral XM-L! Good to see yours is still nice and tidy (hehe!!)
Lovely mod with the XP-G! and a beautifully bent clip.
Much respect!
I have to ask, where did you find an emitter on a board that small?
Thanks Vectrex. Shipping kills it deader than dead, unfortunately. Total price would be more than the light itself.
illuminationsupply.com sells xp-g's on 10mm pcb's. Unfortunately that was still too big, hence the hand filing to make it fit.
How the #%@ did you get that screw out? I've got a screw and 2 separate chunks of what used to be the head, now.
The little brass screw. Yup, kind of a pain, since it has a very shallow slot. I used a thin hollow ground flat screwdriver and A LOT of pressure to keep it in the slot, then slowly turned. Also, make sure the cap is screwed in, and not in the "lockout" position. Once it's out, I performed the above mod to make it much easier to install/remove in the future.
Sorry about your cap. One fix would be to make a new one out of brass. I may try this anyways because I think it would look pretty sharp.
No worries. I was already digging through my random parts bin looking for one to match the snazzy ring near the head. I've lost the lockout feature, but otherwise no big deal.
That said, I don't know if I'd buy it again, given the choice. They did NOT make this little sucker to come apart easily, and the off-center emitter is driving me nuts.
Off center emitter...yup, that's what finally caused me to mod it. The head will come apart easily enough if you use a propane torch. Remove the O-rings first, then apply heat to the black aluminum above the threads. It doesn't take a whole bunch, but it has to be hot. I have two sets of pliers that I've made leather covers for the jaws so as to not gall the flashlight. Heat it up, and give it a light twist (standard threads). If it doesn't break loose with medium effort, heat it up some more.
Even without doing an emitter swap, you can center the original OSRAM which will improve the beam quite a bit. (and replace that awful glue they use as thermal compound!).
Hmm... Best I can do is a butane lighter. Not sure if that will work, but I can try. Might freeze the sucker first, try to crack the glue.
A quick re-seat and some thermal glue, and hopefully I'll be back in business!
