Had to get out to try it out. This lens has to be built into a zoomie because fully focused you need binoculars to see out far enough to to use the hot spot. The hot spot is too small within the range of normal eye sight. Check you my 20 minute to build light:
LOL. Yeah, totally surprised me too. I expected junk for $9. I'm thinking the issue is that it might focus the image of the die with some artifacts. Could just be my set up though with the white PVC. Well, I have to crash for work tomorrow. Night folks.
Hahaha… can’t blame him, that IS a popular technique nowadays! :bigsmile:
At 14cm FL, this FT lens is pretty much the same thing as DX, only $1.10 cheaper. Nice. Quite tempted to try this as well, except that I still have 62mm project lens laying around almost a year… with the project not even starting LOL. Maybe I’ll try 100mm after actually finishing that.
Paint everything in the head but the LED itself flat black. Or make a black insulator/shield to hide it. Flat is better, anything shiny will get projected along with the die image.
Wow, very nice results! But wait a minute…something looks familiar…did you steal jmpaul320’s camera and technique?
What is this technique you two speak of?
I turned on the light. Aimed it at a tree and snapped a shot with my other hand. I see that the camera moved during the shot. That was unintended, but turned out good in that I would not have posted the picture if the license plate number on that first car was readable. Is that the technique, move the camera during the shot? Does it enhance the shot? I ask because the beam was more impressive in person. Smaller, but brighter.
EDIT: I just PM'd jmpaul320 as I was wondering what I was missing. I get it now. LOL. Good one.
Thank you. I'll make sure what ever I end of is flat black inside as you recommend. This setup was just to try out the lens. The head gets too hot without the additional large piece of aluminum that holds the reflector and lens.
Use a tripod (or some way of holding it in a stable position) and the 'self-shot' timer, so you aren't touching the camera when it takes the pic.
Yeah, I agree I need to get one for the lights and one for the camera. Especially with my shaky hands.
I ordered a couple more. I really only need one though. I wanted somthing like this for spotting distant buoys on the water.
Yeah, I guess I could smooth, shape, and paint the PVC head to make it presentable. It's sturdy as heck. Actually, I can't get it off. I will need to use heat. The problem is, it doesn't help get rid of heat and this host doesn't have enough heat sinking in this configuration.
Maybe we could get a group together to have manufactured a host/head that is designed around this lens? Not exactly a budget option, but I do not think there will be a truly budget option for a proper piece thats not good for much more than a toy. No offence, it is a very impressive mod
No offense taken Pulsar. I really only slapped that together last night to get a feel for how the lens works. It's not a real build. The lens is held on by painters tape. I think I can build something that will work good, but I would rather find an existing host.
I think the GB idea is a good one. I think we need someone with more experience to evaluate the lens first thougth. After that, if we go GB, It would need to be a zoomie with real good heat sinking.
Thats what I am thinking. Maybe design it around a cheaper multi-cell light like the King or maybe something with stacked cells.
edit: I was also thinking zoomie. It would be one I would be all over. I think it would be hard to find a host that will take a 100mm lens and have 5.5" between led and lens
